    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    245 Posts 66 Posters 253.9k Views 66 Watching
      gohch
      hi guys,
      I've just worked out a solution to the icons/toolbar issue:
      (included in version 1.1.4)-- ready for download.
      i.e. a Toolbar manager that allows user to pick on what to show and hide.
      User can also choose between putting the icons in single toolbar or separate toolbars.
      manage toolbar function
      manage toolbar dialog
      You'll need to restart SU (once) for new setting to take effect. After that it'll remain persistent.
      In addition to that, I've also added a hip roof creator.
      hip roof tool
      Some complex profiles(particularly those that ends with curves) cannot be fully, automatically solved.
      in this case, the tool will do 'as much as it can'.
      Please try them out, cheers! πŸ˜„
        cadmunkey
        Downloaded the trial version this morning, v1.3 and it looks like a cracking set of tools. Cheers!
        • jeff hammondJ Offline
          oh NiCE!
          the new toolbar system is working well on macs.. thank you
          (i'm replying here instead of the other thread to keep things on topic)
          one problem is that what i wanted to do originally is what takesh was suggesting in this post:
          http://www.sketchucation.com/forums/scf/viewtopic.php?p=147577#p147577
          if i turn off an icon via the toolbar manager, i know longer have the icon available for my custom toolbar at the top of the SU window (i'm pretty sure the customized toolbar up top is a mac only thing)
          the way you've set it up though doesn't really matter now because i can just make a custom 1001bit toolbar using any of the icons.
          it's fine like this.
          thank you!
            That hip roof creator will be well handy to use. πŸ‘ πŸ‘
              Just tried the Hip Roof creator; and I get some errors:
              Error - Vertex with more than 2 edges found on face.
              followed by:
              Face #Sketchup::Face:0x7285f00 invalid. Cannot create hip roof from this face.
              I had pushpulled a box and selected the top face.
              If I grouped it first, then it worked fine.
              Why can't it create a roof from a face connected to other geometry? And could you make it so it automatically creates a copy of the face in a group from which it creates the roof? That'd be a smoother workflow.
                Cheers TIG! πŸ‘
                  My Roof.rb (v3 http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_arc_page.htm ) does all of this and more. The tools will do a hipped roof made from a selected horizontal face - it can be connected to others as only its edges are needed - it's ignored afterwards: one face only - not with inner holes! Note that some shapes - like a crooked star - cannot have a single-pitch hipped roof - needs impossible 3D geometry...
                  There are other tools in the set to make mansard/sprocketed roofs, gabled and pyramid roofs and also get roof face slopes.
                  The tools' dialogs allow you to specify angle or pitch or height/eaves/fascia/soffit/verge/type/materials/layer etc as appropriate. Also including sloping and orthogonal fascia/soffit and different gable types at each end, and differ materials for each part e.g. fascia/soffit/slope/gable etc. There is also a help file out there...
                    gohch
                    hi Thomthom,
                    I was working on the idea of generating hiproof from just a single face. Come to think of it now, that's really quite limited. I'll improve it.
                    hi TIG, always good to know that there's more than 1 solution to a problem.
                    cheers! πŸ˜„
                      hi Thomthom,
                      cheers! πŸ˜„
                      Well, I did have only one face selected. But when it is connected to other, the script refuse to use it.
                        gohch
                        Yep, Thomthom, that's the part that i didn't take into account and definitely should improve on. πŸ˜‰
                        cheers!
                          tiriki
                          @tiriki said:
                          Hi Gohch!
                          I bought the users license for 1001bit... I received the email whit the activation key... but when I activate the license and I close and restart SU the license still appears as trial.
                          In the 1001bit folder is been created the file: 1001bit.key
                          What do I have to do to activate the licens?
                          Thank's a lot!
                          Hi Tiriki,
                          Sorry, didn't check on this forum past few days. Saw your email today and emailed the 1001bit.key file to you. That should solve the issue. Feel free to drop me a note if there's any issue. Thanks
                          Hi Gohch!
                          I received the email, thank's for the file πŸ˜‰
                          It works very well now, I find it very useful!
                            gohch
                            Hi everyone,
                            1001bit tools is now possible for different languages! πŸ˜„
                            A new language pack function is added into version 1.1.5, which allows for automatic translation of the dialog boxes, status bar, tooltips and error messages into your local languages.
                            http://www.1001bit.com/language_pack/v1.1/images/dialog-cn.jpg
                            hip roof dialog in Chinese Simplified - courtesy of purplewind
                            http://www.1001bit.com/language_pack/v1.1/images/dialog-jp.jpg
                            hip roof dialog in Japanese - courtesy of Takeshi
                            Here's how it works
                            In version 1.1.5, there's an additional language folder inside the 1001bit folder.
                            http://www.1001bit.com/language_pack/v1.1/images/language_folder.jpg
                            inside the language folder, there's a collection of text files (.txt) which contains the language translation.
                            http://www.1001bit.com/language_pack/v1.1/images/sample_cn.gif
                            translation courtesy of purplewind
                            The format of the translation is
                            id>>english>>translation
                            Just use a text editor to edit the .txt file and save it.
                            You may need to try saving the file in different format, for example, the Chinese version has to be saved in UTF-8 format for it to work properly on a Mac (English).
                            The first full translation into Chinese Simplified language has been completed and tested by purplewind of club.sketchupbar.com
                            http://www.1001bit.com/discussions/viewforum.php?f=17
                            Special thanks to Purplewind for his hardwork!
                            by the way, the 1001bit_tools.rbs file in the Plugins folder needs to be replaced with the latest. Otherwise you'll see a lot of errors!
                              gohch
                              hi guys,
                              I have modified the 1001bit_tools.rb to automatically look for the files in SU's Plugins/1001bit folder regardless of Windows or Mac.
                              if it cannot find the files, it then search for c:\1001bit.com
                              So, the setting up can be simplified to
                              Step 1: put the 1001bit folder in SU's Plugins folder
                              Step 2: copy the 1001bit_tools.rb file into the Plugins folder
                              Appreciate if you guys can test this for me:
                              Attached zip file contains 2 files,
                              1001bitmenu.rbs file
                              1001bit_tools.rb
                              1. Please overwrite the 1001bitmenu.rbs file (must be version 1.1.5)
                              2. remove the 1001bit_tools.rbs file , and use the 1001bit_tools.rb in your Plugins folder instead.
                              3. remove any file that indicates the path, like 1001bit_path_.....rb
                              In this case, the 1001bit folder must be in your Plugins folder.
                              Thanks and appreciate all feedbacks
                              patch for testing 1001bit default path
                                I advanced the French version! β˜€
                                Tell you when it's finished πŸ˜‰
                                  gohch
                                  Great Pilou,
                                  really looking forward to see 1001bit in more different languages! πŸŽ‰
                                    @GOHCH
                                    French translation done β˜€
                                    See your PM system at PushPullbar πŸ˜‰
                                    See your forum for images & questions πŸ˜„
                                      gohch
                                      hi Pilou,
                                      Thanks so much for your efforts!
                                      1. Tooltip text: Seems like there is a maximum of 79 characters in the tooltip. I couldn't get it to do more, and couldn't get it to do multi lines of text.
                                        Has anyone come across a tooltip with multi lines of text?
                                      2. The Escalator title: tracked down the problem. It's that little Apostrophe (')
                                        title>>Create Escalator>>CrΓ©ation d'Escalator
                                        when Javascript sees a apostrophe('), it interprets as the beginning of another string and caused an error.
                                        The translator defaults back to English when there's an error getting the translation.
                                        Adding a back slash in front of it will get it to be interpreted correctly.
                                      escalator title translated correctly with
                                      cheers!
                                      Goh
                                        OK! So some modify to make πŸ˜„
                                          @GOHCH
                                          See your forum for little problems πŸ˜‰
                                          • Z Offline
                                            zfconnor
                                            Thank you for your effort.
                                            • 12
                                            • 13
                                            • 5 / 13
