    [Plugin] extrudeEdgesByLathe
    104 Posts 43 Posters 69.8k Views 43 Watching
      Seems you must say that the "path" or the "face" must be on a vertical plan else maybe result will be not that you want 😉
      Cool plug as always ☀
      @tig said:
      The selected polyline's edges are swept around in an arc,
      about the Z-axis [blue] and are faced.
      • FrederikF Offline
        Frederik
        Thanks, Tig...!
        @simon le bon said:
        You surf so easily with ruby that you are a sort of Yoda jedaï in the SketchUpSpace...
        +1
        Cheers
        Kim Frederik
        • massimoM Offline
          massimo Moderator
          Many thanks TIG, it works like a charm. 👍 👍
            v1.1 is here http://forums.sketchucation.com/viewtopic.php?p=184477#p184477
            Improved inferencing of pick cursor and tooltips.
            Added second point pick to set axis of rotation.
            Thanks for the kind comments so far... 😄
              Ben Ritter
              I am not able to create a "donut" shape. My shape is oriented in the vertical direction and I select the blue axis for axis of rotation. What am I doing wrong?
                Panga
                Thanks a lot for this one, definitly needed !!
                    Ben Ritter
                    TIG,
                    That is the process I used, however, without having a short line to define the radius point.
                    In my attachment, you can see the result with and without a reference line for the radius point. The inference was indicating that I was going up in the blue axis direction, but I still got the result shown.
                    Thanks. Ben
                      Ben Ritter
                        @ben ritter said:
                        TIG,
                        Thanks. Ben
                        Did the VCB say [0.0,0.0,1.0] - i.e. Z-axis... If you start off in the blue Z-direction and hold down the shift-key the interference is locked to blue and when you pick it should definitely be axial... You don't need the short line - I added it for clarity. You can start to move off in the blue direction, hold-down shift to lock in the blue and pick any point above the center and it should snap to vertical ?
                          Ben Ritter
                          The VCB doesn't say anything in the process, but the screen shows that I'm on the blue axis. For some reason, it only works when I lock down the inferencing with the shift key. Even though it says I'm pointing on the blue axis, somehow it must not lock on without holding the shift.
                          Thanks TIG
                            Jim
                            TIG - thanks for another fine plugin.
                            report - not sure where you're getting the definition for round - Float.round does not take an argument.
                            Also, version 7 users would find a nice speed-up by modifying the start_operation statement:
                            model.start_operation("Lathe", true)
                            Error; #<ArgumentError; wrong number of arguments(1 for 0)>
                            C;/Program Files/Google/Google SketchUp 7.1b3/Plugins/lathe1.1.rb;146;in `round'
                            C;/Program Files/Google/Google SketchUp 7.1b3/Plugins/lathe1.1.rb;146;in `onMouseMove'
                            • simon le bonS Offline
                              simon le bon
                              HeyHey!
                              this time (V1.1) Lathe Tool is "carrément génial"
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/lathe_TigBth.jpg
                              ++simon
                                tomasz
                                Tig, thanks for the plugin!
                                Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                                  v1.2 now available here http://forums.sketchucation.com/viewtopic.php?p=184477#p184477
                                  'Round' error fixed.
                                  Operation optimized for v7 users.
                                  Following Jim's comments... 🤓
                                    I'll add the version 7 speed up [forgotten during its speedy initial creation] and my float.round(n) does work for me !!! - although I don't know where I'm got that from [Edit: I grepped my rubies and found that 'Demeter.rb' and 'sunposition.rb' both redefine float.round(n=0) to take an argument [defaults to 0 if not set]]... I've written a similar method too float.roundup(n) to keep it separate... An update v1.2 will be issued shortly...
                                      RustyShack
                                      Very nice to have this function as a pseudo-built in rather than the clunky workaround previously required to make lathed objects. Thanks!
                                      • MALAISEM Offline
                                        MALAISE
                                        Wow ! Many thanks TIG.
                                        SU becomes really powerfull when boosted with all theses plugins...
                                        MALAISE 👍
                                          Here's v1.3 with Soft/Smooth Option in dialog
                                            dedmin
                                            • 4 / 6
