    [Plugin Library] LibFredo6 - v16.1a - 31 Aug 26
    2.2k Posts 580 Posters 6.6m Views 582 Watching
    • massimoM Offline
      massimo Moderator
      I have deleted LibFredo6_Dir_32 and, after a quick test, RoundCorner and FredoScale seem to work fine. Thanks. 😄
      • I Offline
        iamarchitecture
        Thanks Fredo
        • O Offline
          oblin77
          Hello again
          Where can I find this group of plugin : RoundCorner 2.1, GhostComp 1.0 and ToolsOnSurface 1.5
          I would like to change my soft and I've seen your plugin
          wonderfull
          Thank
          Olivier
          • Jean-FrancoJ Offline
            Jean-Franco
            Dear Olivier,
            you can find a collection of plugins here: http://forums.sketchucation.com/viewtopic.php?f=180&t=10142
            They are sorted in a way you should understand easily.
            And you can also have a look at there: http://www.sketchucation.com/extensions-index/
            Jean-Franco
            • fredo6F Offline
              Escargot,
              Pas d'affichage. C'est juste une librairie de code Ruby commune a certains de mes scripts, le premier de cette famille etant FreeScale.
              • fredo6F Offline
                NEW VERSION 3.3a - 27 Aug 09
                Needed for for RoundCorner 2.1, GhostComp 1.0 (and compatible for FredoScale and HoverSelect).
                Small evolutions (some for Palettes), bug fixing, ...
                see main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
                • fredo6F Offline
                  NEW VERSION 3.4a - 17 Sep 09
                  Needed for Tools On Surface v1.5 (and compatible for FredoScale, RoundCorner 2.1, GhostComp 1.0 and HoverSelect).
                  Small evolutions (mainly for Palettes), bug fixing, ...
                  • N Offline
                    notareal
                    • Bob JamesB Offline
                      Bob James
                      Fredo Tools alive and well on MacPro/Leopard (Tools on Surface, Round Corner, Joint Push-Pull)
                      • fredo6F Offline
                        [Upgrade 08 Oct 09] LibFredo6 3.4b
                        Complement of Plugin translation to Spanish by Gaonirico (previous was done by Pichuneke).
                        See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=17947#p144178
                          SimonSTJ
                          whwrw can I find (download libfredo6 3.3a or higher..?
                            SimonSTJ
                            Hi.. Can you tell me where can I find libfredo6 3.3a or higher..?
                            • massimoM Offline
                              massimo Moderator
                              Hi Simon, go to the bottom of the very first post of this thread. You will find something like this...(see below)
                                SimonSTJ
                                Thanks.. I've been doing that for the las 2 days hoping that I'll find something like that.
                                Thank you again..I'll try to install it right now and if I have any problems I'll wright to you again.. 😄
                                • fredo6F Offline
                                  Update 20 Oct 09 - Documentation available in French, thanks to Jean-Franco.
                                  See main post http://forums.sketchucation.com/viewtopic.php?f=180&t=17947#p144178
                                    avya
                                    thanks 👍
                                      arturmercurio
                                      Great work! amazing just perfect. my best regards.
                                      http://www.arturcarvalho.me/
                                      • fredo6F Offline
                                        [Chinese version - 11 Nov 09 - 21:50 CET
                                        Diweiman and the SuBAR_CLT team at SketchupBar have translated the script into Chinese.
                                        See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=17947&p=144178#p144178).
                                          blammas
                                          Is this compatible with windows 7? It doesn't show up in the folder once extracted...
                                            works fine on my windows7. But I have the UAC diabled, maybe that makes a difference.... Think there was an issue on Vista where files some times ended up in a compatibility folder...
                                            • 111
                                            • 112
                                            • 4 / 112
