    [Plugin] Flatten and Extrude
    46 Posts 11 Posters 42.1k Views 11 Watching
      No worries! πŸ˜„ πŸ˜‰
        dtrarch
        TT
        How about using TIG's Height/datum tool to set Z with your new tool.
        Hmmm?
        dtr
          @dtrarch said:
          TT
          Hmmm?
          dtr
          Set Z? What you mean?
            My Datum tool sets a 'Z' datum in your model [as an attribute] so when z=0 z_datum=123.456m or whatever. Then you use the tool to add text to refer to a point so that floors or points on an elevation etc are given their corrected height above 'datum', rather than z=0...
              Ok - but how does that relate to this plugin? (I'm confused...)
                I surmise he means instead of flattening everything to z-o allow you to set it to flatten to z=123.456m. Easy done as it's in a group - flatten all to z=0 end with an option to enter a new z or pick a point and move the flattened group up/down to suit the desired z ???
                  That would move the top above the lines it extrudes up to. But it's just as easy to just to flatten down to a given Z level.
                  Anyway - thanks for clearing that up. Will see if I'll be adding that in the future.
                  Btw, does your Z-Level plugin expose the Z Height publicly? Wondering if I can read the value and use that as default if present.
                    Frankly I'd keep them separate...
                      Flat land πŸ˜‰
                        Flat land πŸ˜‰
                        Someone's been snooping in the code, eh? πŸ˜„ It just so happened to be the last book I read. πŸ€“
                          kwistenbiebel
                          Nice idea thomthom. Things are busy now, but I will try the plugin in depth at the weekend.
                          For architects this is extremely useful!
                          Now I don't have to ask the Rhino guy to do it for me and to import it in SU πŸ˜‰
                          By the way,
                          I love the CookieWare idea! Whenever you're in Australia, please drop by for a beer... πŸ˜„
                            dtrarch
                            I yield πŸ‘Š
                            Just thought that muli-level flat and extrude might be a possible for structural elements and such.
                            tt many thanks in any case β˜€
                            dtr
                            • utilerU Offline
                              utiler
                              By the way,
                              Some nice boutique breweries over there, kwist......
                              After you've had a few beers with kwist, Thom fly across the other side of the country and I'll shout you a few also!!! πŸ‘
                              Just Curious...
                                Rhino has a function like this??
                                  @dtrarch said:
                                  I yield πŸ‘Š
                                  dtr
                                  Multi-level flat and extrude? Could you care to explain more what you got in mind?
                                    gavvy
                                    πŸ˜’
                                    I tride this plugin .The groups in the group can't be faltten
                                    Is it a better idea to flatten the group in group,and hold the group of faces?
                                    to build a city ,i always use clf_greeble_2.rb πŸ˜„
                                      Currently it doesn't dig into nested groups. It only works on the edges directly inside the selected group/component.
                                      Will change that later.
                                        gavvy
                                        πŸ˜„
                                        zorro tool is a good EXAMPLE
                                          Hm. My city has just stopped at 31% (and SU is unresponsive). But I gues there are limitations also (file size and edge count) so maybe I shouldn't be so eager and clean the file up a bit before I try.
                                          πŸ˜‰
                                            πŸ˜‰
                                            Can you send me the model for debugging?
                                            • 1 / 3
