    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • plot-parisP Offline
      plot-paris
      My plan would be to introduce stickiness and inferences, a little bit in the spirit of Tools on Surface.
      I am really looking forward to this, Fredo.
        misteriosodude
        Amazing, excellent -- very useful plugin, thanks!
          rv1974
          How could I make 'polyline segmentor' command work? I simply can't find it. ๐Ÿ˜•
          • Bob JamesB Offline
            Bob James
            Right click on the line and then click on "Convert to"
              rv1974
              @Bob ๐Ÿ‘
              • fredo6F Offline
                [New version 1.3 - 22 Dec 09]
                This upgrade allows to convert any sequence of segments to a Polyline or Spline (before, in version 1.21, you needed first to create a curve)
                I also added an extension for Dog-bone and T-Bone corners
                See main post at http://forums.sketchucation.com/viewtopic.php?f=323&t=13563&hilit=plugin#p100509
                  plot-paris
                  wow, thats fantastic, Fredo! just yesterday I went through welding dozens of curves, just to polyline-divide them afterwards. now that would be sooo much faster! what a great christmas present! THANK YOU ๐Ÿ˜
                  and I see you've implemented some of the visual stuff of the 'round corner' plugin as well (like the green cursor when in edit mode). I like it a lot!
                  I've got one question though, that I wanted to ask you for quite some time now:
                  when I transform a polyline (or now just a series of linesegments ๐Ÿ˜‰ ) into a Polyline Arc Corners, sometimes the distribution of vertexes is a bit strange, showing some corner with very high polygon detail, leaving others almost unrounded... is there a way to influence that? like to tell the plugin to distribute the vertexes evenly per corner?
                  • fredo6F Offline
                    [attachment=0:28204xm3]<!-- ia0 -->bz_round_corner-problem01.jpg<!-- ia0 -->[/attachment:28204xm3]
                    The number of vertices for the rounding is based on the Precision parameter given on a Full Circle basis. So for Precision = 24s, you'll get 24 points for 360ยฐ. Depending on the arc angle of the rounding, you'll get less or more points.
                    Is that the explanation or do you see another issue or bug?
                    • CadFatherC Offline
                      CadFather
                      Thank you Fredo, it runs very well.. conversion is awesome!
                      updated icons if needed
                      IMAGES_CadFather.zip
                      • simon le bonS Offline
                        simon le bon
                        So Version 1.3 is out
                        Always better and handy and complete. I add my single vibrant gratefulness to the vast number who have already given to you.
                        So don't need to Weld anymore ๐Ÿ‘
                        DogBone added I have to look that!
                        Also I've found a great interest and developments to use yourBZ__Animation (divider for flight path) in conjonction with Chris Fullmer's Component Stringer
                        and also whith Shape Bender from the same to produce an arithmetic(?) segmented curve with it as your BZ__Animation is actually!! "limited to straight lines" ๐Ÿ˜‰ ๐Ÿ˜‰
                        Bien Amicalement, Simon.
                          DIEGO-RODRIGUEZ
                          hi fredo.
                          a question.
                          • how they work, the inferences. when I'm editing the nodes of a polyline?
                            maybe. have an orthogonal way and a way to free movement, pressing ctrl
                          • can add a tool that enables you to select multiple nodes in order to move them?
                          • You can add, to draw a polyline (polyline insulation and polyline Zigzag)?
                          http://img690.imageshack.us/img690/1589/sinttulo1qq.jpg
                          • Plugins could be added to the libraries fredo? would be good to be able to translate and cuztomizar toolbar
                          greetings and thanks for your exelentes plugins. and her willingness to help
                            magpie
                            It's a tremendous tool for enriching sketchup, must now pay careful attention to all the subtle variations in the toolset...Thankyou fredo!
                            • fredo6F Offline
                              New version 1.3b - 31 Jan 10.
                              It fixes a bug in Segmentor and reconsolidates all sub-plugins recently introduced or changed.
                              One tip, before I forgot. When you wish to give more precision to a curve without redrawing it (for instance an Arc or Circle curve), you can use "Convert to Catmull". With a precision of 3s, you introduce an median point for each segment. With Precision = 4s, you introduce two median points, etc.... Try on a circle of 24 segments and make it a circle of 96 segments.
                                peter.b.nz
                                I am going round in circles! How do I download the bezierspline v1.3b plug in please. i keep clicking on the title but nothing is happening ...
                                • mitcorbM Offline
                                  mitcorb
                                  Go to the first page of this post. Mouse over the target file. Right click. Select Save Link As.. Make sure that the window that pops up shows the file name and be sure that file type is Zip file. Save to destination, say desktop, or Google Sketchup Plugin subfolder. I prefer desktop so that it gets me out of suspense. Then I cut or copy to the plugin folder. Then it is a matter of unzipping the folder in place in the plugins.
                                  Also, be aware that you need the latest version of LibFredo, a helper file for the plugin. Do the same thing to download this one.
                                  Hope this helps.
                                  mitcorb
                                    DIEGO-RODRIGUEZ
                                    hi fredo.
                                    a query.
                                    in this plugin, the inferences do not work correctly.
                                    in the first segment, generally work well (inferences, color axis)
                                    the second segment, with some work tools and other tools do not work.
                                    in the third segment, inferences generally do not work or the color of the axes.
                                    and does not block the inference to press the shift key
                                    that's normal? or is an error in my computer?
                                    if not normal, it might solve?
                                    Thank you very much
                                    • fredo6F Offline
                                      @diego-rodriguez said:
                                      hi fredo.
                                      a query.
                                      Thank you very much
                                      This plugin needs a serious refresh (this was my first one), in particular for the inference management, tangent positioining and some other additional features.
                                      So your computer is innocent!
                                      Fred
                                        tulacong
                                        thank you ๐Ÿ˜
                                          mm5949
                                          hi fredo.
                                          a query.
                                          Thank you very much
                                          Fred
                                          So, should I download v1.3b, or should I wait for v.1.3c?
                                          If so, where can I find the download? I would like to try it.
                                          Thanks for your good work, ๐Ÿ˜„
                                          Mel
                                            jcoulter1890
                                            This tool looks amazing bit how do i actualy download it. Is there a link any1 can give me?
                                            • 22
                                            • 23
                                            • 4 / 23
