    [Plugin] Sculpt Tools (help)
    188 Posts 46 Posters 79.6k Views 46 Watching
      Jim
      I just downloaded it - there are no images in the toolbar, but it works for me.
      • Chris FullmerC Offline
        It also has worked just fine for me. Did you try the most recent download? It has the files cleaned up, so its easier to get it installed.
        I have a question, does anyone have a good tip on how to make a triangulated sphere instead of one made from quads? I wanted one with triangualted faces so I could use the sandbox "add detail" tool.
          For the avoidance of doubt... the current toolset zip is here ? http://forums.sketchucation.com/viewtopic.php?p=169747#p169747
            A most interseting tool... marred by these toolbar problems...
            The problem is there are no 'small_icons' AND the icons' paths are missing a ./... for example
              $btm_sculpt_menu.add_item mgp
              mgp.large_icon = "./btm_sculpt3_push1.png"
              mgp.small_icon = "./btm_sculpt3_push1.png"
            I adjusted each of the rubies and NOW it works fine for me πŸ˜„
            Until some different sized [better?] icons gets made...
              BTM
              @burkhard said:
              I'm not sure if these changes are the only ones ( that's what I call "playing around" ) But I remember I put also the # in front of some header lines.
              Yeah, but =start and =end do the same things, so you didn't need those. I haven't posted the file with proper icons yet, but it's coming. I'm trying to get the script working with the multi-windows that macs can have; right now when I try it crashes. Apparently it's because active_model doesn't seem to be good enough for it, and the SU API FAQ mentions how to get it to work, so I'm going to give it a go…
              Also, on a side note, is there anyone who wants to make a webdialog that can be opened and closed on the click of the dialog tool, instead of the current inputbox? I think that could make it easier to change settings while using a tool, but I can't make webdialogs. I don't know how πŸ˜’ .
                hehe, yeah I also fixed my copy so the toolbars had icons. They stilla re in double, but at least they are there πŸ˜„
                  BTM
                  Then why did it still work for me? 😲
                  • CadFatherC Offline
                    CadFather
                    because mac is 🀒
                    small icons here
                    btm_sculpt_tools icons.zip
                      Awesome, thanks TIG!
                      BTM, I just PM'ed you a copy of the plugin with working icons on the PC, and a pc friendly zip, if you want to update the version here.
                      Maybe put the current copy back in the first post? Or maybe it just needs a whole new topic now that its a [Plugin] ? Or maybe you want to wait til the final toolbar oddities get worked out?
                        @chris fullmer said:
                        I have a question, does anyone have a good tip on how to make a triangulated sphere instead of one made from quads? I wanted one with triangulated faces so I could use the sandbox "add detail" tool.
                        See here:
                        http://forums.sketchucation.com/viewtopic.php?p=169956#p169956 ...
                        for 'triangulate.rb' ...
                          sepo
                          Could actually someone post the one which works...of course with BTMs agreement. At moment this is crazy,
                            Thanks, got the small/large icons and tweaked the scripts... now works fine...
                              BTM
                              @cadfather said:
                              because mac is 🀒
                              small icons here
                              I already made my own small icons, but whatever. Good for the others untill the next one's up.
                              Just a simple question, but is anyone willing to make better icons? I don't really like the ones it has right now, but don't know what the new ones should look like…
                              Why does everyone post things when I'm writing my posts/ editing the script myself! πŸ˜†
                              I'll check my PMs, and yes, I'm planning on making a [Plugin] thread when all the oddities work out. I'll keep the download where it is for now, so that mostly the people downloading it are those who are testing it.
                              Tell me about it πŸ˜’ πŸ‘Š
                                BTM
                                The download's been replaced with the one with good icons that Chris edited. My next fix of the mac issue should be up shortly.
                                  sepo
                                  BTM ...could you actually post the link for PC or at least say on which page it is. There are couple of download versions. Thanks
                                    BTM
                                    The download all link to the one on page 5.
                                      Can I suggest a new "[Plugin] Sculpt" thread that has the updated stuff as its first post - it's getting confusing...
                                        I've updated: triangulate.rb v1.1 to trap for 3 vertices in line and made a one-step undo http://forums.sketchucation.com/viewtopic.php?p=169956#p169956
                                          sepo
                                          It is not there anymore..
                                            BTM
                                            Sorry, I meant 4
                                            http://forums.sketchucation.com/download/file.php?id=30086
                                            • 5 / 10
