    [Plugin] UV Toolkit
    377 Posts 86 Posters 391.2k Views 86 Watching
    • jeff hammondJ Offline
      @thomthom said:
      As it is in it current state you'd have to select each row by it self. Your top row is no different from the lower ones except it got larger faces.
      But I hope to be able to make it cascade through connected rows, but it'd still have to be quad-faces. Quad-faces are just so much more predictable.
      right, i realize that each row is the same.. i'm just wondering if everything will line up through those bends?
      right now in SU, i can get basically two results:
      on the left if i just import and paint it on.. the right if i turn on hidden geometry and sample/paint each quad.. i'm really hoping for something more like the middle but not necessarily on a sphere. (that's done with whaat's UVtools)
      are you thinking you may have come up with a way to do this?
      [EDIT] -- ouch.. and i just remembered if i want to render that sphere in indigo and have it turn out correctly, i have to triangulate the faces first. i'm wondering what would happen with these quads that aren't part of a sphere.
        Like this?
        Could you triangulate after mapping?
        I think I should be able to deal with triangulated quads - but it won't be the first to be implemented.
        • EscapeArtistE Offline
          EscapeArtist
          Oh man, this made texturing some of the stuff I do so much easier.
          Thank you! πŸ‘ 😍
            @thomthom said:
            Like this?
            ha, yes.. exactly like that
            actually, yes.. i just tried it but i have to triangulate manually after mapping.. previously, i tried using the triangulateFaces ruby by TIG but it screws up the mapping if i do it afterwards.. i just assumed doing it manually would create the same problem but no, it works.
            • Y Offline
              ygcl
              @frederik said:
              Thanks,
              πŸ‘
                Thom, great stuff so far! In my basilica, there was an arch in which there was literally hundreds of bricks. Even with the UV toolkit, it needed a lot of manual "quading" of the faces. 😲
                (and there were like 7 different sizes so you can imagine that day I was making them). πŸ˜†
                • majidM Offline
                  majid
                  maybe adding a "goust preview" of how plugin is going to UVmap (i.e. showing a sphere when choosing shepherical...etc) could improve the ui!!
                    mm? I got no spherical mapping option.
                    As for the mapping types I do have, I don't have any API to draw texture previews.
                    • PixeroP Offline
                      Pixero
                      Just wanted to say thanks. I've had this plugin for a while but recently it saved me when doing some remapping of leaves on a highres tree. πŸ‘
                      Looking forward to the next version.
                        Jim
                        Is this correct, or am I using it wrong? I applied the material, selected the face, and selected "Rotate QF Clockwise 90" from the menu.
                          I think it's doing it correct. As it rotates the orientation of the texture it stretch the texture to fit the quad-face.
                          For normal texture rotation you use the rotate methods from the native Position Texture tool.
                            Jim
                            Ok Thanks, I was just thinking about a quick shortcut to rotate a texture 90 degrees (no stretching.)
                              To add a hotkey to?
                              Since SU already has a rotate method I haven't made one myself.
                              But you can't assign a hotkey to it. That is one reason why I have considered recreating my own function. But it haven't been high up on the list.
                                Jim
                                Looking at your UV Tools, you are shifting the positions of points in 2 arrays. Is it as simple using a rotation on the arrays (around face.normal at face.bounds.center, maybe) instead of shifting? I'll try that.
                                  I don't quite remember what I did. But what I do is somewhat special for quad-faces with textures stretched to fit.
                                  Think you need some different handling for a general rotate method...
                                    Jim
                                    It works for square textures (where the image is square) but distorts rectangular ones.
                                      I think what you need to do is sample four points in a quadratic formation of the face's plane and then shift the 3Dpoints.
                                        @pixero said:
                                        First, an option to keep the scale of a texture when rotating.
                                        That's a mighty small image there... can't see much what's going on.
                                        The rotate feature is meant for textures stretched to fit quad-faces. Special purpose rotate. SU already got rotate methods built in - When you activate SU's texture gizmo - you have a Rotate sub-menu.
                                        • PixeroP Offline
                                          Pixero
                                          Here's my two requests for a great tool:
                                          http://imagecloset.com/28/a429772e52af5cc3266b8d5eb74ce6f3/UVrotate.jpg
                                          Second, add it to the right click menu for easier access.
                                          Edit: Fixed the image size. πŸ˜’
                                          • PixeroP Offline
                                            Pixero
                                            Still its great to be able to select a bunch of faces and rotate at the same time.
                                            You cant do that with SU's build in tools can you?
                                            • 18
                                            • 19
                                            • 4 / 19
