    Render this: LCD screen (light emitting material)
    59 Posts 30 Posters 18.6k Views 30 Watching
    • boofredlayB Offline
      boofredlay
      Respect Oli. This is my favorite so far.
      • jeff hammondJ Offline
        here's an iphone screenshot from the original post in this thread.. let me know if you want a different screenshot to use in your render 😄
        • olisheaO Offline
          olishea
          lol
          thanks eric.
          pete....what silver/chrome material did you use for the first render? looks very very nice...great lighting on that one. 👍
          oli
            Here's my attempt.....
            Twilight Easy 9 [5hrs Cooking]
            • olisheaO Offline
              olishea
              I got mugged by an iphone; lingering in this back alley:
              http://i654.photobucket.com/albums/uu269/olishea/final2-3.jpg
              twilight: fake emitter @ 100W, interior preset, studio hdri at 0.3 brightness (for fill light), sunlight disabled, rough stone template to concrete
              edit: a slightly different version
              http://i654.photobucket.com/albums/uu269/olishea/final3.jpg
              oli
              • dermotcollD Offline
                dermotcoll
                Oli
                wish I had the time to try this but too busy working to attempt these challenges at the minute - making mental notes on the tips though!!!
                BTW how did you manage to get an AT&T signal all the way over there in Manchester lad!!! I thought o2 was the only service provider in the UK for iphones!!!!
                When you burn your arse - you gotta sit on the blisters!!
                • olisheaO Offline
                  olishea
                  keep making mental notes mate you'll be shit hot in no time! 👍
                  oli
                  • soloS Offline
                    Oli, I used an Aluminum base, and tweaked it a little.
                    • olisheaO Offline
                      olishea
                      cheers
                      oli
                      • Al HartA Offline
                        Al Hart
                        @solo said:
                        Al Hart has a render tip floating around regarding back lighting, I thought we could expand on that slightly and have a challenge to render an IPhone, with an LCD screen.
                        There are a lot of great iPhone renders here in this thread and a lot of good lighting effects.
                        The original tip, though, was about using a non-light emitting, self-glow, material instead for the iPhone. This compromise will never produce as good a rendering as the actual illuminated iPhones, but it the phone itself is just an accessory, rather than the main object of the rendering, then it may speed up the rendering process by not including additional light sources.
                        Here are a couple of iPhones on a table - one is on and one is off.
                        (Their are no light sources in the phone - just a material marked as self illuminating)
                        Al Hart
                        IRender nXt from Render Plus
                        • FrederikF Offline
                          Frederik
                          Although I can see there's a difference between the two phones, I can't tell which one is "on" and which one of them is "off"... 😐
                          @solo said:
                          I'd suggest a dark environment and maybe posing the phone in a way that the light can reflect on a surface
                          Cheers
                          Kim Frederik
                          • Al HartA Offline
                            Al Hart
                            @frederik said:
                            It's a little tricky to make the image look lit-up, (I am trying to avoid putting actual lights behind it.)
                            One idea is to manipulate the original image, so that it looks more "lit-up" in the first place. I suppose the photo-shop experts could do this easily. It will be more tricky for a "Paint" novice like myself.
                            The other is to play with the "self glow" to increase the brightness of the image, without starting to make the black parts look lit up as well.
                            I'll see what I can do.
                            (Original image)
                            Al Hart
                            • olisheaO Offline
                              olishea
                              great render escapeartist 😄
                              oli
                              • EarthMoverE Offline
                                EarthMover
                                Honestly, I don't see the point. What really is to gain about trying a less effective way to achieve a desired result. I hate to say it, but it feels like there is an ulterior motive behind the render tip to draw attention to a feature of a developer's app. IMO, the light emitting textures have proven to be a more realistic result by looking at the posted renders.
                                Content Creator at Skapeup
                                  i dunno, when my iphone is off, it's just a black screen.
                                  • EscapeArtistE Offline
                                    EscapeArtist
                                    Not sure what the distinction is that you are trying to make. In Kerkythea, the texture can be applied to the radiance (edit material > self illumination > and select bitmap and use the screen texture) function and the texture becomes "self illuminating", it is not a backlit texture.
                                    Here is a completely dark scene with only the screen applied to one surface, self illuminated:
                                    Or am I missing completely what you are trying to get at? Are you trying to achieve a similar effect, without applying self illumination of this type?
                                    • Al HartA Offline
                                      Al Hart
                                      Oops - I guess U need to buy one.
                                      But - does it have a lit and non-lit mode?
                                      Al Hart
                                      • Al HartA Offline
                                        Al Hart
                                        I think what you showed in your rendering is just what I am talking about. The ability to make something look illuminated, without using or adding any actual light sources to the scene.
                                        New light options including projector lights and manual inputs of light intensities for self luminating sources.
                                        I presume that in the image you showed, we see a reflection of the lit iPhone, but it is not actually a light source??
                                        Al Hart
                                          no, it's just like a standard computer monitor.. on or off and that's it
                                          http://obsdesign.freznell.com/wp-content/uploads/2008/11/iphone-off.jpg
                                          • olisheaO Offline
                                            olishea
                                            al: nobody said you cant make it an emitter.....there are many ways of doing this but its the most realistic way of achieving the result. you cant really make something look illuminated without showing its effect on neighbouring surfaces/particles (air/dust etc). correct me if i'm wrong. you are basically trying to make a texture look brighter which isn't convincing.
                                            why are you trying to avoid putting lights behind it? this is largely how screens are illuminated in real life. like a large emitter......again correct me if im wrong...but saturating and brightening a texture wont make it look illuminated.
                                            oli
                                            • 2 / 3
