    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 586 Posters 10.8m Views 588 Watching
    • massimoM
      massimo Moderator
      Hi Simon, go to the bottom of the very first post of this thread. You will find something like this...(see below)
        SimonSTJ
        Thanks.. I've been doing that for the las 2 days hoping that I'll find something like that.
        Thank you again..I'll try to install it right now and if I have any problems I'll wright to you again.. πŸ˜„
        • fredo6F
          Update 20 Oct 09 - Documentation available in French, thanks to Jean-Franco.
          See main post http://forums.sketchucation.com/viewtopic.php?f=180&t=17947#p144178
            avya
            thanks πŸ‘
              arturmercurio
              Great work! amazing just perfect. my best regards.
              http://www.arturcarvalho.me/
              • fredo6F
                [Chinese version - 11 Nov 09 - 21:50 CET
                Diweiman and the SuBAR_CLT team at SketchupBar have translated the script into Chinese.
                See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=17947&p=144178#p144178).
                • B
                  blammas
                  Is this compatible with windows 7? It doesn't show up in the folder once extracted...
                    works fine on my windows7. But I have the UAC diabled, maybe that makes a difference.... Think there was an issue on Vista where files some times ended up in a compatibility folder...
                    • K
                      Khai
                      ok.. installed the Library to my new SU install and on starting SU I just get a load of Load Errors:
                      Error Loading File D:/7500 Modeling Apps/Google/Google Sketchup 7/plugins/LIBFREDO6_Dir_34/lib6config/tb uninitalized constant Traductor::T6
                      etc etc (list goes on...)
                      Edit ok - found it was an issue with Smustards Plugin organiser.
                      • P
                        pcrego
                        I am trying to download Round Corner but it says I am not authorized to do so.. Any help please?
                        • Q
                          qiujie19
                          great i need the chinese version
                          • cherokee_roC
                            cherokee_ro
                            hi, i'm getting an error like this : "uninitialized constant LibFredo6::Traductor" i installed the last version of libfredo6...anybidy knows why?
                              davidgold
                              have installed v3.4b will not show up in sketchup. Have deleted and re-downloaded, unzipped etc several times...any clues?
                              Running xp sketchup 7pro
                              • fredo6F
                                Did you install one of my plugin (FredoScale, Roundcorner). LibFredo6 alone is not doing anything. It is just a shared library.
                                  davidgold1
                                  downloaded LibFredo6 .Winrar says system cannot find path specified,,c/prog files/google/sketchup7/plugins. what could be the problem here? Would the fact that i have 2 comptrs one xp and one vista be a problem? i.e. while dnlding to vista machine is it trying to accomodate xp machine....please help. And which additional files are actually required to get it working...i successfully extracted files to xp machine, but nothing shows up within sketchup. (these may be dumb questions but i am a bit dumb)
                                    Rick Zook
                                    I've dowloaded the LibFredo6 3.4 into the plugins folder and unzipped it.
                                    Everything is there per the instructions (pdf). When I open SU the LibFredo6 doesn't show in the Windows menu.
                                    What am I doing wrong?
                                    Thanks,
                                    -Zook
                                    • fredo6F
                                      Thanks,
                                      -Zook
                                      LibFredo6 does not do anything 'alone'. It is only activated when my other scripts are used (like FredoScale, RoundCorner, etc...). Actually, LibFredo6 does not even load if not invoked from my other scripts (so it does preserve memory).
                                      Thanks to confirm that you did (or did not)install any other script along with LibFredo6.
                                      • P
                                        pepijn korner
                                        where can i download this fabulous plug in πŸ˜„?
                                          romain210
                                          thank you fredo
                                          vive la france
                                            affyx
                                            Thnk you fredo - you have saved me countless hours! I would like to make a paypal donation to your continued efforts - anyone know how?
                                            • 113
                                            • 114
                                            • 5 / 114
