    Updated version of Draw Metal plugins
    25 Posts 14 Posters 4.7k Views 14 Watching
      max-cx
      Dave -
      Thanks for reporting this problem. There is nothing in my code that wants or seeks to make a sound, and it doesn't happen on my machine. Let me see what I can find.
      Terry
      Terry
      http://www.drawmetal.com
        Jim
        @dave r said:
        This is great Terry. thank you. Any chance of getting rid of the sounds? So far I haven't seen anything that requires the sound and it occurs during operations such as right clicking on a curve before editing it.
        The housebuilder plugin is one that is known to cause sounds. Temporarily disabled it and see if that helps.
          Nice plug indeed 😎
            Thank you very kindly for that. My ears appreciate it.
              max-cx
              OK, the irritating sound mystery is solved.
              Some example code I had used featured a UI.beep which I had not noticed, and the machines I use have the alert sound muted.
              I have updated the download code at: http://www.drawmetal.com/download
              Sorry for the inconvenience.
              Terry
              • Bob JamesB Offline
                Bob James
                Amen
                • fredo6F Offline
                  Terry,
                  Very impressed by this suite of tools. Great job and very neat programming!
                  One question: do you know if mathematically you can extend the Cornu curve to a suite of control points in 3D space (i.e. not in a plane)?
                  • JClementsJ Offline
                    JClements
                    The Cornu function looks like it could be very useful.
                    • massimoM Offline
                      massimo Moderator
                      Hi Terry, your plugin is really good thanks. It works well, but i've noticed a strange thing. In SU6 free when i do right click on a face i had this:
                      Error: #<NoMethodError: undefined method active_path' for #<Sketchup::Model:0x879db90>> (eval):3406:in valid_group?'
                      (eval):3458:in selected_stuff' C:/Programmi/Google/Google SketchUp 6/Plugins/ctsMaker/curve_menu.rb:46 C:/Programmi/Google/Google SketchUp 6/Plugins/ctsMaker/curve_menu.rb:45:in call'
                      I've tried it on SU7 pro (with no other plugin installed) and no error message.
                      Maybe a plugin conflict?
                      Massimo
                      • Didier BurD Offline
                        Didier Bur
                        active_path is a "SU7 only" method.
                        As the author says:
                        SketchUp 7 is required to use the new interactive features.
                        DB
                        • massimoM Offline
                          massimo Moderator
                          Oh... sorry, thanks Didier
                            max-cx
                            Fredo -
                            Sorry to be slow in responding. The mathematical extension to 3D is discussed in Chapter 11 of Raph Levien's forthcoming PhD thesis (http://levien.com/phd/thesis.pdf). That does not imply, however, that I will be programming such an extension.
                            Terry
                            • I Offline
                              IAGDint
                              Your great.
                              This is a very useful tool.
                              Thanks.
                              Cheers.
                              • E Offline
                                Efrado
                                Indeed It is a great plugin,THANKS.But I get trouble with the icons, does not show ,only the blanks.I use Mac 😞
                                • jeff hammondJ Offline
                                  this plugin doesn't have any icons (at least no toolbar icons which i think you're talking about).. it's functions are accessible via the plugins menu -> curve maker
                                  maybe your blank icons are from a different plugin?
                                    max-cx
                                    So far, the only time the toolbar icons have not worked is when they had not been installed in the right place in the file hierarchy. After installation, the file hierarchy for the plugin should appear as shown in this figure.
                                    toolbar_installed.pdf
                                    Terry
                                      well in that case, i think the icons are missing from the mac zip package.. i'll check the dmg
                                        this is after a straight install from the mac zip..
                                          haha, ok.. 😳
                                          i guess i have to keep reading the page in order to find the optional toolbar...
                                          ok, back to watching the latest episode of short attention span theater πŸ˜„
                                          • E Offline
                                            Efrado
                                            Thanks Terry, πŸ‘ I found the misplacing.Now I am going to trying something.
                                            Hi Jeff,hapy to see you have the icons too.thanks for your reply πŸ˜„
