[Plugin] Sculpt Tools (help)
First of all, thanx for such brilliant tool..it was one of my dreams...
It worked for mr ,but seems to me that I'v missed icons. -
I've played around and get the Icons to work. The files are send to BTM.
Wait, so all it needs is the small icons?
I thought that I didn't need small icons, as my mac will automatically turn the large ones into 16x16's, if I set it to small.I'll change the scripts as you did to have small icons too. If there are still issues, let me know.
You don't need to make separate small icons if you set the small icons to the same image as the large icons. But hand-made small icons usually look better than having SketchUp shrink the large ones. But I now remember having the same problem until I set the small icons to something, rather than nothing.
So.....all good to go now...shall I download it? Excited!!!!
Jeff -
I'm not sure if these changes are the only ones ( that's what I call "playing around" ) But I remember I put also the # in front of some header lines.
Pretty remarkable, btm. Here's 15 minute test.
Jim ..How did you make it work?
I just downloaded it - there are no images in the toolbar, but it works for me.
It also has worked just fine for me. Did you try the most recent download? It has the files cleaned up, so its easier to get it installed.
I have a question, does anyone have a good tip on how to make a triangulated sphere instead of one made from quads? I wanted one with triangualted faces so I could use the sandbox "add detail" tool.
For the avoidance of doubt... the current toolset zip is here ? http://forums.sketchucation.com/viewtopic.php?p=169747#p169747
A most interseting tool... marred by these toolbar problems...
The problem is there are no 'small_icons' AND the icons' paths are missing a ./... for example
###... $btm_sculpt_menu.add_item mgp mgp.large_icon = "./btm_sculpt3_push1.png" mgp.small_icon = "./btm_sculpt3_push1.png" ###...
I adjusted each of the rubies and NOW it works fine for me
Until some different sized [better?] icons gets made... -
Yeah, but =start and =end do the same things, so you didn't need those. I haven't posted the file with proper icons yet, but it's coming. I'm trying to get the script working with the multi-windows that macs can have; right now when I try it crashes. Apparently it's because active_model doesn't seem to be good enough for it, and the SU API FAQ mentions how to get it to work, so I'm going to give it a go…
Also, on a side note, is there anyone who wants to make a webdialog that can be opened and closed on the click of the dialog tool, instead of the current inputbox? I think that could make it easier to change settings while using a tool, but I can't make webdialogs. I don't know how .
hehe, yeah I also fixed my copy so the toolbars had icons. They stilla re in double, but at least they are there
###... > $btm_sculpt_menu.add_item mgp > mgp.large_icon = "./btm_sculpt3_push1.png" > mgp.small_icon = "./btm_sculpt3_push1.png" > ###...
Until some different sized [better?] icons gets made...Then why did it still work for me?
Awesome, thanks TIG!
BTM, I just PM'ed you a copy of the plugin with working icons on the PC, and a pc friendly zip, if you want to update the version here.
Maybe put the current copy back in the first post? Or maybe it just needs a whole new topic now that its a [Plugin] ? Or maybe you want to wait til the final toolbar oddities get worked out?
@chris fullmer said:
I have a question, does anyone have a good tip on how to make a triangulated sphere instead of one made from quads? I wanted one with triangulated faces so I could use the sandbox "add detail" tool.
See here:
http://forums.sketchucation.com/viewtopic.php?p=169956#p169956 ...
for 'triangulate.rb' ... -
Could actually someone post the one which works...of course with BTMs agreement. At moment this is crazy,
Thanks, got the small/large icons and tweaked the scripts... now works fine...
