    [Plugin] Sculpt Tools (help)
    207 Posts 48 Posters 112.3k Views 48 Watching
    • L
      leixing
      @daniel s said:
      I can´t see the icons on the toolbar but the plugin seems to work.. but very slow for me.. I will keep trying
      Thank you!!
      Daniel S
      I have the same problem.I think i did the right work.
      Thank you BTM.
      • Chris FullmerC
        I sent him an updated .zip file a while ago. Hopefully he'll post it soon.
        But otherwise, you have to dig in a level intothe btm_sculp_tools folder. Then copy the single .rb file from there and the folder into your plugins folder. Then it will work (but as noted previously, the icons do not show up, its just a big blank toolbar (with tooltips though)). And the toolbar buttons appear twice, so its twice as big as it should be.
        You should be able to get it installed if you do that though.
        • Chris FullmerC
          I REALLY like the smooth tool. Its a lot of fun, as are all the other ones.
          I am wondering about the dual icons in the toolbar and the lack of toolbar icons. Are you seeing that also on the Mac? Or is that only happening on the PC?
          I'm looking for the problem, but so far I have not found it. I'm not sure if I'm just missing something obvious (I don't make toolbars all that often really). Or I am kind of thinking that your pressing your luck with the global variables holding all the menu information. You might simplify it by combining all the scripts into a single file, and remove the menu globals from the loader script. Just do all the menu stuff from the single main script in the folder.
          But again, perhaps that has nothing to do with it. I really haven't found anything concrete.
          Good luck with it, its awesome!
          • PixeroP
            Pixero
            Very nice. 👍
            I don't get the icons but I don't get them twice as you.
            I'm on XP.
              sepo
              No change for me. It is same as before.
              • B
                BTM
                … Weird 😕 The icons work for me, and, although ugly, look like this.
                I need better icons…
                I can't seem to find any problems either.
                • B
                  BTM
                  @cadfather said:
                  BTM, the problem is that you are calling the tools with different toolbars,
                  look in the extensions menu under preferences and you will find bulge, push etc
                  go to view toolbars and you will find your sculpt (sculp) as well
                  I actually just found out about the typo a few minutes ago 😆 The current file up is now easier to download, but still has the typo. As for me though, I only have the 1 toolbar anyways. 😕
                  • CadFatherC
                    CadFather
                    BTM, (Edit: 'i think') the problem is that you are calling the tools with different toolbars,
                    • CadFatherC
                      CadFather
                      i got the feeling it's somewhere here.. toolbar = $btm_sculpt_toolbar.add_item mgp
                      (i might just get out some tarot cards)
                      • majidM
                        majid
                        First of all, thanx for such brilliant tool..it was one of my dreams... 👍 👍 👍
                        It worked for mr ,but seems to me that I'v missed icons.
                        • BurkhardB
                          Burkhard
                          I've played around and get the Icons to work. The files are send to BTM.
                          http://www.ia-plus.de
                          • B
                            BTM
                            Wait, so all it needs is the small icons? 😲
                            I thought that I didn't need small icons, as my mac will automatically turn the large ones into 16x16's, if I set it to small.
                            I'll change the scripts as you did to have small icons too. If there are still issues, let me know.
                              Jim
                              You don't need to make separate small icons if you set the small icons to the same image as the large icons. But hand-made small icons usually look better than having SketchUp shrink the large ones. But I now remember having the same problem until I set the small icons to something, rather than nothing.
                              • C
                                Click Draw
                                So.....all good to go now...shall I download it? Excited!!!!
                                Jeff
                                Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                                • BurkhardB
                                  Burkhard
                                  I'm not sure if these changes are the only ones ( that's what I call "playing around" ) But I remember I put also the # in front of some header lines.
                                    Jim
                                    Pretty remarkable, btm. Here's 15 minute test.
                                      sepo
                                      Jim ..How did you make it work?
                                        Jim
                                        I just downloaded it - there are no images in the toolbar, but it works for me.
                                        • Chris FullmerC
                                          It also has worked just fine for me. Did you try the most recent download? It has the files cleaned up, so its easier to get it installed.
                                          I have a question, does anyone have a good tip on how to make a triangulated sphere instead of one made from quads? I wanted one with triangualted faces so I could use the sandbox "add detail" tool.
                                            For the avoidance of doubt... the current toolset zip is here ? http://forums.sketchucation.com/viewtopic.php?p=169747#p169747
                                            • 11
                                            • 4 / 11
