    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 215.4k Views 76 Watching
    • plot-parisP Offline
      plot-paris
      wow, really a nice plugin! thanks a lot, TIG! jumps out of his seat
      (and thanks Gaieus, for pointing me here...)
      that is quite a useful tool.
      next step: birial operation? (two different path-curves and/or several different base-curves...) ๐Ÿ˜‰
      • mitcorbM Offline
        mitcorb
        As Plot-paris said: "next step: birail operation? (two different path-curves and/or several different base-curves...) ๐Ÿ˜‰ and then morph along rails to preset sectional outlines, and who knows what else?
        I am currently enjoying some experimentation with this plugin-- craggy curtains, canyon walls, insect "skins"....
        Thank you TIG
        mitcorb
        • olisheaO Offline
          olishea
          does it work well for mac?
          oli
            dylan
            Works perfectly on the Mac Oli ๐Ÿ˜Ž
            http://dmdarchitecture.co.uk/
              putnik
              Thank you TIG!
              http://keshas.info
              • olisheaO Offline
                olishea
                amazing plugin, works really smooth too. gonna have some fun with this! ๐Ÿ˜†
                oli
                  Version 1.1 20090625
                  Speed improvements - face making time ~halved,
                  typename >> kind_of?, triangulation glitch trapped
                  and orientation improved.
                  It's here http://forums.sketchucation.com/viewtopic.php?p=166780#p166780 ...
                  Another example...
                    The funny of your plug ๐Ÿ˜‰
                    (Click the image)
                    • MALAISEM Offline
                      MALAISE
                      Great TIG, thanks a lot for this SU enhancement.
                      MALAISE
                      La Connaissance n'a de valeur que partagรฉe
                      • JClementsJ Offline
                        JClements
                        Congratulations TIG!
                        A very useful and well executed script.
                        Questions/Suggestions:
                        1- I assume the order in which the two groups were assigned determines the alignment of the mesh; to the last defined of the two selected groups.
                        2- Not critical, but could there be a Smoothing Dialog that prompts: "a)Smooth or b)Smooth and Soften"?
                        3- A defaults dialog triggered by pressing the [Tab] key? You'd would then be able to assign defaults of a Yes or No for each prompt and which which dialogs would be shown (if shown, then user could temporarily change their default as the script is playing).
                          Here's an update...
                          Version 1.2 20090625
                          Orientation speed optimised.
                          Glitch on groups erase fixed.
                          Get it here... http://forums.sketchucation.com/viewtopic.php?p=166780#p166780 ...
                          • I Offline
                            ideas_arte
                            Wow...!
                            Many thank you very much ...!
                            Excellent tool, thank you very much again and a hug from Central America ...! ๐Ÿ˜„
                            • massimoM Offline
                              massimo Moderator
                              Hi TIG and many thanks. I've tried both "intersect with self" or not, but nothing changed. A little problem...
                                Massimo
                                Have you tried the latest version v1.2 ? I've just tried to reproduce your path/profile and I get all faces made - no gaps - Any edge that can get a face should get a face ? Your faces aren't reversed are they, so look 'gappped' ?
                                The only problem I have was because of the convoluted result some faces orient wrongly [inside out] - both in the script AND within SUp later - the only fix is to reverse the problem faces manually ...
                                I had to guess your model's details - I could test it better with the real thing - if after trying with the latest version it still gaps please PM me with the model attached, so I can see if I get the same problem...
                                  Can you subsequently get the face made if you redraw an edge ? If so then EEbyE should have made that face...
                                  I haven't managed to reproduce it, can one of you PM me a [small] model with the problem ?
                                    I have same result but seems normal as this function is not adapted to this!
                                    As the profil stay parallel ๐Ÿ˜’
                                    At each "rotation" there are creation of an external or internal horizontal face ๐Ÿ˜„
                                    For ovoid that make just an half circle ๐Ÿ˜‰
                                    And a mirror after ๐Ÿ˜‰
                                    But even with this there some gaps ๐Ÿ˜‰
                                      file of the mirror above ๐Ÿ˜‰
                                      gap.skp
                                        I get no loose edges with either of your skp's... There is orientation weirdness as sometimes threes faces share as edge as it's convoluted in on itself when a circle... to be on the safe side I am adjusting the script to trap any edges without faces... Look out for update...
                                          Here's v1.3 ...
                                          It's been trapped for rare unfaced edges - it either forces the edge to have a face, or erases the edge if it's not possible to add a face ...
                                            Have you tried this latest version ?
                                            • 7 / 10
