    Render this: LCD screen (light emitting material)
    59 Posts 30 Posters 19.7k Views 30 Watching
    • jeff hammondJ
      here's an iphone screenshot from the original post in this thread.. let me know if you want a different screenshot to use in your render 😄
      • olisheaO
        olishea
        lol
        thanks eric.
        pete....what silver/chrome material did you use for the first render? looks very very nice...great lighting on that one. 👍
        oli
          Here's my attempt.....
          Twilight Easy 9 [5hrs Cooking]
          • olisheaO
            olishea
            I got mugged by an iphone; lingering in this back alley:
            http://i654.photobucket.com/albums/uu269/olishea/final2-3.jpg
            twilight: fake emitter @ 100W, interior preset, studio hdri at 0.3 brightness (for fill light), sunlight disabled, rough stone template to concrete
            edit: a slightly different version
            http://i654.photobucket.com/albums/uu269/olishea/final3.jpg
            oli
            • dermotcollD
              dermotcoll
              Oli
              wish I had the time to try this but too busy working to attempt these challenges at the minute - making mental notes on the tips though!!!
              BTW how did you manage to get an AT&T signal all the way over there in Manchester lad!!! I thought o2 was the only service provider in the UK for iphones!!!!
              When you burn your arse - you gotta sit on the blisters!!
              • olisheaO
                olishea
                keep making mental notes mate you'll be shit hot in no time! 👍
                oli
                • soloS
                  Oli, I used an Aluminum base, and tweaked it a little.
                  • olisheaO
                    olishea
                    cheers
                    oli
                    • Al HartA
                      Al Hart
                      @solo said:
                      Al Hart has a render tip floating around regarding back lighting, I thought we could expand on that slightly and have a challenge to render an IPhone, with an LCD screen.
                      There are a lot of great iPhone renders here in this thread and a lot of good lighting effects.
                      The original tip, though, was about using a non-light emitting, self-glow, material instead for the iPhone. This compromise will never produce as good a rendering as the actual illuminated iPhones, but it the phone itself is just an accessory, rather than the main object of the rendering, then it may speed up the rendering process by not including additional light sources.
                      Here are a couple of iPhones on a table - one is on and one is off.
                      (Their are no light sources in the phone - just a material marked as self illuminating)
                      Al Hart
                      IRender nXt from Render Plus
                      • FrederikF
                        Frederik
                        Although I can see there's a difference between the two phones, I can't tell which one is "on" and which one of them is "off"... 😐
                        @solo said:
                        I'd suggest a dark environment and maybe posing the phone in a way that the light can reflect on a surface
                        Cheers
                        Kim Frederik
                        • Al HartA
                          Al Hart
                          @frederik said:
                          It's a little tricky to make the image look lit-up, (I am trying to avoid putting actual lights behind it.)
                          One idea is to manipulate the original image, so that it looks more "lit-up" in the first place. I suppose the photo-shop experts could do this easily. It will be more tricky for a "Paint" novice like myself.
                          The other is to play with the "self glow" to increase the brightness of the image, without starting to make the black parts look lit up as well.
                          I'll see what I can do.
                          (Original image)
                          Al Hart
                          • olisheaO
                            olishea
                            great render escapeartist 😄
                            oli
                            • EarthMoverE
                              EarthMover
                              Honestly, I don't see the point. What really is to gain about trying a less effective way to achieve a desired result. I hate to say it, but it feels like there is an ulterior motive behind the render tip to draw attention to a feature of a developer's app. IMO, the light emitting textures have proven to be a more realistic result by looking at the posted renders.
                              Content Creator at Skapeup
                              • jeff hammondJ
                                i dunno, when my iphone is off, it's just a black screen.
                                • EscapeArtistE
                                  EscapeArtist
                                  Not sure what the distinction is that you are trying to make. In Kerkythea, the texture can be applied to the radiance (edit material > self illumination > and select bitmap and use the screen texture) function and the texture becomes "self illuminating", it is not a backlit texture.
                                  Here is a completely dark scene with only the screen applied to one surface, self illuminated:
                                  Or am I missing completely what you are trying to get at? Are you trying to achieve a similar effect, without applying self illumination of this type?
                                  • Al HartA
                                    Al Hart
                                    Oops - I guess U need to buy one.
                                    But - does it have a lit and non-lit mode?
                                    Al Hart
                                    • Al HartA
                                      Al Hart
                                      I think what you showed in your rendering is just what I am talking about. The ability to make something look illuminated, without using or adding any actual light sources to the scene.
                                      New light options including projector lights and manual inputs of light intensities for self luminating sources.
                                      I presume that in the image you showed, we see a reflection of the lit iPhone, but it is not actually a light source??
                                      Al Hart
                                      • jeff hammondJ
                                        no, it's just like a standard computer monitor.. on or off and that's it
                                        http://obsdesign.freznell.com/wp-content/uploads/2008/11/iphone-off.jpg
                                        • olisheaO
                                          olishea
                                          al: nobody said you cant make it an emitter.....there are many ways of doing this but its the most realistic way of achieving the result. you cant really make something look illuminated without showing its effect on neighbouring surfaces/particles (air/dust etc). correct me if i'm wrong. you are basically trying to make a texture look brighter which isn't convincing.
                                          why are you trying to avoid putting lights behind it? this is largely how screens are illuminated in real life. like a large emitter......again correct me if im wrong...but saturating and brightening a texture wont make it look illuminated.
                                          oli
                                          • EscapeArtistE
                                            EscapeArtist
                                            The texture itself is the source of light, there are no other lights whatsoever in the scene. The reflection on the surface below the screen is actually reflected light off of the ground plane. Kerkthea will create light based on the color of the image used - black, no light; green, green light, etc... Kerkythea does not do "light linking" (yet), where light can be shone on one object of the scene to make it brighter but not affect any other objects. Other render engines can do this though.
                                            One could put lights behind a texture, but I couldn't imagine the difficulty of getting nice, even light out of a large surface by arranging light sources behind it. It would be more involved setup in the render engine as well, you'd have to do something like a multi-layered texture with transparency mapping and translucency set up for the colors.
                                            Another example, this time the blacks are not completely black so they do emit some light. A quick "plasma TV".
                                            • 2 / 3
