    Updated version of Draw Metal plugins
    25 Posts 14 Posters 5.3k Views 14 Watching
    • JClementsJ
      JClements
      The Cornu function looks like it could be very useful.
      • massimoM
        massimo Moderator
        Hi Terry, your plugin is really good thanks. It works well, but i've noticed a strange thing. In SU6 free when i do right click on a face i had this:
        Error: #<NoMethodError: undefined method active_path' for #<Sketchup::Model:0x879db90>> (eval):3406:in valid_group?'
        (eval):3458:in selected_stuff' C:/Programmi/Google/Google SketchUp 6/Plugins/ctsMaker/curve_menu.rb:46 C:/Programmi/Google/Google SketchUp 6/Plugins/ctsMaker/curve_menu.rb:45:in call'
        I've tried it on SU7 pro (with no other plugin installed) and no error message.
        Maybe a plugin conflict?
        Massimo
        • Didier BurD
          Didier Bur
          active_path is a "SU7 only" method.
          As the author says:
          SketchUp 7 is required to use the new interactive features.
          DB
          • massimoM
            massimo Moderator
            Oh... sorry, thanks Didier
              max-cx
              Fredo -
              One question: do you know if mathematically you can extend the Cornu curve to a suite of control points in 3D space (i.e. not in a plane)?
              Sorry to be slow in responding. The mathematical extension to 3D is discussed in Chapter 11 of Raph Levien's forthcoming PhD thesis (http://levien.com/phd/thesis.pdf). That does not imply, however, that I will be programming such an extension.
              Terry
              http://www.drawmetal.com
              • I
                IAGDint
                Your great.
                This is a very useful tool.
                Thanks.
                Cheers.
                • E
                  Efrado
                  Indeed It is a great plugin,THANKS.But I get trouble with the icons, does not show ,only the blanks.I use Mac 😞
                  • jeff hammondJ
                    this plugin doesn't have any icons (at least no toolbar icons which i think you're talking about).. it's functions are accessible via the plugins menu -> curve maker
                    maybe your blank icons are from a different plugin?
                      max-cx
                      So far, the only time the toolbar icons have not worked is when they had not been installed in the right place in the file hierarchy. After installation, the file hierarchy for the plugin should appear as shown in this figure.
                      toolbar_installed.pdf
                      Terry
                      • jeff hammondJ
                        well in that case, i think the icons are missing from the mac zip package.. i'll check the dmg
                        • jeff hammondJ
                          this is after a straight install from the mac zip..
                          • jeff hammondJ
                            haha, ok.. 😳
                            i guess i have to keep reading the page in order to find the optional toolbar...
                            ok, back to watching the latest episode of short attention span theater πŸ˜„
                            • E
                              Efrado
                              Thanks Terry, πŸ‘ I found the misplacing.Now I am going to trying something.
                              Hi Jeff,hapy to see you have the icons too.thanks for your reply πŸ˜„
                              • ken28875K
                                ken28875
                                Hi Terry,
                                I have been using that plugin and it is awesome. I just downloaded the updaded version and ran into some problems.
                                I have this error message.
                                http://i593.photobucket.com/albums/tt12/ken28875/error_message_curve_maker.jpg
                                I see the plugin and everything, but when i click on what i want to do (e.g. draw a taper) nothing happens.
                                Thank you for your help,
                                _KN
                                Follow Your Dreams.
                                • ken28875K
                                  ken28875
                                  Never mind. I figured out. I put the files in the wrong folder. lol
                                  thank you.
                                  Follow Your Dreams.
