    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.0m Views 585 Watching
    • fredo6F
      @massimo said:
      And this is the contents of the Libfredo_32 folder. And the IMAGES folder is empty. But i imagine i can delete any previous LibFredo.
      If you have a LibFredo6_Dir_33 folder in good shape, you can indeed remove the folder of the previous version LibFredo6_Dir_32.
      By the way, are you able to run the scripts like RoundCorner 2.1 and my other scripts after your installation ?
      • massimoM
        massimo Moderator
        I have deleted LibFredo6_Dir_32 and, after a quick test, RoundCorner and FredoScale seem to work fine. Thanks. 😄
        • I
          iamarchitecture
          Thanks Fredo
          • O
            oblin77
            Hello again
            Where can I find this group of plugin : RoundCorner 2.1, GhostComp 1.0 and ToolsOnSurface 1.5
            I would like to change my soft and I've seen your plugin
            wonderfull
            Thank
            Olivier
            • Jean-FrancoJ
              Jean-Franco
              Dear Olivier,
              you can find a collection of plugins here: http://forums.sketchucation.com/viewtopic.php?f=180&t=10142
              They are sorted in a way you should understand easily.
              And you can also have a look at there: http://www.sketchucation.com/extensions-index/
              Jean-Franco
              • fredo6F
                Escargot,
                Pas d'affichage. C'est juste une librairie de code Ruby commune a certains de mes scripts, le premier de cette famille etant FreeScale.
                • fredo6F
                  NEW VERSION 3.3a - 27 Aug 09
                  Needed for for RoundCorner 2.1, GhostComp 1.0 (and compatible for FredoScale and HoverSelect).
                  Small evolutions (some for Palettes), bug fixing, ...
                  see main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
                  • fredo6F
                    NEW VERSION 3.4a - 17 Sep 09
                    Needed for Tools On Surface v1.5 (and compatible for FredoScale, RoundCorner 2.1, GhostComp 1.0 and HoverSelect).
                    Small evolutions (mainly for Palettes), bug fixing, ...
                    • N
                      notareal
                      • Bob JamesB
                        Bob James
                        Fredo Tools alive and well on MacPro/Leopard (Tools on Surface, Round Corner, Joint Push-Pull)
                        • fredo6F
                          [Upgrade 08 Oct 09] LibFredo6 3.4b
                          Complement of Plugin translation to Spanish by Gaonirico (previous was done by Pichuneke).
                          See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=17947#p144178
                            SimonSTJ
                            whwrw can I find (download libfredo6 3.3a or higher..?
                              SimonSTJ
                              Hi.. Can you tell me where can I find libfredo6 3.3a or higher..?
                              • massimoM
                                massimo Moderator
                                Hi Simon, go to the bottom of the very first post of this thread. You will find something like this...(see below)
                                  SimonSTJ
                                  Thanks.. I've been doing that for the las 2 days hoping that I'll find something like that.
                                  Thank you again..I'll try to install it right now and if I have any problems I'll wright to you again.. 😄
                                  • fredo6F
                                    Update 20 Oct 09 - Documentation available in French, thanks to Jean-Franco.
                                    See main post http://forums.sketchucation.com/viewtopic.php?f=180&t=17947#p144178
                                      avya
                                      thanks 👍
                                        arturmercurio
                                        Great work! amazing just perfect. my best regards.
                                        http://www.arturcarvalho.me/
                                        • fredo6F
                                          [Chinese version - 11 Nov 09 - 21:50 CET
                                          Diweiman and the SuBAR_CLT team at SketchupBar have translated the script into Chinese.
                                          See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=17947&p=144178#p144178).
                                          • B
                                            blammas
                                            Is this compatible with windows 7? It doesn't show up in the folder once extracted...
                                            • 112
                                            • 113
                                            • 4 / 113
