    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • Jean-FrancoJ
      Jean-Franco
      Dear Olivier,
      you can find a collection of plugins here: http://forums.sketchucation.com/viewtopic.php?f=180&t=10142
      They are sorted in a way you should understand easily.
      And you can also have a look at there: http://www.sketchucation.com/extensions-index/
      Jean-Franco
      • fredo6F
        Escargot,
        Pas d'affichage. C'est juste une librairie de code Ruby commune a certains de mes scripts, le premier de cette famille etant FreeScale.
        • fredo6F
          NEW VERSION 3.3a - 27 Aug 09
          Needed for for RoundCorner 2.1, GhostComp 1.0 (and compatible for FredoScale and HoverSelect).
          Small evolutions (some for Palettes), bug fixing, ...
          see main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
          • fredo6F
            NEW VERSION 3.4a - 17 Sep 09
            Needed for Tools On Surface v1.5 (and compatible for FredoScale, RoundCorner 2.1, GhostComp 1.0 and HoverSelect).
            Small evolutions (mainly for Palettes), bug fixing, ...
            • N
              notareal
              • Bob JamesB
                Bob James
                Fredo Tools alive and well on MacPro/Leopard (Tools on Surface, Round Corner, Joint Push-Pull)
                • fredo6F
                  [Upgrade 08 Oct 09] LibFredo6 3.4b
                  Complement of Plugin translation to Spanish by Gaonirico (previous was done by Pichuneke).
                  See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=17947#p144178
                    SimonSTJ
                    whwrw can I find (download libfredo6 3.3a or higher..?
                      SimonSTJ
                      @massimo said:
                      I have deleted LibFredo6_Dir_32 and, after a quick test, RoundCorner and FredoScale seem to work fine. Thanks. πŸ˜„
                      Hi.. Can you tell me where can I find libfredo6 3.3a or higher..?
                      • massimoM
                        massimo Moderator
                        Hi Simon, go to the bottom of the very first post of this thread. You will find something like this...(see below)
                          SimonSTJ
                          Thanks.. I've been doing that for the las 2 days hoping that I'll find something like that.
                          Thank you again..I'll try to install it right now and if I have any problems I'll wright to you again.. πŸ˜„
                          • fredo6F
                            Update 20 Oct 09 - Documentation available in French, thanks to Jean-Franco.
                            See main post http://forums.sketchucation.com/viewtopic.php?f=180&t=17947#p144178
                              avya
                              thanks πŸ‘
                                arturmercurio
                                Great work! amazing just perfect. my best regards.
                                http://www.arturcarvalho.me/
                                • fredo6F
                                  [Chinese version - 11 Nov 09 - 21:50 CET
                                  Diweiman and the SuBAR_CLT team at SketchupBar have translated the script into Chinese.
                                  See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=17947&p=144178#p144178).
                                  • B
                                    blammas
                                    Is this compatible with windows 7? It doesn't show up in the folder once extracted...
                                      works fine on my windows7. But I have the UAC diabled, maybe that makes a difference.... Think there was an issue on Vista where files some times ended up in a compatibility folder...
                                      • K
                                        Khai
                                        ok.. installed the Library to my new SU install and on starting SU I just get a load of Load Errors:
                                        Error Loading File D:/7500 Modeling Apps/Google/Google Sketchup 7/plugins/LIBFREDO6_Dir_34/lib6config/tb uninitalized constant Traductor::T6
                                        etc etc (list goes on...)
                                        Edit ok - found it was an issue with Smustards Plugin organiser.
                                        • P
                                          pcrego
                                          I am trying to download Round Corner but it says I am not authorized to do so.. Any help please?
                                          • Q
                                            qiujie19
                                            great i need the chinese version
                                            • 115
                                            • 116
                                            • 4 / 116
