    Updated version of Draw Metal plugins
    25 Posts 14 Posters 5.1k Views 14 Watching
      max-cx
      OK, the irritating sound mystery is solved.
      Some example code I had used featured a UI.beep which I had not noticed, and the machines I use have the alert sound muted.
      I have updated the download code at: http://www.drawmetal.com/download
      Sorry for the inconvenience.
      Terry
      • Bob JamesB Offline
        Bob James
        @dave r said:
        Thank you very kindly for that. My ears appreciate it.
        Amen
        • fredo6F Offline
          Terry,
          Very impressed by this suite of tools. Great job and very neat programming!
          One question: do you know if mathematically you can extend the Cornu curve to a suite of control points in 3D space (i.e. not in a plane)?
          • JClementsJ Offline
            JClements
            The Cornu function looks like it could be very useful.
            • massimoM Offline
              massimo Moderator
              Hi Terry, your plugin is really good thanks. It works well, but i've noticed a strange thing. In SU6 free when i do right click on a face i had this:
              Error: #<NoMethodError: undefined method active_path' for #<Sketchup::Model:0x879db90>> (eval):3406:in valid_group?'
              (eval):3458:in selected_stuff' C:/Programmi/Google/Google SketchUp 6/Plugins/ctsMaker/curve_menu.rb:46 C:/Programmi/Google/Google SketchUp 6/Plugins/ctsMaker/curve_menu.rb:45:in call'
              I've tried it on SU7 pro (with no other plugin installed) and no error message.
              Maybe a plugin conflict?
              Massimo
              • Didier BurD Offline
                Didier Bur
                active_path is a "SU7 only" method.
                As the author says:
                SketchUp 7 is required to use the new interactive features.
                DB
                • massimoM Offline
                  massimo Moderator
                  Oh... sorry, thanks Didier
                    max-cx
                    Fredo -
                    Sorry to be slow in responding. The mathematical extension to 3D is discussed in Chapter 11 of Raph Levien's forthcoming PhD thesis (http://levien.com/phd/thesis.pdf). That does not imply, however, that I will be programming such an extension.
                    Terry
                    • I Offline
                      IAGDint
                      Your great.
                      This is a very useful tool.
                      Thanks.
                      Cheers.
                      • E Offline
                        Efrado
                        Indeed It is a great plugin,THANKS.But I get trouble with the icons, does not show ,only the blanks.I use Mac 😞
                        • jeff hammondJ Offline
                          this plugin doesn't have any icons (at least no toolbar icons which i think you're talking about).. it's functions are accessible via the plugins menu -> curve maker
                          maybe your blank icons are from a different plugin?
                            max-cx
                            So far, the only time the toolbar icons have not worked is when they had not been installed in the right place in the file hierarchy. After installation, the file hierarchy for the plugin should appear as shown in this figure.
                            toolbar_installed.pdf
                            Terry
                              well in that case, i think the icons are missing from the mac zip package.. i'll check the dmg
                                this is after a straight install from the mac zip..
                                  haha, ok.. 😳
                                  i guess i have to keep reading the page in order to find the optional toolbar...
                                  ok, back to watching the latest episode of short attention span theater πŸ˜„
                                  • E Offline
                                    Efrado
                                    Thanks Terry, πŸ‘ I found the misplacing.Now I am going to trying something.
                                    Hi Jeff,hapy to see you have the icons too.thanks for your reply πŸ˜„
                                    • ken28875K Offline
                                      ken28875
                                      Hi Terry,
                                      I have been using that plugin and it is awesome. I just downloaded the updaded version and ran into some problems.
                                      I have this error message.
                                      http://i593.photobucket.com/albums/tt12/ken28875/error_message_curve_maker.jpg
                                      I see the plugin and everything, but when i click on what i want to do (e.g. draw a taper) nothing happens.
                                      Thank you for your help,
                                      _KN
                                      Follow Your Dreams.
                                      • ken28875K Offline
                                        ken28875
                                        Never mind. I figured out. I put the files in the wrong folder. lol
                                        thank you.
                                        Follow Your Dreams.
