    Render this: LCD screen (light emitting material)
    59 Posts 30 Posters 19.3k Views 30 Watching
      lexmonteiro
      This Is "TWiphone"!
      Twilight 6 minutes:
      • RichardR Offline
        Richard
        @stefanq said:
        V-ray renders, studio setup, I just used the same texture from diffuse, for the emissive layer of the v-ray material.
        http://img140.imageshack.us/img140/4426/iphone1z.jpg
        http://img685.imageshack.us/img685/805/iphone2d.jpg
        very nice!!!
        BUILTBRAND.COM.AU
        • EarthMoverE Offline
          EarthMover
          Finally had a few minutes to throw these into the mix. Great renders all the way around from everyone!
          Content Creator at Skapeup
          • N Offline
            notareal
            Adam, I like the composition of Iphone_LED2.jpg. Good looking materials, except there is something odd going with the table lamp; ceramic base has some material (or surface normal) problem with the grazing angle.
              EarthMover
              Thanks Notareal. I adjusted the material and got a better result. Also added an HDRI for fill light.
              • FrederikF Offline
                Frederik
                Excellent render, Adam... 👍
                What render app. did you use...??
                Cheers
                Kim Frederik
                  EarthMover
                  Thanks Kim. I used Vray for Max with the Solid Rocks plugin for render settings. Vray light material for the LCD.
                  • charly2008C Offline
                    charly2008
                    A quick Photon render with Kerkythea. Again something learned about emitting light. Thanks Pete
                    Karlheinz
                      lexmonteiro
                      If I may, I would like to try again.
                      I went to sleep last night thinking of a way to render as quickly as possible without light-emitting materials, and today I woke up and I had the idea to only using projectors, a thin glass to cover the screen, and most importantly, projector must coincides exactly with the image on the screen.
                      Then I looked at my clock alarm and I think that this may be interesting to show the reflection in the "thin glass" over the Iphone screen, how to do this too...? I put a red light iside the alarm and a red glass on the numbers, the result you see now!
                        d12dozr
                        Awesome effect...you have reflections going both ways ☀
                        http://goo.gl/f7ooYh
                        • olisheaO Offline
                          olishea
                          good topic pete, some lovely renders here. im cooking one now 😄
                          oli
                          • boofredlayB Offline
                            boofredlay
                            Respect Oli. This is my favorite so far.
                            • jeff hammondJ Offline
                              here's an iphone screenshot from the original post in this thread.. let me know if you want a different screenshot to use in your render 😄
                              • olisheaO Offline
                                olishea
                                lol
                                thanks eric.
                                pete....what silver/chrome material did you use for the first render? looks very very nice...great lighting on that one. 👍
                                oli
                                • Rich O BrienR Online
                                  Here's my attempt.....
                                  Twilight Easy 9 [5hrs Cooking]
                                  • olisheaO Offline
                                    olishea
                                    I got mugged by an iphone; lingering in this back alley:
                                    http://i654.photobucket.com/albums/uu269/olishea/final2-3.jpg
                                    twilight: fake emitter @ 100W, interior preset, studio hdri at 0.3 brightness (for fill light), sunlight disabled, rough stone template to concrete
                                    edit: a slightly different version
                                    http://i654.photobucket.com/albums/uu269/olishea/final3.jpg
                                    oli
                                    • dermotcollD Offline
                                      dermotcoll
                                      Oli
                                      wish I had the time to try this but too busy working to attempt these challenges at the minute - making mental notes on the tips though!!!
                                      BTW how did you manage to get an AT&T signal all the way over there in Manchester lad!!! I thought o2 was the only service provider in the UK for iphones!!!!
                                      When you burn your arse - you gotta sit on the blisters!!
                                      • olisheaO Offline
                                        olishea
                                        keep making mental notes mate you'll be shit hot in no time! 👍
                                        oli
                                        • soloS Offline
                                          Oli, I used an Aluminum base, and tweaked it a little.
                                          • olisheaO Offline
                                            olishea
                                            cheers
                                            oli
                                            • 2 / 3
