    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    245 Posts 66 Posters 265.5k Views 66 Watching
      tiriki
      @tiriki said:
      Hi Gohch!
      I bought the users license for 1001bit... I received the email whit the activation key... but when I activate the license and I close and restart SU the license still appears as trial.
      In the 1001bit folder is been created the file: 1001bit.key
      What do I have to do to activate the licens?
      Thank's a lot!
      Hi Tiriki,
      Sorry, didn't check on this forum past few days. Saw your email today and emailed the 1001bit.key file to you. That should solve the issue. Feel free to drop me a note if there's any issue. Thanks
      Hi Gohch!
      I received the email, thank's for the file πŸ˜‰
      It works very well now, I find it very useful!
        gohch
        Hi everyone,
        1001bit tools is now possible for different languages! πŸ˜„
        A new language pack function is added into version 1.1.5, which allows for automatic translation of the dialog boxes, status bar, tooltips and error messages into your local languages.
        http://www.1001bit.com/language_pack/v1.1/images/dialog-cn.jpg
        hip roof dialog in Chinese Simplified - courtesy of purplewind
        http://www.1001bit.com/language_pack/v1.1/images/dialog-jp.jpg
        hip roof dialog in Japanese - courtesy of Takeshi
        Here's how it works
        In version 1.1.5, there's an additional language folder inside the 1001bit folder.
        http://www.1001bit.com/language_pack/v1.1/images/language_folder.jpg
        inside the language folder, there's a collection of text files (.txt) which contains the language translation.
        http://www.1001bit.com/language_pack/v1.1/images/sample_cn.gif
        translation courtesy of purplewind
        The format of the translation is
        id>>english>>translation
        Just use a text editor to edit the .txt file and save it.
        You may need to try saving the file in different format, for example, the Chinese version has to be saved in UTF-8 format for it to work properly on a Mac (English).
        The first full translation into Chinese Simplified language has been completed and tested by purplewind of club.sketchupbar.com
        http://www.1001bit.com/discussions/viewforum.php?f=17
        Special thanks to Purplewind for his hardwork!
        by the way, the 1001bit_tools.rbs file in the Plugins folder needs to be replaced with the latest. Otherwise you'll see a lot of errors!
          gohch
          hi guys,
          I have modified the 1001bit_tools.rb to automatically look for the files in SU's Plugins/1001bit folder regardless of Windows or Mac.
          if it cannot find the files, it then search for c:\1001bit.com
          So, the setting up can be simplified to
          Step 1: put the 1001bit folder in SU's Plugins folder
          Step 2: copy the 1001bit_tools.rb file into the Plugins folder
          Appreciate if you guys can test this for me:
          Attached zip file contains 2 files,
          1001bitmenu.rbs file
          1001bit_tools.rb
          1. Please overwrite the 1001bitmenu.rbs file (must be version 1.1.5)
          2. remove the 1001bit_tools.rbs file , and use the 1001bit_tools.rb in your Plugins folder instead.
          3. remove any file that indicates the path, like 1001bit_path_.....rb
          In this case, the 1001bit folder must be in your Plugins folder.
          Thanks and appreciate all feedbacks
          patch for testing 1001bit default path
            I advanced the French version! β˜€
            Tell you when it's finished πŸ˜‰
              gohch
              Great Pilou,
              really looking forward to see 1001bit in more different languages! πŸŽ‰
                @GOHCH
                French translation done β˜€
                See your PM system at PushPullbar πŸ˜‰
                See your forum for images & questions πŸ˜„
                  gohch
                  hi Pilou,
                  Thanks so much for your efforts!
                  1. Tooltip text: Seems like there is a maximum of 79 characters in the tooltip. I couldn't get it to do more, and couldn't get it to do multi lines of text.
                    Has anyone come across a tooltip with multi lines of text?
                  2. The Escalator title: tracked down the problem. It's that little Apostrophe (')
                    title>>Create Escalator>>CrΓ©ation d'Escalator
                    when Javascript sees a apostrophe('), it interprets as the beginning of another string and caused an error.
                    The translator defaults back to English when there's an error getting the translation.
                    Adding a back slash in front of it will get it to be interpreted correctly.
                  escalator title translated correctly with
                  cheers!
                  Goh
                    OK! So some modify to make πŸ˜„
                      @GOHCH
                      See your forum for little problems πŸ˜‰
                      • Z Offline
                        zfconnor
                        Thank you for your effort.
                          publied
                          very nice library! great job.
                          hire me@ http://www.publied.it !
                            gohch
                            😍 Thanks to Frenchy Pilou's hardwork, 😍
                            the French language pack for 1001bit tools is now ready for download!
                            http://www.1001bit.com/language_pack/v1.1/fr/1001bit_v1.1_language_fr_pilou.zip
                            Some of the dialog boxes may be insufficiently sized to accomodate all the French languages. Please bear with this for another 2-3 weeks. I'll issue a version 1.1.6 update soon that addresses resizing of dialog boxes as well as installation path automatic settings.
                            Again, Thanks Frenchy Pilou
                              πŸ˜„ πŸ˜‰ β˜€ 😎
                                putnik
                                GOHCH, 1001bit_patch(3-May-09).zip works fine for me. WinXP SP3. Russian language translation is a work in progress at the moment at stroyka.cc
                                http://keshas.info
                                  gohch
                                  Thanks Putnik, for testing out the patch. πŸ˜„
                                  I'm really excited πŸŽ‰ to see someone doing a Russian language pack.
                                  I've placed a link on 1001bit.com pointing to Stroyka forum for anyone who is interested in the Russian language pack.
                                  http://www.1001bit.com/discussions/viewtopic.php?f=17&t=52
                                    gohch
                                    hi guys!
                                    Thanks to Oxer, there is now a Spanish language pack!!!
                                    http://www.1001bit.com/discussions/viewtopic.php?f=17&t=54
                                    Thank you Oxer for sharing your hardwork! πŸ‘
                                    • F Offline
                                      fozmicro
                                      Hello!!!!
                                      I think interesting a portuguese (br) translation pack
                                      • BurkhardB Offline
                                        Burkhard
                                        German language ready, including image changes. Should come soon πŸ˜„
                                        Have fun
                                        http://www.ia-plus.de
                                          gohch
                                          Hi guys, 2 more language packs ready for download!!!
                                          Spanish language pack, thanks to Oxer's hardwork πŸ‘ πŸ‘ πŸ‘
                                          German language pack, thanks to Burkhard's hardwork πŸ‘ πŸ‘ πŸ‘
                                          http://www.1001bit.com/discussions/viewtopic.php?f=17&t=55
                                          And... Portugues language pack coming soon... courtesy of fozmicro. πŸ‘ πŸ‘ πŸ‘
                                          It's really encouraging for me to see different people translating 1001bit tools into different languages.
                                          Many many thanks to everyone's hardwork and support!!!
                                          GohCH
                                          • F Offline
                                            fozmicro
                                            20% complete translation from portugues (br).
                                            πŸ€“
                                            • 12
                                            • 13
                                            • 6 / 13
