    [Plugin Library] LibFredo6 - v15.9b - 21 Apr 26
    2.2k Posts 578 Posters 4.6m Views 580 Watching
    • massimoM Offline
      massimo Moderator
      Not installed yet. The downloaded zip file contains a LibFredo6_Dir_33 folder, a LibFredo6 file plus another LibFredo6_Dir_32 folder with an empty IMAGES_Standard sub-folder. At least in my download. ๐Ÿ˜„
      But i believe i have simply to remove it.
      • fredo6F Offline
        Can you then install it (Open Zip file, Select All, Extract in Plugins folder) and check whether you have any trace of the LibFredo6_Dir_32 in the folder created.
        I did it on several machines, and no trace of the old folder.
        • massimoM Offline
          massimo Moderator
          Hmmm really strange. I overwrote the Libfredo_32 empty folder on the existing folder and now it's no more empty ...
          This is what i have after the download.
          • massimoM Offline
            massimo Moderator
            And this is the contents of the Libfredo_32 folder. And the IMAGES folder is empty. But i imagine i can delete any previous LibFredo.
            • fredo6F Offline
              If you have a LibFredo6_Dir_33 folder in good shape, you can indeed remove the folder of the previous version LibFredo6_Dir_32.
              By the way, are you able to run the scripts like RoundCorner 2.1 and my other scripts after your installation ?
              • massimoM Offline
                massimo Moderator
                I have deleted LibFredo6_Dir_32 and, after a quick test, RoundCorner and FredoScale seem to work fine. Thanks. ๐Ÿ˜„
                • I Offline
                  iamarchitecture
                  Thanks Fredo
                  • O Offline
                    oblin77
                    Hello again
                    Where can I find this group of plugin : RoundCorner 2.1, GhostComp 1.0 and ToolsOnSurface 1.5
                    I would like to change my soft and I've seen your plugin
                    wonderfull
                    Thank
                    Olivier
                    • Jean-FrancoJ Offline
                      Jean-Franco
                      Dear Olivier,
                      you can find a collection of plugins here: http://forums.sketchucation.com/viewtopic.php?f=180&t=10142
                      They are sorted in a way you should understand easily.
                      And you can also have a look at there: http://www.sketchucation.com/extensions-index/
                      Jean-Franco
                      • fredo6F Offline
                        Escargot,
                        Pas d'affichage. C'est juste une librairie de code Ruby commune a certains de mes scripts, le premier de cette famille etant FreeScale.
                        • fredo6F Offline
                          NEW VERSION 3.3a - 27 Aug 09
                          Needed for for RoundCorner 2.1, GhostComp 1.0 (and compatible for FredoScale and HoverSelect).
                          Small evolutions (some for Palettes), bug fixing, ...
                          see main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
                          • fredo6F Offline
                            NEW VERSION 3.4a - 17 Sep 09
                            Needed for Tools On Surface v1.5 (and compatible for FredoScale, RoundCorner 2.1, GhostComp 1.0 and HoverSelect).
                            Small evolutions (mainly for Palettes), bug fixing, ...
                            • N Offline
                              notareal
                              • Bob JamesB Offline
                                Bob James
                                Fredo Tools alive and well on MacPro/Leopard (Tools on Surface, Round Corner, Joint Push-Pull)
                                • fredo6F Offline
                                  [Upgrade 08 Oct 09] LibFredo6 3.4b
                                  Complement of Plugin translation to Spanish by Gaonirico (previous was done by Pichuneke).
                                  See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=17947#p144178
                                    SimonSTJ
                                    whwrw can I find (download libfredo6 3.3a or higher..?
                                      SimonSTJ
                                      Hi.. Can you tell me where can I find libfredo6 3.3a or higher..?
                                      • massimoM Offline
                                        massimo Moderator
                                        Hi Simon, go to the bottom of the very first post of this thread. You will find something like this...(see below)
                                          SimonSTJ
                                          Thanks.. I've been doing that for the las 2 days hoping that I'll find something like that.
                                          Thank you again..I'll try to install it right now and if I have any problems I'll wright to you again.. ๐Ÿ˜„
                                          • fredo6F Offline
                                            Update 20 Oct 09 - Documentation available in French, thanks to Jean-Franco.
                                            See main post http://forums.sketchucation.com/viewtopic.php?f=180&t=17947#p144178
                                            • 111
                                            • 112
                                            • 4 / 112
