    Render this: LCD screen (light emitting material)
    59 Posts 30 Posters 19.3k Views 30 Watching
      Chris_at_Twilight
      I used modeling to provide the emitter / reflection combination. I moved the screen back a tiny bit and placed another "plastic" surface in front. Made the apple glow, just because. 😉
      http://www.TwilightRender.com
      • stefanqS Offline
        stefanq
        V-ray renders, studio setup, I just used the same texture from diffuse, for the emissive layer of the v-ray material.
        http://img140.imageshack.us/img140/4426/iphone1z.jpg
        http://img685.imageshack.us/img685/805/iphone2d.jpg
        • soloS Offline
          2nd try, used light caustics.
          and a very low res .gif.
          http://img694.imageshack.us/img694/7915/iphone.gif
            lexmonteiro
            This Is "TWiphone"!
            Twilight 6 minutes:
            • RichardR Offline
              Richard
              very nice!!!
              BUILTBRAND.COM.AU
              • EarthMoverE Offline
                EarthMover
                Finally had a few minutes to throw these into the mix. Great renders all the way around from everyone!
                Content Creator at Skapeup
                • N Offline
                  notareal
                  Adam, I like the composition of Iphone_LED2.jpg. Good looking materials, except there is something odd going with the table lamp; ceramic base has some material (or surface normal) problem with the grazing angle.
                    EarthMover
                    Thanks Notareal. I adjusted the material and got a better result. Also added an HDRI for fill light.
                    • FrederikF Offline
                      Frederik
                      Excellent render, Adam... 👍
                      What render app. did you use...??
                      Cheers
                      Kim Frederik
                        EarthMover
                        Thanks Kim. I used Vray for Max with the Solid Rocks plugin for render settings. Vray light material for the LCD.
                        • charly2008C Offline
                          charly2008
                          A quick Photon render with Kerkythea. Again something learned about emitting light. Thanks Pete
                          Karlheinz
                            lexmonteiro
                            If I may, I would like to try again.
                            I went to sleep last night thinking of a way to render as quickly as possible without light-emitting materials, and today I woke up and I had the idea to only using projectors, a thin glass to cover the screen, and most importantly, projector must coincides exactly with the image on the screen.
                            Then I looked at my clock alarm and I think that this may be interesting to show the reflection in the "thin glass" over the Iphone screen, how to do this too...? I put a red light iside the alarm and a red glass on the numbers, the result you see now!
                              d12dozr
                              Awesome effect...you have reflections going both ways ☀
                              http://goo.gl/f7ooYh
                              • olisheaO Offline
                                olishea
                                good topic pete, some lovely renders here. im cooking one now 😄
                                oli
                                • boofredlayB Offline
                                  boofredlay
                                  Respect Oli. This is my favorite so far.
                                  • jeff hammondJ Offline
                                    here's an iphone screenshot from the original post in this thread.. let me know if you want a different screenshot to use in your render 😄
                                    • olisheaO Offline
                                      olishea
                                      lol
                                      thanks eric.
                                      pete....what silver/chrome material did you use for the first render? looks very very nice...great lighting on that one. 👍
                                      oli
                                        Here's my attempt.....
                                        Twilight Easy 9 [5hrs Cooking]
                                        • olisheaO Offline
                                          olishea
                                          I got mugged by an iphone; lingering in this back alley:
                                          http://i654.photobucket.com/albums/uu269/olishea/final2-3.jpg
                                          twilight: fake emitter @ 100W, interior preset, studio hdri at 0.3 brightness (for fill light), sunlight disabled, rough stone template to concrete
                                          edit: a slightly different version
                                          http://i654.photobucket.com/albums/uu269/olishea/final3.jpg
                                          oli
                                          • dermotcollD Offline
                                            dermotcoll
                                            Oli
                                            wish I had the time to try this but too busy working to attempt these challenges at the minute - making mental notes on the tips though!!!
                                            BTW how did you manage to get an AT&T signal all the way over there in Manchester lad!!! I thought o2 was the only service provider in the UK for iphones!!!!
                                            When you burn your arse - you gotta sit on the blisters!!
                                            • 1 / 3
