    [Plugin] UV Toolkit
    377 Posts 86 Posters 415.1k Views 86 Watching
    • GaieusG
      Thom, great stuff so far! In my basilica, there was an arch in which there was literally hundreds of bricks. Even with the UV toolkit, it needed a lot of manual "quading" of the faces. 😲
      (and there were like 7 different sizes so you can imagine that day I was making them). πŸ˜†
      • majidM
        majid
        maybe adding a "goust preview" of how plugin is going to UVmap (i.e. showing a sphere when choosing shepherical...etc) could improve the ui!!
          mm? I got no spherical mapping option.
          As for the mapping types I do have, I don't have any API to draw texture previews.
          • PixeroP
            Pixero
            Just wanted to say thanks. I've had this plugin for a while but recently it saved me when doing some remapping of leaves on a highres tree. πŸ‘
            Looking forward to the next version.
              Jim
              Is this correct, or am I using it wrong? I applied the material, selected the face, and selected "Rotate QF Clockwise 90" from the menu.
                I think it's doing it correct. As it rotates the orientation of the texture it stretch the texture to fit the quad-face.
                For normal texture rotation you use the rotate methods from the native Position Texture tool.
                  Jim
                  Ok Thanks, I was just thinking about a quick shortcut to rotate a texture 90 degrees (no stretching.)
                    To add a hotkey to?
                    Since SU already has a rotate method I haven't made one myself.
                    But you can't assign a hotkey to it. That is one reason why I have considered recreating my own function. But it haven't been high up on the list.
                      Jim
                      Looking at your UV Tools, you are shifting the positions of points in 2 arrays. Is it as simple using a rotation on the arrays (around face.normal at face.bounds.center, maybe) instead of shifting? I'll try that.
                        I don't quite remember what I did. But what I do is somewhat special for quad-faces with textures stretched to fit.
                        Think you need some different handling for a general rotate method...
                          Jim
                          It works for square textures (where the image is square) but distorts rectangular ones.
                            I think what you need to do is sample four points in a quadratic formation of the face's plane and then shift the 3Dpoints.
                              @pixero said:
                              First, an option to keep the scale of a texture when rotating.
                              That's a mighty small image there... can't see much what's going on.
                              The rotate feature is meant for textures stretched to fit quad-faces. Special purpose rotate. SU already got rotate methods built in - When you activate SU's texture gizmo - you have a Rotate sub-menu.
                              • PixeroP
                                Pixero
                                Here's my two requests for a great tool:
                                http://imagecloset.com/28/a429772e52af5cc3266b8d5eb74ce6f3/UVrotate.jpg
                                Second, add it to the right click menu for easier access.
                                Edit: Fixed the image size. πŸ˜’
                                • PixeroP
                                  Pixero
                                  Still its great to be able to select a bunch of faces and rotate at the same time.
                                  You cant do that with SU's build in tools can you?
                                    No you can't. Good point. I could add that feature. πŸ‘
                                    • PixeroP
                                      Pixero
                                      I'm using it to rotate the texture on leaves on trees so doing it manually isn't an option. πŸ˜‰
                                      And don't forget the right click menu...
                                        Only thing though, about which points should it rotate...?
                                        • PixeroP
                                          Pixero
                                          Can't you just swap the UV "scale"?
                                          I mean like it is now but with an option to keep the scale on the X and Y axis.
                                          (Rotating the points so that Points A,B,C,D would be D,A,B,C or something like that.)
                                            There is no such fixed points. The one for the quad-faces works like that because you can use the four vertices of the face. But you can't do that when you have differently shaped faces and/or want to preserve scale.
                                            With SU, you have to generate the set of points yourself and query the face. So when rotating, I need one anchor point.
                                            • 18
                                            • 19
                                            • 4 / 19
