    [Plugin] extrudeEdgesByLathe
    104 Posts 43 Posters 83.4k Views 43 Watching
      Ben Ritter
      The VCB doesn't say anything in the process, but the screen shows that I'm on the blue axis. For some reason, it only works when I lock down the inferencing with the shift key. Even though it says I'm pointing on the blue axis, somehow it must not lock on without holding the shift.
      Thanks TIG
        Jim
        TIG - thanks for another fine plugin.
        report - not sure where you're getting the definition for round - Float.round does not take an argument.
        Also, version 7 users would find a nice speed-up by modifying the start_operation statement:
        model.start_operation("Lathe", true)
        Error; #<ArgumentError; wrong number of arguments(1 for 0)>
        C;/Program Files/Google/Google SketchUp 7.1b3/Plugins/lathe1.1.rb;146;in `round'
        C;/Program Files/Google/Google SketchUp 7.1b3/Plugins/lathe1.1.rb;146;in `onMouseMove'
        • simon le bonS Offline
          simon le bon
          HeyHey!
          this time (V1.1) Lathe Tool is "carrément génial"
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/lathe_TigBth.jpg
          ++simon
            tomasz
            Tig, thanks for the plugin!
            • TIGT Online
              v1.2 now available here http://forums.sketchucation.com/viewtopic.php?p=184477#p184477
              'Round' error fixed.
              Operation optimized for v7 users.
              Following Jim's comments... 🤓
              • TIGT Online
                I'll add the version 7 speed up [forgotten during its speedy initial creation] and my float.round(n) does work for me !!! - although I don't know where I'm got that from [Edit: I grepped my rubies and found that 'Demeter.rb' and 'sunposition.rb' both redefine float.round(n=0) to take an argument [defaults to 0 if not set]]... I've written a similar method too float.roundup(n) to keep it separate... An update v1.2 will be issued shortly...
                  RustyShack
                  Very nice to have this function as a pseudo-built in rather than the clunky workaround previously required to make lathed objects. Thanks!
                  • MALAISEM Offline
                    MALAISE
                    Wow ! Many thanks TIG.
                    SU becomes really powerfull when boosted with all theses plugins...
                    MALAISE 👍
                    • TIGT Online
                      Here's v1.3 with Soft/Smooth Option in dialog
                        dedmin
                          simon le bon
                          Lathe V1.3 *** more and more a true complement to FollowMe. I love this tool.
                          Unsoften ./. Soften ./. Soften+Smooth
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/lathe_TigCth.jpg
                          👍 TIG,
                          simon
                          • TIGT Online
                            v1.4 now available - fixed inference-locking glitch on repeated lathes...
                            404 Not Found
                            (forums.sketchucation.com)
                              DIEGO-RODRIGUEZ
                              HI TIG, is a small BUG.
                              THANKS FOR THE PLUGINS
                              http://img10.imageshack.us/img10/1411/lathe.png
                                Dan
                                @tig said:
                                Version:
                                20090915 1.0 First issue
                                20090916 1.1 Pick cursor/inferencing improved, choose 'axis' added.
                                20090917 1.2 'Round' error fixed. Operation optimized for v7 users.
                                20090918 1.3 Soft/Smooth Edges option added.
                                20090919 1.4 Inference-locking glitch fixed on repeated lathes.
                                Tig, I'm tired trying to follow your daily updates... so I'll be waiting for a week to jump directly to "Lathe V 3.0" 😄
                                Just kidding!
                                Awesome work, thank you again!
                                • X Offline
                                  xrok1
                                  very nice!
                                  • TIGT Online
                                    v1.5 available here http://forums.sketchucation.com/viewtopic.php?p=184477#p184477
                                    Smooth bug with Reverse Faces fixed.
                                      cyan.archnet
                                      SUPERB Plugin indeed!, THANKS A LOT!
                                      • jwlyon1J Offline
                                        jwlyon1
                                        ZOMG 😮
                                        This is fantastic!!
                                        TIG, your plugins are amazing.
                                        Added to my work flow and saved so much time!
                                        Macbook Pro/ iMac
                                        OSX 10.7.2 Sketchup 8
                                        rogue-z is here!
                                          Ruturaj
                                          This tool are very nice tool
                                          Good Job
                                          please sketchup " boolean " rb or plugin
                                          Thanks,
                                          RuturaJ
                                            Hi Ruturaj
                                            Oscarlok released a boolen plugin (which is free) however it has stuck in its beta version and does not always work as expected:
                                            http://forums.sketchucation.com/viewtopic.php?f=180&t=14773
                                            • 3 / 6
