    1.5k Posts 478 Posters 4.3m Views 478 Watching
      Jebimasta
      ๐Ÿ˜ฎ this plugin is incredible, Rendering will look so much better now, I don't even think I could have done this manually because of the odd corners, all sorts of angles going on ๐Ÿ˜›
      Thanks a LOT, perhaps a small donation towards your efforts via paypal or something? ๐Ÿ˜„
        Tools->Fredo Collection->RoundCorner->Donation... ๐Ÿ˜‰
        • edenuxE
          edenux
          I'm using windows 7, and i have problem when i put files into sketchup7/plugins directory. Can someone help me? Error says: " Error Loading File ZLoader__FredoScale.rb
          No such file to load -- LibFredo6.rbError Loading File ZLoader__RoundCorner.rb
          No such file to load -- LibFredo6.rb"
          Want to see more? Visit my facebook page: https://www.facebook.com/Edvisualisation
          • fredo6F
            Can you compare first the footprint of files and folder on your PC and in the documentation to check if the installation by unzipping was done correctly, reconstructing the folder hierarchy.
            Also, did you install LibFredo6 (v3.4 now)?
            • jwlyon1J
              jwlyon1
              Just added this to my mac and works like a charm!! ๐Ÿ˜Ž
              Hmm... I've got a ton of plugins, so showing the folder structure wouldn't really help but...
              I installed it like so:
              /library/application suppor/google sketchup 7/sketchup/plugins/
              • Libfredo6_Dir_34 (folder)
              • Libredo6.rb
              • ROUNDCORNER_Dir_21 (folder)
              • ZLoader__RoundCorner.rb
              (Note: I had to delete an older Libfredo6_Dir. I also had to delete and older ROUNDCORNER_Dir, but it worked fine with this older directory in place)
              What a great thing... awesome.
              Macbook Pro/ iMac
              OSX 10.7.2 Sketchup 8
              rogue-z is here!
                Arnold Layne
                amazing..thanks
                  SteveZissou1
                  i'm sorry if this is a foolish question, but i would really like to try the roundcorner ruby, but my screen says:
                  "You do not have the required permissions to view the files attached to this post."
                  what do i have to do to get permission?
                  thanks
                  brian
                  • jwlyon1J
                    jwlyon1
                    I think all you have to do is register and login to the forum... Since you've done that try downloading again!
                    Macbook Pro/ iMac
                    rogue-z is here!
                    • boofredlayB
                      boofredlay
                      Justin is correct Brian, you have to register. But the best part... it's FREE ๐Ÿ˜„
                      • mitcorbM
                        mitcorb
                        If Brian is able to post in the forum, doesn't that mean he is registered?
                        And if he is registered, could this be the Board Cookies Login problem?
                        At the Forum Index Page navigate to the bottom to the button "Delete All Board Cookies", select Yes, then select Return to the Forum Index.
                        Also, there is a red oval on the right side of the page at the top regarding this.
                        If this is not the problem, never mind.
                        • GaieusG
                          It must rather be a browser cookie setting IMO. See this global announcement
                          http://forums.sketchucation.com/viewtopic.php?f=18&t=19797
                          and delete your cookies in the browser.
                          (The registration/login help email would end up in my mailox anyway ๐Ÿ˜„ )
                          • B
                            Blackpercula
                            Thank
                            • H
                              hamster3
                              Fredo, you make sketchup to become perfect!
                              Thank you! ๐Ÿ˜
                              • fredo6F
                                [Upgrade 08 Oct 09] RoundCorner 2.1c
                                Documentation translated to French by Christophe Plassais(the plugin itself was already available in French) and plugin translation to Spanish by Gaonirico.
                                See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&st=0&sk=t&sd=a#p171721
                                • jeff hammondJ
                                  can't believe i missed this update..
                                  great work once again fredo!
                                  thank you
                                  • EarthMoverE
                                    EarthMover
                                    Fredo...small request for a perfect plugin. In the next release, might you consider and option to drag out a visual offset? i.e. if I have a cube and want to round the corners, I could click on a corner and drag down the offset visually as you would the standard offset tool. With irregular shaped objects, I find myself entering 3 or 4 dimensions manually until I find one that doesn't overlap in tight corners and create a hole. If I could dynamically pull out the offset, I could see how far the offset could be before running into issues. Just a suggestions. Like I said...really just the perfect tool all the way around.
                                    Content Creator at Skapeup
                                    • jeff hammondJ
                                      you fixed sketchup! ๐Ÿ˜„
                                      prior to this script, if i needed a corner to look like the one on the left (and i need them often), i had to draw it manually and while not incredibly difficult, it's certainly a waste of time.. SU+ follow me can't do it right..
                                      RoundCorner on the left -- SU on the right
                                      when doing a corner which has a top radius looser than the profile radius... SU/follow me & RoundCorner produce the exact same results which are incorrect but i can deal with it a little easier..
                                      the transparent planes show where the hidden lines should be.. the attached skp shows another problem as well.
                                      RoundCorner & SU/follow me
                                      of course, i'm using this plugin for an application far from its intent and i'm not asking you to try to fix this or anything... just pointing out a sketchup error that you happened to halfway fix..
                                      thanks man -- great plugin here.
                                      roundedge.skp
                                      • fredo6F
                                        Visual dragging was in my plan but is stuck with many other things I need to do on this plugin (non-uniform offset, custom profiles) and other plugins. I should also add a detector of holes and overlaps.
                                        So point noted.
                                        • plot-parisP
                                          plot-paris
                                          cool! are we going to get christmas presents? ๐ŸŽ‰ ... ๐Ÿ˜„
                                          • FletchF
                                            Fletch
                                            I just have to say that the more I use this plugin, the more amazing it becomes, it's simply one of my favorite plugins ever written for SketchUp.
                                            http://twilightrender.com/phpBB3/images/smilies/Respect.gif
                                            My favorite part is the little toolbar that pops up with buttons and options on it, and that I can save 2 presets that I commonly use.
                                            http://twilightrender.com/phpBB3/download/file.php?id=1547
                                            Fletch
                                            • 74
                                            • 75
                                            • 7 / 75
