    [Plugin] Sculpt Tools (help)
    193 Posts 47 Posters 102.3k Views 47 Watching
    • CadFatherC
      CadFather
      i got the feeling it's somewhere here.. toolbar = $btm_sculpt_toolbar.add_item mgp
      (i might just get out some tarot cards)
      • majidM
        majid
        First of all, thanx for such brilliant tool..it was one of my dreams... πŸ‘ πŸ‘ πŸ‘
        It worked for mr ,but seems to me that I'v missed icons.
        • BurkhardB
          Burkhard
          I've played around and get the Icons to work. The files are send to BTM.
          http://www.ia-plus.de
          • B
            BTM
            Wait, so all it needs is the small icons? 😲
            I thought that I didn't need small icons, as my mac will automatically turn the large ones into 16x16's, if I set it to small.
            I'll change the scripts as you did to have small icons too. If there are still issues, let me know.
              Jim
              You don't need to make separate small icons if you set the small icons to the same image as the large icons. But hand-made small icons usually look better than having SketchUp shrink the large ones. But I now remember having the same problem until I set the small icons to something, rather than nothing.
              • C
                Click Draw
                So.....all good to go now...shall I download it? Excited!!!!
                Jeff
                Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                • BurkhardB
                  Burkhard
                  I'm not sure if these changes are the only ones ( that's what I call "playing around" ) But I remember I put also the # in front of some header lines.
                    Jim
                    Pretty remarkable, btm. Here's 15 minute test.
                      sepo
                      Jim ..How did you make it work?
                        Jim
                        I just downloaded it - there are no images in the toolbar, but it works for me.
                        • Chris FullmerC
                          It also has worked just fine for me. Did you try the most recent download? It has the files cleaned up, so its easier to get it installed.
                          I have a question, does anyone have a good tip on how to make a triangulated sphere instead of one made from quads? I wanted one with triangualted faces so I could use the sandbox "add detail" tool.
                            For the avoidance of doubt... the current toolset zip is here ? http://forums.sketchucation.com/viewtopic.php?p=169747#p169747
                              A most interseting tool... marred by these toolbar problems...
                              The problem is there are no 'small_icons' AND the icons' paths are missing a ./... for example
                                $btm_sculpt_menu.add_item mgp
                                mgp.large_icon = "./btm_sculpt3_push1.png"
                                mgp.small_icon = "./btm_sculpt3_push1.png"
                              I adjusted each of the rubies and NOW it works fine for me πŸ˜„
                              Until some different sized [better?] icons gets made...
                              • B
                                BTM
                                Yeah, but =start and =end do the same things, so you didn't need those. I haven't posted the file with proper icons yet, but it's coming. I'm trying to get the script working with the multi-windows that macs can have; right now when I try it crashes. Apparently it's because active_model doesn't seem to be good enough for it, and the SU API FAQ mentions how to get it to work, so I'm going to give it a go…
                                Also, on a side note, is there anyone who wants to make a webdialog that can be opened and closed on the click of the dialog tool, instead of the current inputbox? I think that could make it easier to change settings while using a tool, but I can't make webdialogs. I don't know how πŸ˜’ .
                                • Chris FullmerC
                                  hehe, yeah I also fixed my copy so the toolbars had icons. They stilla re in double, but at least they are there πŸ˜„
                                  • B
                                    BTM
                                    Then why did it still work for me? 😲
                                    • CadFatherC
                                      CadFather
                                      because mac is 🀒
                                      small icons here
                                      btm_sculpt_tools icons.zip
                                      • Chris FullmerC
                                        Awesome, thanks TIG!
                                        BTM, I just PM'ed you a copy of the plugin with working icons on the PC, and a pc friendly zip, if you want to update the version here.
                                        Maybe put the current copy back in the first post? Or maybe it just needs a whole new topic now that its a [Plugin] ? Or maybe you want to wait til the final toolbar oddities get worked out?
                                          @chris fullmer said:
                                          I have a question, does anyone have a good tip on how to make a triangulated sphere instead of one made from quads? I wanted one with triangulated faces so I could use the sandbox "add detail" tool.
                                          See here:
                                          http://forums.sketchucation.com/viewtopic.php?p=169956#p169956 ...
                                          for 'triangulate.rb' ...
                                            sepo
                                            Could actually someone post the one which works...of course with BTMs agreement. At moment this is crazy,
                                            • 5 / 10
