    Render this: LCD screen (light emitting material)
    59 Posts 30 Posters 19.3k Views 30 Watching
    • EarthMoverE Offline
      EarthMover
      Thanks Notareal. I adjusted the material and got a better result. Also added an HDRI for fill light.
      Content Creator at Skapeup
      • FrederikF Offline
        Frederik
        Excellent render, Adam... 👍
        What render app. did you use...??
        Cheers
        Kim Frederik
          EarthMover
          Thanks Kim. I used Vray for Max with the Solid Rocks plugin for render settings. Vray light material for the LCD.
          • charly2008C Offline
            charly2008
            A quick Photon render with Kerkythea. Again something learned about emitting light. Thanks Pete
            Karlheinz
              lexmonteiro
              If I may, I would like to try again.
              I went to sleep last night thinking of a way to render as quickly as possible without light-emitting materials, and today I woke up and I had the idea to only using projectors, a thin glass to cover the screen, and most importantly, projector must coincides exactly with the image on the screen.
              Then I looked at my clock alarm and I think that this may be interesting to show the reflection in the "thin glass" over the Iphone screen, how to do this too...? I put a red light iside the alarm and a red glass on the numbers, the result you see now!
                d12dozr
                Awesome effect...you have reflections going both ways ☀
                http://goo.gl/f7ooYh
                • olisheaO Offline
                  olishea
                  good topic pete, some lovely renders here. im cooking one now 😄
                  oli
                  • boofredlayB Offline
                    boofredlay
                    Respect Oli. This is my favorite so far.
                    • jeff hammondJ Offline
                      here's an iphone screenshot from the original post in this thread.. let me know if you want a different screenshot to use in your render 😄
                      • olisheaO Offline
                        olishea
                        lol
                        thanks eric.
                        pete....what silver/chrome material did you use for the first render? looks very very nice...great lighting on that one. 👍
                        oli
                        • Rich O BrienR Online
                          Here's my attempt.....
                          Twilight Easy 9 [5hrs Cooking]
                          • olisheaO Offline
                            olishea
                            I got mugged by an iphone; lingering in this back alley:
                            http://i654.photobucket.com/albums/uu269/olishea/final2-3.jpg
                            twilight: fake emitter @ 100W, interior preset, studio hdri at 0.3 brightness (for fill light), sunlight disabled, rough stone template to concrete
                            edit: a slightly different version
                            http://i654.photobucket.com/albums/uu269/olishea/final3.jpg
                            oli
                            • dermotcollD Offline
                              dermotcoll
                              Oli
                              wish I had the time to try this but too busy working to attempt these challenges at the minute - making mental notes on the tips though!!!
                              BTW how did you manage to get an AT&T signal all the way over there in Manchester lad!!! I thought o2 was the only service provider in the UK for iphones!!!!
                              When you burn your arse - you gotta sit on the blisters!!
                              • olisheaO Offline
                                olishea
                                keep making mental notes mate you'll be shit hot in no time! 👍
                                oli
                                • soloS Offline
                                  Oli, I used an Aluminum base, and tweaked it a little.
                                  • olisheaO Offline
                                    olishea
                                    cheers
                                    oli
                                    • Al HartA Offline
                                      Al Hart
                                      @solo said:
                                      Al Hart has a render tip floating around regarding back lighting, I thought we could expand on that slightly and have a challenge to render an IPhone, with an LCD screen.
                                      There are a lot of great iPhone renders here in this thread and a lot of good lighting effects.
                                      The original tip, though, was about using a non-light emitting, self-glow, material instead for the iPhone. This compromise will never produce as good a rendering as the actual illuminated iPhones, but it the phone itself is just an accessory, rather than the main object of the rendering, then it may speed up the rendering process by not including additional light sources.
                                      Here are a couple of iPhones on a table - one is on and one is off.
                                      (Their are no light sources in the phone - just a material marked as self illuminating)
                                      Al Hart
                                      IRender nXt from Render Plus
                                      • FrederikF Offline
                                        Frederik
                                        Although I can see there's a difference between the two phones, I can't tell which one is "on" and which one of them is "off"... 😐
                                        @solo said:
                                        I'd suggest a dark environment and maybe posing the phone in a way that the light can reflect on a surface
                                        Cheers
                                        Kim Frederik
                                        • Al HartA Offline
                                          Al Hart
                                          @frederik said:
                                          It's a little tricky to make the image look lit-up, (I am trying to avoid putting actual lights behind it.)
                                          One idea is to manipulate the original image, so that it looks more "lit-up" in the first place. I suppose the photo-shop experts could do this easily. It will be more tricky for a "Paint" novice like myself.
                                          The other is to play with the "self glow" to increase the brightness of the image, without starting to make the black parts look lit up as well.
                                          I'll see what I can do.
                                          (Original image)
                                          Al Hart
                                          • olisheaO Offline
                                            olishea
                                            great render escapeartist 😄
                                            oli
                                            • 2 / 3
