    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • fredo6F
      @jdspdx said:
      Thanks fredo! I have the same condition as smithsam - Quickcard and Tutorials open as blank boxes from Documentation menu. Both are in BZ_Dir_12. --- jdspdx
      This seems to be related to the Mac platform, dealing with how Adobe PFD reader is installed or configured to ruun in web browser Safari.
      I would need other Mac users to advise and possibly gives hints on how to resolve this.
      • Bob JamesB
        Bob James
        My two cents worth: I have no problem with any feature of Bezierspline on my Intel iMac.
        Also the pdf files located in the BZ_DIR_12 folder open in Adobe Reader 9.
          Ayashi
          Excellent plugin! Thank you dude!
          • mitcorbM
            mitcorb
            Thanks, Fredo:
            I had a glance at this link and it looks very informative.
            • fredo6F
              I discovered a remarkable tutorial on BezierSpline written by Scott Onstottfrom AECBytes at http://www.aecbytes.com/tipsandtricks/2009/issue42-sketchup.html. It will drive you with a step-by-step tour of the plugin, with all types of curves (much better than what I could do).
              • O
                oblin77
                Hello Fredo06
                Where I can find and download your plugin BezierSpline v1.21 ?
                thank you
                Best regards
                olivier de france
                • soloS
                  Try the first page.
                  • plot-parisP
                    plot-paris
                    don't know if that behavior is specific to my machinde. but when I have drawn a curve, then go into edit mode, press Ctrl to unlock allow curve points to be moved outside the initial drawing plane and then press the up arrow to lock it to a vertical direction, my cursor doesn't stick to the point anymore. meaning, that when I move up my cursor only by a tiny bit, the curve point shoots up vertically a lot faster, and in very wide increments too.
                    if that is the general behavior of the plugin, would it be possible to change it, so that the point still sticks to the position of the curser (only the vertical position of course. to make things easier, a dotted horizontal line could be connecting the curve point and the curser).
                    any ideas if thats possible?
                    • fredo6F
                      I understand and I had myself questions about this behavior which may not seem very natural. Let's say 2 things about it:
                      1. The Vertex Edit mode is actually working for perfroming one move per click. So in your case, you would need to move first in the 3D, then release the mouse, switch to Vertical mode by Arrow and Click to move the point vertically. I agree that I should use the modifier keys as successive steps of Input. I'll probably do that in a further release.
                      2. Bezierspline was my very first script and I did not that much of the SU API. My plan would be to introduce stickiness and inferences, a little bit in the spirit of Tools on Surface.
                      • plot-parisP
                        plot-paris
                        I am really looking forward to this, Fredo.
                          misteriosodude
                          Amazing, excellent -- very useful plugin, thanks!
                            rv1974
                            How could I make 'polyline segmentor' command work? I simply can't find it. 😕
                            • Bob JamesB
                              Bob James
                              Right click on the line and then click on "Convert to"
                                rv1974
                                @Bob 👍
                                • fredo6F
                                  [New version 1.3 - 22 Dec 09]
                                  This upgrade allows to convert any sequence of segments to a Polyline or Spline (before, in version 1.21, you needed first to create a curve)
                                  I also added an extension for Dog-bone and T-Bone corners
                                  See main post at http://forums.sketchucation.com/viewtopic.php?f=323&t=13563&hilit=plugin#p100509
                                  • plot-parisP
                                    plot-paris
                                    wow, thats fantastic, Fredo! just yesterday I went through welding dozens of curves, just to polyline-divide them afterwards. now that would be sooo much faster! what a great christmas present! THANK YOU 😍
                                    and I see you've implemented some of the visual stuff of the 'round corner' plugin as well (like the green cursor when in edit mode). I like it a lot!
                                    I've got one question though, that I wanted to ask you for quite some time now:
                                    when I transform a polyline (or now just a series of linesegments 😉 ) into a Polyline Arc Corners, sometimes the distribution of vertexes is a bit strange, showing some corner with very high polygon detail, leaving others almost unrounded... is there a way to influence that? like to tell the plugin to distribute the vertexes evenly per corner?
                                    • fredo6F
                                      [attachment=0:28204xm3]<!-- ia0 -->bz_round_corner-problem01.jpg<!-- ia0 -->[/attachment:28204xm3]
                                      The number of vertices for the rounding is based on the Precision parameter given on a Full Circle basis. So for Precision = 24s, you'll get 24 points for 360°. Depending on the arc angle of the rounding, you'll get less or more points.
                                      Is that the explanation or do you see another issue or bug?
                                      • CadFatherC
                                        CadFather
                                        Thank you Fredo, it runs very well.. conversion is awesome!
                                        updated icons if needed
                                        IMAGES_CadFather.zip
                                        • simon le bonS
                                          simon le bon
                                          So Version 1.3 is out
                                          Always better and handy and complete. I add my single vibrant gratefulness to the vast number who have already given to you.
                                          So don't need to Weld anymore 👍
                                          DogBone added I have to look that!
                                          Also I've found a great interest and developments to use yourBZ__Animation (divider for flight path) in conjonction with Chris Fullmer's Component Stringer
                                          and also whith Shape Bender from the same to produce an arithmetic(?) segmented curve with it as your BZ__Animation is actually!! "limited to straight lines" 😉 😉
                                          Bien Amicalement, Simon.
                                            DIEGO-RODRIGUEZ
                                            hi fredo.
                                            a question.
                                            • how they work, the inferences. when I'm editing the nodes of a polyline?
                                              maybe. have an orthogonal way and a way to free movement, pressing ctrl
                                            • can add a tool that enables you to select multiple nodes in order to move them?
                                            • You can add, to draw a polyline (polyline insulation and polyline Zigzag)?
                                            http://img690.imageshack.us/img690/1589/sinttulo1qq.jpg
                                            • Plugins could be added to the libraries fredo? would be good to be able to translate and cuztomizar toolbar
                                            greetings and thanks for your exelentes plugins. and her willingness to help
                                            • 22
                                            • 23
                                            • 3 / 23
