    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    245 Posts 66 Posters 283.8k Views 66 Watching
      My Roof.rb (v3 http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_arc_page.htm ) does all of this and more. The tools will do a hipped roof made from a selected horizontal face - it can be connected to others as only its edges are needed - it's ignored afterwards: one face only - not with inner holes! Note that some shapes - like a crooked star - cannot have a single-pitch hipped roof - needs impossible 3D geometry...
      There are other tools in the set to make mansard/sprocketed roofs, gabled and pyramid roofs and also get roof face slopes.
      The tools' dialogs allow you to specify angle or pitch or height/eaves/fascia/soffit/verge/type/materials/layer etc as appropriate. Also including sloping and orthogonal fascia/soffit and different gable types at each end, and differ materials for each part e.g. fascia/soffit/slope/gable etc. There is also a help file out there...
      • G
        gohch
        hi Thomthom,
        I was working on the idea of generating hiproof from just a single face. Come to think of it now, that's really quite limited. I'll improve it.
        hi TIG, always good to know that there's more than 1 solution to a problem.
        cheers! πŸ˜„
          hi Thomthom,
          cheers! πŸ˜„
          Well, I did have only one face selected. But when it is connected to other, the script refuse to use it.
          • G
            gohch
            Yep, Thomthom, that's the part that i didn't take into account and definitely should improve on. πŸ˜‰
            cheers!
            • T
              tiriki
              @tiriki said:
              Hi Gohch!
              I bought the users license for 1001bit... I received the email whit the activation key... but when I activate the license and I close and restart SU the license still appears as trial.
              In the 1001bit folder is been created the file: 1001bit.key
              What do I have to do to activate the licens?
              Thank's a lot!
              Hi Tiriki,
              Sorry, didn't check on this forum past few days. Saw your email today and emailed the 1001bit.key file to you. That should solve the issue. Feel free to drop me a note if there's any issue. Thanks
              Hi Gohch!
              I received the email, thank's for the file πŸ˜‰
              It works very well now, I find it very useful!
              • G
                gohch
                Hi everyone,
                1001bit tools is now possible for different languages! πŸ˜„
                A new language pack function is added into version 1.1.5, which allows for automatic translation of the dialog boxes, status bar, tooltips and error messages into your local languages.
                http://www.1001bit.com/language_pack/v1.1/images/dialog-cn.jpg
                hip roof dialog in Chinese Simplified - courtesy of purplewind
                http://www.1001bit.com/language_pack/v1.1/images/dialog-jp.jpg
                hip roof dialog in Japanese - courtesy of Takeshi
                Here's how it works
                In version 1.1.5, there's an additional language folder inside the 1001bit folder.
                http://www.1001bit.com/language_pack/v1.1/images/language_folder.jpg
                inside the language folder, there's a collection of text files (.txt) which contains the language translation.
                http://www.1001bit.com/language_pack/v1.1/images/sample_cn.gif
                translation courtesy of purplewind
                The format of the translation is
                id>>english>>translation
                Just use a text editor to edit the .txt file and save it.
                You may need to try saving the file in different format, for example, the Chinese version has to be saved in UTF-8 format for it to work properly on a Mac (English).
                The first full translation into Chinese Simplified language has been completed and tested by purplewind of club.sketchupbar.com
                http://www.1001bit.com/discussions/viewforum.php?f=17
                Special thanks to Purplewind for his hardwork!
                by the way, the 1001bit_tools.rbs file in the Plugins folder needs to be replaced with the latest. Otherwise you'll see a lot of errors!
                • G
                  gohch
                  hi guys,
                  I have modified the 1001bit_tools.rb to automatically look for the files in SU's Plugins/1001bit folder regardless of Windows or Mac.
                  if it cannot find the files, it then search for c:\1001bit.com
                  So, the setting up can be simplified to
                  Step 1: put the 1001bit folder in SU's Plugins folder
                  Step 2: copy the 1001bit_tools.rb file into the Plugins folder
                  Appreciate if you guys can test this for me:
                  Attached zip file contains 2 files,
                  1001bitmenu.rbs file
                  1001bit_tools.rb
                  1. Please overwrite the 1001bitmenu.rbs file (must be version 1.1.5)
                  2. remove the 1001bit_tools.rbs file , and use the 1001bit_tools.rb in your Plugins folder instead.
                  3. remove any file that indicates the path, like 1001bit_path_.....rb
                  In this case, the 1001bit folder must be in your Plugins folder.
                  Thanks and appreciate all feedbacks
                  patch for testing 1001bit default path
                    I advanced the French version! β˜€
                    Tell you when it's finished πŸ˜‰
                    • G
                      gohch
                      Great Pilou,
                      really looking forward to see 1001bit in more different languages! πŸŽ‰
                        @GOHCH
                        French translation done β˜€
                        See your PM system at PushPullbar πŸ˜‰
                        See your forum for images & questions πŸ˜„
                        • G
                          gohch
                          hi Pilou,
                          Thanks so much for your efforts!
                          1. Tooltip text: Seems like there is a maximum of 79 characters in the tooltip. I couldn't get it to do more, and couldn't get it to do multi lines of text.
                            Has anyone come across a tooltip with multi lines of text?
                          2. The Escalator title: tracked down the problem. It's that little Apostrophe (')
                            title>>Create Escalator>>CrΓ©ation d'Escalator
                            when Javascript sees a apostrophe('), it interprets as the beginning of another string and caused an error.
                            The translator defaults back to English when there's an error getting the translation.
                            Adding a back slash in front of it will get it to be interpreted correctly.
                          escalator title translated correctly with
                          cheers!
                          Goh
                            OK! So some modify to make πŸ˜„
                              @GOHCH
                              See your forum for little problems πŸ˜‰
                              • Z
                                zfconnor
                                Thank you for your effort.
                                • P
                                  publied
                                  very nice library! great job.
                                  hire me@ http://www.publied.it !
                                  • G
                                    gohch
                                    😍 Thanks to Frenchy Pilou's hardwork, 😍
                                    the French language pack for 1001bit tools is now ready for download!
                                    http://www.1001bit.com/language_pack/v1.1/fr/1001bit_v1.1_language_fr_pilou.zip
                                    Some of the dialog boxes may be insufficiently sized to accomodate all the French languages. Please bear with this for another 2-3 weeks. I'll issue a version 1.1.6 update soon that addresses resizing of dialog boxes as well as installation path automatic settings.
                                    Again, Thanks Frenchy Pilou
                                      πŸ˜„ πŸ˜‰ β˜€ 😎
                                      • P
                                        putnik
                                        GOHCH, 1001bit_patch(3-May-09).zip works fine for me. WinXP SP3. Russian language translation is a work in progress at the moment at stroyka.cc
                                        http://keshas.info
                                        • G
                                          gohch
                                          Thanks Putnik, for testing out the patch. πŸ˜„
                                          I'm really excited πŸŽ‰ to see someone doing a Russian language pack.
                                          I've placed a link on 1001bit.com pointing to Stroyka forum for anyone who is interested in the Russian language pack.
                                          http://www.1001bit.com/discussions/viewtopic.php?f=17&t=52
                                          • G
                                            gohch
                                            hi guys!
                                            Thanks to Oxer, there is now a Spanish language pack!!!
                                            http://www.1001bit.com/discussions/viewtopic.php?f=17&t=54
                                            Thank you Oxer for sharing your hardwork! πŸ‘
                                            • 12
                                            • 13
                                            • 6 / 13
