    [Plugin] Flatten and Extrude
    46 Posts 11 Posters 44.1k Views 11 Watching
      Ok - but how does that relate to this plugin? (I'm confused...)
        I surmise he means instead of flattening everything to z-o allow you to set it to flatten to z=123.456m. Easy done as it's in a group - flatten all to z=0 end with an option to enter a new z or pick a point and move the flattened group up/down to suit the desired z ???
          That would move the top above the lines it extrudes up to. But it's just as easy to just to flatten down to a given Z level.
          Anyway - thanks for clearing that up. Will see if I'll be adding that in the future.
          Btw, does your Z-Level plugin expose the Z Height publicly? Wondering if I can read the value and use that as default if present.
            Frankly I'd keep them separate...
              Flat land πŸ˜‰
                Flat land πŸ˜‰
                Someone's been snooping in the code, eh? πŸ˜„ It just so happened to be the last book I read. πŸ€“
                • K
                  kwistenbiebel
                  Nice idea thomthom. Things are busy now, but I will try the plugin in depth at the weekend.
                  For architects this is extremely useful!
                  Now I don't have to ask the Rhino guy to do it for me and to import it in SU πŸ˜‰
                  By the way,
                  I love the CookieWare idea! Whenever you're in Australia, please drop by for a beer... πŸ˜„
                    dtrarch
                    I yield πŸ‘Š
                    Just thought that muli-level flat and extrude might be a possible for structural elements and such.
                    tt many thanks in any case β˜€
                    dtr
                    • utilerU
                      utiler
                      By the way,
                      Some nice boutique breweries over there, kwist......
                      After you've had a few beers with kwist, Thom fly across the other side of the country and I'll shout you a few also!!! πŸ‘
                      Just Curious...
                        Rhino has a function like this??
                          @dtrarch said:
                          I yield πŸ‘Š
                          dtr
                          Multi-level flat and extrude? Could you care to explain more what you got in mind?
                          • G
                            gavvy
                            πŸ˜’
                            I tride this plugin .The groups in the group can't be faltten
                            Is it a better idea to flatten the group in group,and hold the group of faces?
                            to build a city ,i always use clf_greeble_2.rb πŸ˜„
                              Currently it doesn't dig into nested groups. It only works on the edges directly inside the selected group/component.
                              Will change that later.
                              • G
                                gavvy
                                πŸ˜„
                                zorro tool is a good EXAMPLE
                                • GaieusG
                                  Hm. My city has just stopped at 31% (and SU is unresponsive). But I gues there are limitations also (file size and edge count) so maybe I shouldn't be so eager and clean the file up a bit before I try.
                                  πŸ˜‰
                                    πŸ˜‰
                                    Can you send me the model for debugging?
                                      dtrarch
                                      TT
                                      It seemed useful to be able to flatten selected objects (groups components etc) to adjusted (TIG's)heights above default Z height zero.
                                      Then select and extrude +/- as wanted.
                                      A multi-Z height selection.
                                      Just an idea for consideration.
                                      dtr
                                        Been trying to find a way to triangulate Roofs from 3d plans. Will never be perfect, but "good enough" to do the bulk work and get a rough idea of the shape.
                                        Think the name of this plugin isn't fitting any more. It's doing much more building than flattening. "BuildUp"?
                                        • GaieusG
                                          @thomthom said:
                                          ...Can you send me the model for debugging?
                                          Sure - see your PM (when I finish this post). But in fact, the file is still a mess as everything is connected with everything (street ends for instance are "closed") and also it's a rather large piece of the city (and where I cut it out from the whole city plan, there are a bunch of open ends, too) so no wonder it didn't really work.
                                          Wherever I cleaned up a bit and grouped separately, it worked just fine.
                                          • GaieusG
                                            And the roofing also looks promising!
                                            πŸ˜‰
                                            • 1 / 3
