    1.5k Posts 476 Posters 4.0m Views 476 Watching
    • fredo6F Offline
      @jim said:
      Fredo - this is off-topic, but I have been wanting to show files and folders as you have shown in the in the previous post. How do you do it?
      I use a very handy shareware, called STG FolderPrint Plus.
      More info at http://www.stgsys.com/fpp.asp
        Decker
        Are there any MAC users out there that can help describe the proper directory build for this plugin??? thank you
          Decker
          Seems like I have it working here are my directories
          SKU plugins - LIBFREDO_DIR_33
          LibFredo6.rb
          ROUNDCORNER_Dir_21
          Zloader RoundCorner.rb
          removed extra directories
          Thanks for your help
            B2Pi
            Is it possible to do a 'half-round' in order to round the intersection of two mitered components? Thanks so much
            • fredo6F Offline
              Could you illustrate so that it is fully clear.
              Fred
                Sergio Morera
                What an excellent pluging it works like a charm on SU 7. Thank you for all the wonderful work you have done in this forum, it is really inspiring.
                  Pegasus442
                  can anyone help me get this plugin, im looking for a download link for the upgrade for sketchup and the actual plugin buti cant find either of them.
                  • massimoM Offline
                    massimo Moderator
                    Look at the bottom of the very first post of this thread. You have also to install the latest version of LibFredo. Read the first post carefully.
                      Jebimasta
                      ๐Ÿ˜ฎ this plugin is incredible, Rendering will look so much better now, I don't even think I could have done this manually because of the odd corners, all sorts of angles going on ๐Ÿ˜›
                      Thanks a LOT, perhaps a small donation towards your efforts via paypal or something? ๐Ÿ˜„
                        Tools->Fredo Collection->RoundCorner->Donation... ๐Ÿ˜‰
                        • edenuxE Offline
                          edenux
                          I'm using windows 7, and i have problem when i put files into sketchup7/plugins directory. Can someone help me? Error says: " Error Loading File ZLoader__FredoScale.rb
                          No such file to load -- LibFredo6.rbError Loading File ZLoader__RoundCorner.rb
                          No such file to load -- LibFredo6.rb"
                          Want to see more? Visit my facebook page: https://www.facebook.com/Edvisualisation
                          • fredo6F Offline
                            Can you compare first the footprint of files and folder on your PC and in the documentation to check if the installation by unzipping was done correctly, reconstructing the folder hierarchy.
                            Also, did you install LibFredo6 (v3.4 now)?
                            • jwlyon1J Offline
                              jwlyon1
                              Just added this to my mac and works like a charm!! ๐Ÿ˜Ž
                              Hmm... I've got a ton of plugins, so showing the folder structure wouldn't really help but...
                              I installed it like so:
                              /library/application suppor/google sketchup 7/sketchup/plugins/
                              • Libfredo6_Dir_34 (folder)
                              • Libredo6.rb
                              • ROUNDCORNER_Dir_21 (folder)
                              • ZLoader__RoundCorner.rb
                              (Note: I had to delete an older Libfredo6_Dir. I also had to delete and older ROUNDCORNER_Dir, but it worked fine with this older directory in place)
                              What a great thing... awesome.
                              Macbook Pro/ iMac
                              OSX 10.7.2 Sketchup 8
                              rogue-z is here!
                                Arnold Layne
                                amazing..thanks
                                  SteveZissou1
                                  i'm sorry if this is a foolish question, but i would really like to try the roundcorner ruby, but my screen says:
                                  "You do not have the required permissions to view the files attached to this post."
                                  what do i have to do to get permission?
                                  thanks
                                  brian
                                  • jwlyon1J Offline
                                    jwlyon1
                                    I think all you have to do is register and login to the forum... Since you've done that try downloading again!
                                    Macbook Pro/ iMac
                                    rogue-z is here!
                                    • boofredlayB Offline
                                      boofredlay
                                      Justin is correct Brian, you have to register. But the best part... it's FREE ๐Ÿ˜„
                                      • mitcorbM Offline
                                        mitcorb
                                        If Brian is able to post in the forum, doesn't that mean he is registered?
                                        And if he is registered, could this be the Board Cookies Login problem?
                                        At the Forum Index Page navigate to the bottom to the button "Delete All Board Cookies", select Yes, then select Return to the Forum Index.
                                        Also, there is a red oval on the right side of the page at the top regarding this.
                                        If this is not the problem, never mind.
                                          It must rather be a browser cookie setting IMO. See this global announcement
                                          http://forums.sketchucation.com/viewtopic.php?f=18&t=19797
                                          and delete your cookies in the browser.
                                          (The registration/login help email would end up in my mailox anyway ๐Ÿ˜„ )
                                            Blackpercula
                                            Thank
                                            • 74
                                            • 75
                                            • 6 / 75
