    1.5k Posts 476 Posters 3.9m Views 476 Watching
    • fredo6F Offline
      @decker said:
      Contiued from previous post - Difficulties with installation of LibFredo6 3.3a and RoundCorner2.1a
      After removing empty directories I get this message upon SKU start up -
      Error Loading File ZLoader__RoundCorner.rb
      uninitialized constant Traductor::Plugin
      Help Please.... ๐Ÿ˜ข
      It could come from your Unzip program that may not respect the reconstruction of hierarchy for folders. On PC, it is advised to use WinZip, but on Mac, I don't know.
      Open the zip file, Select_all, click on Extract, select the Skechup Plugins folder, then answer YES to any request for overwriting.
      Do this for LibFredo6 3.3a.zip and for RoundCorner 2.1a.zip.
      Check that the folder hierarchy is correctly reconstructed
      At the top level, with the Sketchup Plugins folder, you should have only these files and folders:
      Within the folder ROUNDCORNER_Dir_21, you should have:
      Within the folder LIBFREDO6_Dir_33, you should have:
      Don't bother for the rest. Do not delete, rename or move files manually.
        Jim
        Fredo - this is off-topic, but I have been wanting to show files and folders as you have shown in the in the previous post. How do you do it?
        • fredo6F Offline
          I use a very handy shareware, called STG FolderPrint Plus.
          More info at http://www.stgsys.com/fpp.asp
            Decker
            Are there any MAC users out there that can help describe the proper directory build for this plugin??? thank you
              Decker
              Seems like I have it working here are my directories
              SKU plugins - LIBFREDO_DIR_33
              LibFredo6.rb
              ROUNDCORNER_Dir_21
              Zloader RoundCorner.rb
              removed extra directories
              Thanks for your help
                B2Pi
                Is it possible to do a 'half-round' in order to round the intersection of two mitered components? Thanks so much
                • fredo6F Offline
                  Could you illustrate so that it is fully clear.
                  Fred
                    Sergio Morera
                    What an excellent pluging it works like a charm on SU 7. Thank you for all the wonderful work you have done in this forum, it is really inspiring.
                      Pegasus442
                      can anyone help me get this plugin, im looking for a download link for the upgrade for sketchup and the actual plugin buti cant find either of them.
                      • massimoM Offline
                        massimo Moderator
                        Look at the bottom of the very first post of this thread. You have also to install the latest version of LibFredo. Read the first post carefully.
                          Jebimasta
                          ๐Ÿ˜ฎ this plugin is incredible, Rendering will look so much better now, I don't even think I could have done this manually because of the odd corners, all sorts of angles going on ๐Ÿ˜›
                          Thanks a LOT, perhaps a small donation towards your efforts via paypal or something? ๐Ÿ˜„
                            Tools->Fredo Collection->RoundCorner->Donation... ๐Ÿ˜‰
                            • edenuxE Offline
                              edenux
                              I'm using windows 7, and i have problem when i put files into sketchup7/plugins directory. Can someone help me? Error says: " Error Loading File ZLoader__FredoScale.rb
                              No such file to load -- LibFredo6.rbError Loading File ZLoader__RoundCorner.rb
                              No such file to load -- LibFredo6.rb"
                              Want to see more? Visit my facebook page: https://www.facebook.com/Edvisualisation
                              • fredo6F Offline
                                Can you compare first the footprint of files and folder on your PC and in the documentation to check if the installation by unzipping was done correctly, reconstructing the folder hierarchy.
                                Also, did you install LibFredo6 (v3.4 now)?
                                • jwlyon1J Offline
                                  jwlyon1
                                  Just added this to my mac and works like a charm!! ๐Ÿ˜Ž
                                  Hmm... I've got a ton of plugins, so showing the folder structure wouldn't really help but...
                                  I installed it like so:
                                  /library/application suppor/google sketchup 7/sketchup/plugins/
                                  • Libfredo6_Dir_34 (folder)
                                  • Libredo6.rb
                                  • ROUNDCORNER_Dir_21 (folder)
                                  • ZLoader__RoundCorner.rb
                                  (Note: I had to delete an older Libfredo6_Dir. I also had to delete and older ROUNDCORNER_Dir, but it worked fine with this older directory in place)
                                  What a great thing... awesome.
                                  Macbook Pro/ iMac
                                  OSX 10.7.2 Sketchup 8
                                  rogue-z is here!
                                    Arnold Layne
                                    amazing..thanks
                                      SteveZissou1
                                      i'm sorry if this is a foolish question, but i would really like to try the roundcorner ruby, but my screen says:
                                      "You do not have the required permissions to view the files attached to this post."
                                      what do i have to do to get permission?
                                      thanks
                                      brian
                                      • jwlyon1J Offline
                                        jwlyon1
                                        I think all you have to do is register and login to the forum... Since you've done that try downloading again!
                                        Macbook Pro/ iMac
                                        rogue-z is here!
                                        • boofredlayB Offline
                                          boofredlay
                                          Justin is correct Brian, you have to register. But the best part... it's FREE ๐Ÿ˜„
                                          • mitcorbM Offline
                                            mitcorb
                                            If Brian is able to post in the forum, doesn't that mean he is registered?
                                            And if he is registered, could this be the Board Cookies Login problem?
                                            At the Forum Index Page navigate to the bottom to the button "Delete All Board Cookies", select Yes, then select Return to the Forum Index.
                                            Also, there is a red oval on the right side of the page at the top regarding this.
                                            If this is not the problem, never mind.
                                            • 74
                                            • 75
                                            • 6 / 75
