    Updated version of Draw Metal plugins
    25 Posts 14 Posters 5.1k Views 14 Watching
      Nice plug indeed 😎
        Thank you very kindly for that. My ears appreciate it.
          max-cx
          OK, the irritating sound mystery is solved.
          Some example code I had used featured a UI.beep which I had not noticed, and the machines I use have the alert sound muted.
          I have updated the download code at: http://www.drawmetal.com/download
          Sorry for the inconvenience.
          Terry
          • Bob JamesB Offline
            Bob James
            Amen
            • fredo6F Offline
              Terry,
              Very impressed by this suite of tools. Great job and very neat programming!
              One question: do you know if mathematically you can extend the Cornu curve to a suite of control points in 3D space (i.e. not in a plane)?
              • JClementsJ Offline
                JClements
                The Cornu function looks like it could be very useful.
                • massimoM Offline
                  massimo Moderator
                  Hi Terry, your plugin is really good thanks. It works well, but i've noticed a strange thing. In SU6 free when i do right click on a face i had this:
                  Error: #<NoMethodError: undefined method active_path' for #<Sketchup::Model:0x879db90>> (eval):3406:in valid_group?'
                  (eval):3458:in selected_stuff' C:/Programmi/Google/Google SketchUp 6/Plugins/ctsMaker/curve_menu.rb:46 C:/Programmi/Google/Google SketchUp 6/Plugins/ctsMaker/curve_menu.rb:45:in call'
                  I've tried it on SU7 pro (with no other plugin installed) and no error message.
                  Maybe a plugin conflict?
                  Massimo
                  • Didier BurD Offline
                    Didier Bur
                    active_path is a "SU7 only" method.
                    As the author says:
                    SketchUp 7 is required to use the new interactive features.
                    DB
                    • massimoM Offline
                      massimo Moderator
                      Oh... sorry, thanks Didier
                        max-cx
                        Fredo -
                        Sorry to be slow in responding. The mathematical extension to 3D is discussed in Chapter 11 of Raph Levien's forthcoming PhD thesis (http://levien.com/phd/thesis.pdf). That does not imply, however, that I will be programming such an extension.
                        Terry
                        • I Offline
                          IAGDint
                          Your great.
                          This is a very useful tool.
                          Thanks.
                          Cheers.
                          • E Offline
                            Efrado
                            Indeed It is a great plugin,THANKS.But I get trouble with the icons, does not show ,only the blanks.I use Mac 😞
                            • jeff hammondJ Offline
                              this plugin doesn't have any icons (at least no toolbar icons which i think you're talking about).. it's functions are accessible via the plugins menu -> curve maker
                              maybe your blank icons are from a different plugin?
                                max-cx
                                So far, the only time the toolbar icons have not worked is when they had not been installed in the right place in the file hierarchy. After installation, the file hierarchy for the plugin should appear as shown in this figure.
                                toolbar_installed.pdf
                                Terry
                                  well in that case, i think the icons are missing from the mac zip package.. i'll check the dmg
                                    this is after a straight install from the mac zip..
                                      haha, ok.. 😳
                                      i guess i have to keep reading the page in order to find the optional toolbar...
                                      ok, back to watching the latest episode of short attention span theater πŸ˜„
                                      • E Offline
                                        Efrado
                                        Thanks Terry, πŸ‘ I found the misplacing.Now I am going to trying something.
                                        Hi Jeff,hapy to see you have the icons too.thanks for your reply πŸ˜„
                                        • ken28875K Offline
                                          ken28875
                                          Hi Terry,
                                          I have been using that plugin and it is awesome. I just downloaded the updaded version and ran into some problems.
                                          I have this error message.
                                          http://i593.photobucket.com/albums/tt12/ken28875/error_message_curve_maker.jpg
                                          I see the plugin and everything, but when i click on what i want to do (e.g. draw a taper) nothing happens.
                                          Thank you for your help,
                                          _KN
                                          Follow Your Dreams.
                                          • ken28875K Offline
                                            ken28875
                                            Never mind. I figured out. I put the files in the wrong folder. lol
                                            thank you.
                                            Follow Your Dreams.
