    [Plugin] Flatten and Extrude
    46 Posts 11 Posters 44.1k Views 11 Watching
      My Datum tool sets a 'Z' datum in your model [as an attribute] so when z=0 z_datum=123.456m or whatever. Then you use the tool to add text to refer to a point so that floors or points on an elevation etc are given their corrected height above 'datum', rather than z=0...
        Ok - but how does that relate to this plugin? (I'm confused...)
          I surmise he means instead of flattening everything to z-o allow you to set it to flatten to z=123.456m. Easy done as it's in a group - flatten all to z=0 end with an option to enter a new z or pick a point and move the flattened group up/down to suit the desired z ???
            That would move the top above the lines it extrudes up to. But it's just as easy to just to flatten down to a given Z level.
            Anyway - thanks for clearing that up. Will see if I'll be adding that in the future.
            Btw, does your Z-Level plugin expose the Z Height publicly? Wondering if I can read the value and use that as default if present.
              Frankly I'd keep them separate...
                Flat land πŸ˜‰
                  Flat land πŸ˜‰
                  Someone's been snooping in the code, eh? πŸ˜„ It just so happened to be the last book I read. πŸ€“
                  • K
                    kwistenbiebel
                    Nice idea thomthom. Things are busy now, but I will try the plugin in depth at the weekend.
                    For architects this is extremely useful!
                    Now I don't have to ask the Rhino guy to do it for me and to import it in SU πŸ˜‰
                    By the way,
                    I love the CookieWare idea! Whenever you're in Australia, please drop by for a beer... πŸ˜„
                      dtrarch
                      I yield πŸ‘Š
                      Just thought that muli-level flat and extrude might be a possible for structural elements and such.
                      tt many thanks in any case β˜€
                      dtr
                      • utilerU
                        utiler
                        By the way,
                        Some nice boutique breweries over there, kwist......
                        After you've had a few beers with kwist, Thom fly across the other side of the country and I'll shout you a few also!!! πŸ‘
                        Just Curious...
                          Rhino has a function like this??
                            @dtrarch said:
                            I yield πŸ‘Š
                            dtr
                            Multi-level flat and extrude? Could you care to explain more what you got in mind?
                            • G
                              gavvy
                              πŸ˜’
                              I tride this plugin .The groups in the group can't be faltten
                              Is it a better idea to flatten the group in group,and hold the group of faces?
                              to build a city ,i always use clf_greeble_2.rb πŸ˜„
                                Currently it doesn't dig into nested groups. It only works on the edges directly inside the selected group/component.
                                Will change that later.
                                • G
                                  gavvy
                                  πŸ˜„
                                  zorro tool is a good EXAMPLE
                                  • GaieusG
                                    Hm. My city has just stopped at 31% (and SU is unresponsive). But I gues there are limitations also (file size and edge count) so maybe I shouldn't be so eager and clean the file up a bit before I try.
                                    πŸ˜‰
                                      πŸ˜‰
                                      Can you send me the model for debugging?
                                        dtrarch
                                        TT
                                        It seemed useful to be able to flatten selected objects (groups components etc) to adjusted (TIG's)heights above default Z height zero.
                                        Then select and extrude +/- as wanted.
                                        A multi-Z height selection.
                                        Just an idea for consideration.
                                        dtr
                                          Been trying to find a way to triangulate Roofs from 3d plans. Will never be perfect, but "good enough" to do the bulk work and get a rough idea of the shape.
                                          Think the name of this plugin isn't fitting any more. It's doing much more building than flattening. "BuildUp"?
                                          • GaieusG
                                            @thomthom said:
                                            ...Can you send me the model for debugging?
                                            Sure - see your PM (when I finish this post). But in fact, the file is still a mess as everything is connected with everything (street ends for instance are "closed") and also it's a rather large piece of the city (and where I cut it out from the whole city plan, there are a bunch of open ends, too) so no wonder it didn't really work.
                                            Wherever I cleaned up a bit and grouped separately, it worked just fine.
                                            • 1 / 3
