    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • W Offline
      watkins
      Dear Edson,
      You are not the only one to spot that. I will have to be more careful in future.
      Regards,
      Bob
        mattg
        Just re-downloaded this for SU7.
        Any reason why the toolbar won't hug the side of the screen.
        Seems to only want to sit horizontally along the top.
        • fredo6F Offline
          Matt,
          As you may know, scripts have zero control over the toolbar placement from Ruby.
          So it must be SU7 or the configuration of the toolbar set.
          In my SU7 environment, I don't have any particular issue.
          • W Offline
            watkins
            Dear Mattg
            You should be able to 're-shape' the rectangle of icons by searching for re-sizing arrows at the edges using the mouse pointer. Once re-shaped (horizontal rectangle to vertical rectangle) it can be placed along the side.
            Regards,
            Bob
              mattg
              Thanks Bob, too easy!
                jdspdx
                Thanks fredo! I have the same condition as smithsam - Quickcard and Tutorials open as blank boxes from Documentation menu. Both are in BZ_Dir_12. --- jdspdx
                • fredo6F Offline
                  This seems to be related to the Mac platform, dealing with how Adobe PFD reader is installed or configured to ruun in web browser Safari.
                  I would need other Mac users to advise and possibly gives hints on how to resolve this.
                  • Bob JamesB Offline
                    Bob James
                    My two cents worth: I have no problem with any feature of Bezierspline on my Intel iMac.
                    Also the pdf files located in the BZ_DIR_12 folder open in Adobe Reader 9.
                      Ayashi
                      Excellent plugin! Thank you dude!
                      • mitcorbM Offline
                        mitcorb
                        Thanks, Fredo:
                        I had a glance at this link and it looks very informative.
                        • fredo6F Offline
                          I discovered a remarkable tutorial on BezierSpline written by Scott Onstottfrom AECBytes at http://www.aecbytes.com/tipsandtricks/2009/issue42-sketchup.html. It will drive you with a step-by-step tour of the plugin, with all types of curves (much better than what I could do).
                          • O Offline
                            oblin77
                            Hello Fredo06
                            Where I can find and download your plugin BezierSpline v1.21 ?
                            thank you
                            Best regards
                            olivier de france
                            • soloS Offline
                              Try the first page.
                              • plot-parisP Offline
                                plot-paris
                                don't know if that behavior is specific to my machinde. but when I have drawn a curve, then go into edit mode, press Ctrl to unlock allow curve points to be moved outside the initial drawing plane and then press the up arrow to lock it to a vertical direction, my cursor doesn't stick to the point anymore. meaning, that when I move up my cursor only by a tiny bit, the curve point shoots up vertically a lot faster, and in very wide increments too.
                                if that is the general behavior of the plugin, would it be possible to change it, so that the point still sticks to the position of the curser (only the vertical position of course. to make things easier, a dotted horizontal line could be connecting the curve point and the curser).
                                any ideas if thats possible?
                                • fredo6F Offline
                                  I understand and I had myself questions about this behavior which may not seem very natural. Let's say 2 things about it:
                                  1. The Vertex Edit mode is actually working for perfroming one move per click. So in your case, you would need to move first in the 3D, then release the mouse, switch to Vertical mode by Arrow and Click to move the point vertically. I agree that I should use the modifier keys as successive steps of Input. I'll probably do that in a further release.
                                  2. Bezierspline was my very first script and I did not that much of the SU API. My plan would be to introduce stickiness and inferences, a little bit in the spirit of Tools on Surface.
                                    plot-paris
                                    I am really looking forward to this, Fredo.
                                      misteriosodude
                                      Amazing, excellent -- very useful plugin, thanks!
                                        rv1974
                                        How could I make 'polyline segmentor' command work? I simply can't find it. 😕
                                          Bob James
                                          Right click on the line and then click on "Convert to"
                                            rv1974
                                            @Bob 👍
                                            • 22
                                            • 23
                                            • 3 / 23
