    1.5k Posts 471 Posters 3.3m Views 470 Watching
    • massimoM Offline
      massimo Moderator
      Look at the bottom of the very first post of this thread. You have also to install the latest version of LibFredo. Read the first post carefully.
        Jebimasta
        ๐Ÿ˜ฎ this plugin is incredible, Rendering will look so much better now, I don't even think I could have done this manually because of the odd corners, all sorts of angles going on ๐Ÿ˜›
        Thanks a LOT, perhaps a small donation towards your efforts via paypal or something? ๐Ÿ˜„
          Tools->Fredo Collection->RoundCorner->Donation... ๐Ÿ˜‰
          • edenuxE Offline
            edenux
            I'm using windows 7, and i have problem when i put files into sketchup7/plugins directory. Can someone help me? Error says: " Error Loading File ZLoader__FredoScale.rb
            No such file to load -- LibFredo6.rbError Loading File ZLoader__RoundCorner.rb
            No such file to load -- LibFredo6.rb"
            Want to see more? Visit my facebook page: https://www.facebook.com/Edvisualisation
            • fredo6F Offline
              Can you compare first the footprint of files and folder on your PC and in the documentation to check if the installation by unzipping was done correctly, reconstructing the folder hierarchy.
              Also, did you install LibFredo6 (v3.4 now)?
              • jwlyon1J Offline
                jwlyon1
                Just added this to my mac and works like a charm!! ๐Ÿ˜Ž
                Hmm... I've got a ton of plugins, so showing the folder structure wouldn't really help but...
                I installed it like so:
                /library/application suppor/google sketchup 7/sketchup/plugins/
                • Libfredo6_Dir_34 (folder)
                • Libredo6.rb
                • ROUNDCORNER_Dir_21 (folder)
                • ZLoader__RoundCorner.rb
                (Note: I had to delete an older Libfredo6_Dir. I also had to delete and older ROUNDCORNER_Dir, but it worked fine with this older directory in place)
                What a great thing... awesome.
                Macbook Pro/ iMac
                OSX 10.7.2 Sketchup 8
                rogue-z is here!
                  Arnold Layne
                  amazing..thanks
                    SteveZissou1
                    i'm sorry if this is a foolish question, but i would really like to try the roundcorner ruby, but my screen says:
                    "You do not have the required permissions to view the files attached to this post."
                    what do i have to do to get permission?
                    thanks
                    brian
                    • jwlyon1J Offline
                      jwlyon1
                      I think all you have to do is register and login to the forum... Since you've done that try downloading again!
                      Macbook Pro/ iMac
                      rogue-z is here!
                      • boofredlayB Offline
                        boofredlay
                        Justin is correct Brian, you have to register. But the best part... it's FREE ๐Ÿ˜„
                        • mitcorbM Offline
                          mitcorb
                          If Brian is able to post in the forum, doesn't that mean he is registered?
                          And if he is registered, could this be the Board Cookies Login problem?
                          At the Forum Index Page navigate to the bottom to the button "Delete All Board Cookies", select Yes, then select Return to the Forum Index.
                          Also, there is a red oval on the right side of the page at the top regarding this.
                          If this is not the problem, never mind.
                            It must rather be a browser cookie setting IMO. See this global announcement
                            http://forums.sketchucation.com/viewtopic.php?f=18&t=19797
                            and delete your cookies in the browser.
                            (The registration/login help email would end up in my mailox anyway ๐Ÿ˜„ )
                              Blackpercula
                              Thank
                              • H Offline
                                hamster3
                                Fredo, you make sketchup to become perfect!
                                Thank you! ๐Ÿ˜
                                • fredo6F Offline
                                  [Upgrade 08 Oct 09] RoundCorner 2.1c
                                  Documentation translated to French by Christophe Plassais(the plugin itself was already available in French) and plugin translation to Spanish by Gaonirico.
                                  See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&st=0&sk=t&sd=a#p171721
                                  • jeff hammondJ Offline
                                    can't believe i missed this update..
                                    great work once again fredo!
                                    thank you
                                    • EarthMoverE Offline
                                      EarthMover
                                      Fredo...small request for a perfect plugin. In the next release, might you consider and option to drag out a visual offset? i.e. if I have a cube and want to round the corners, I could click on a corner and drag down the offset visually as you would the standard offset tool. With irregular shaped objects, I find myself entering 3 or 4 dimensions manually until I find one that doesn't overlap in tight corners and create a hole. If I could dynamically pull out the offset, I could see how far the offset could be before running into issues. Just a suggestions. Like I said...really just the perfect tool all the way around.
                                      Content Creator at Skapeup
                                        you fixed sketchup! ๐Ÿ˜„
                                        prior to this script, if i needed a corner to look like the one on the left (and i need them often), i had to draw it manually and while not incredibly difficult, it's certainly a waste of time.. SU+ follow me can't do it right..
                                        RoundCorner on the left -- SU on the right
                                        when doing a corner which has a top radius looser than the profile radius... SU/follow me & RoundCorner produce the exact same results which are incorrect but i can deal with it a little easier..
                                        the transparent planes show where the hidden lines should be.. the attached skp shows another problem as well.
                                        RoundCorner & SU/follow me
                                        of course, i'm using this plugin for an application far from its intent and i'm not asking you to try to fix this or anything... just pointing out a sketchup error that you happened to halfway fix..
                                        thanks man -- great plugin here.
                                        roundedge.skp
                                        • fredo6F Offline
                                          Visual dragging was in my plan but is stuck with many other things I need to do on this plugin (non-uniform offset, custom profiles) and other plugins. I should also add a detector of holes and overlaps.
                                          So point noted.
                                          • plot-parisP Offline
                                            plot-paris
                                            cool! are we going to get christmas presents? ๐ŸŽ‰ ... ๐Ÿ˜„
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 73
                                            • 74
                                            • 67 / 74
