    Render this: LCD screen (light emitting material)
    59 Posts 30 Posters 19.7k Views 30 Watching
    • EarthMoverE
      EarthMover
      Finally had a few minutes to throw these into the mix. Great renders all the way around from everyone!
      Content Creator at Skapeup
      • N
        notareal
        Adam, I like the composition of Iphone_LED2.jpg. Good looking materials, except there is something odd going with the table lamp; ceramic base has some material (or surface normal) problem with the grazing angle.
        • EarthMoverE
          EarthMover
          Thanks Notareal. I adjusted the material and got a better result. Also added an HDRI for fill light.
          • FrederikF
            Frederik
            Excellent render, Adam... 👍
            What render app. did you use...??
            Cheers
            Kim Frederik
            • EarthMoverE
              EarthMover
              Thanks Kim. I used Vray for Max with the Solid Rocks plugin for render settings. Vray light material for the LCD.
              • charly2008C
                charly2008
                A quick Photon render with Kerkythea. Again something learned about emitting light. Thanks Pete
                Karlheinz
                • L
                  lexmonteiro
                  If I may, I would like to try again.
                  I went to sleep last night thinking of a way to render as quickly as possible without light-emitting materials, and today I woke up and I had the idea to only using projectors, a thin glass to cover the screen, and most importantly, projector must coincides exactly with the image on the screen.
                  Then I looked at my clock alarm and I think that this may be interesting to show the reflection in the "thin glass" over the Iphone screen, how to do this too...? I put a red light iside the alarm and a red glass on the numbers, the result you see now!
                    d12dozr
                    Awesome effect...you have reflections going both ways ☀
                    http://goo.gl/f7ooYh
                    • olisheaO
                      olishea
                      good topic pete, some lovely renders here. im cooking one now 😄
                      oli
                      • boofredlayB
                        boofredlay
                        Respect Oli. This is my favorite so far.
                        • jeff hammondJ
                          here's an iphone screenshot from the original post in this thread.. let me know if you want a different screenshot to use in your render 😄
                          • olisheaO
                            olishea
                            lol
                            thanks eric.
                            pete....what silver/chrome material did you use for the first render? looks very very nice...great lighting on that one. 👍
                            oli
                              Here's my attempt.....
                              Twilight Easy 9 [5hrs Cooking]
                              • olisheaO
                                olishea
                                I got mugged by an iphone; lingering in this back alley:
                                http://i654.photobucket.com/albums/uu269/olishea/final2-3.jpg
                                twilight: fake emitter @ 100W, interior preset, studio hdri at 0.3 brightness (for fill light), sunlight disabled, rough stone template to concrete
                                edit: a slightly different version
                                http://i654.photobucket.com/albums/uu269/olishea/final3.jpg
                                oli
                                • dermotcollD
                                  dermotcoll
                                  Oli
                                  wish I had the time to try this but too busy working to attempt these challenges at the minute - making mental notes on the tips though!!!
                                  BTW how did you manage to get an AT&T signal all the way over there in Manchester lad!!! I thought o2 was the only service provider in the UK for iphones!!!!
                                  When you burn your arse - you gotta sit on the blisters!!
                                  • olisheaO
                                    olishea
                                    keep making mental notes mate you'll be shit hot in no time! 👍
                                    oli
                                    • soloS
                                      Oli, I used an Aluminum base, and tweaked it a little.
                                      • olisheaO
                                        olishea
                                        cheers
                                        oli
                                        • Al HartA
                                          Al Hart
                                          @solo said:
                                          Al Hart has a render tip floating around regarding back lighting, I thought we could expand on that slightly and have a challenge to render an IPhone, with an LCD screen.
                                          There are a lot of great iPhone renders here in this thread and a lot of good lighting effects.
                                          The original tip, though, was about using a non-light emitting, self-glow, material instead for the iPhone. This compromise will never produce as good a rendering as the actual illuminated iPhones, but it the phone itself is just an accessory, rather than the main object of the rendering, then it may speed up the rendering process by not including additional light sources.
                                          Here are a couple of iPhones on a table - one is on and one is off.
                                          (Their are no light sources in the phone - just a material marked as self illuminating)
                                          Al Hart
                                          IRender nXt from Render Plus
                                          • FrederikF
                                            Frederik
                                            Although I can see there's a difference between the two phones, I can't tell which one is "on" and which one of them is "off"... 😐
                                            @solo said:
                                            I'd suggest a dark environment and maybe posing the phone in a way that the light can reflect on a surface
                                            Cheers
                                            Kim Frederik
                                            • 2 / 3
