    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    245 Posts 66 Posters 272.8k Views 66 Watching
      gohch
      hi Thomthom,
      I was working on the idea of generating hiproof from just a single face. Come to think of it now, that's really quite limited. I'll improve it.
      hi TIG, always good to know that there's more than 1 solution to a problem.
      cheers! πŸ˜„
        hi Thomthom,
        cheers! πŸ˜„
        Well, I did have only one face selected. But when it is connected to other, the script refuse to use it.
          gohch
          Yep, Thomthom, that's the part that i didn't take into account and definitely should improve on. πŸ˜‰
          cheers!
            tiriki
            @tiriki said:
            Hi Gohch!
            I bought the users license for 1001bit... I received the email whit the activation key... but when I activate the license and I close and restart SU the license still appears as trial.
            In the 1001bit folder is been created the file: 1001bit.key
            What do I have to do to activate the licens?
            Thank's a lot!
            Hi Tiriki,
            Sorry, didn't check on this forum past few days. Saw your email today and emailed the 1001bit.key file to you. That should solve the issue. Feel free to drop me a note if there's any issue. Thanks
            Hi Gohch!
            I received the email, thank's for the file πŸ˜‰
            It works very well now, I find it very useful!
              gohch
              Hi everyone,
              1001bit tools is now possible for different languages! πŸ˜„
              A new language pack function is added into version 1.1.5, which allows for automatic translation of the dialog boxes, status bar, tooltips and error messages into your local languages.
              http://www.1001bit.com/language_pack/v1.1/images/dialog-cn.jpg
              hip roof dialog in Chinese Simplified - courtesy of purplewind
              http://www.1001bit.com/language_pack/v1.1/images/dialog-jp.jpg
              hip roof dialog in Japanese - courtesy of Takeshi
              Here's how it works
              In version 1.1.5, there's an additional language folder inside the 1001bit folder.
              http://www.1001bit.com/language_pack/v1.1/images/language_folder.jpg
              inside the language folder, there's a collection of text files (.txt) which contains the language translation.
              http://www.1001bit.com/language_pack/v1.1/images/sample_cn.gif
              translation courtesy of purplewind
              The format of the translation is
              id>>english>>translation
              Just use a text editor to edit the .txt file and save it.
              You may need to try saving the file in different format, for example, the Chinese version has to be saved in UTF-8 format for it to work properly on a Mac (English).
              The first full translation into Chinese Simplified language has been completed and tested by purplewind of club.sketchupbar.com
              http://www.1001bit.com/discussions/viewforum.php?f=17
              Special thanks to Purplewind for his hardwork!
              by the way, the 1001bit_tools.rbs file in the Plugins folder needs to be replaced with the latest. Otherwise you'll see a lot of errors!
                gohch
                hi guys,
                I have modified the 1001bit_tools.rb to automatically look for the files in SU's Plugins/1001bit folder regardless of Windows or Mac.
                if it cannot find the files, it then search for c:\1001bit.com
                So, the setting up can be simplified to
                Step 1: put the 1001bit folder in SU's Plugins folder
                Step 2: copy the 1001bit_tools.rb file into the Plugins folder
                Appreciate if you guys can test this for me:
                Attached zip file contains 2 files,
                1001bitmenu.rbs file
                1001bit_tools.rb
                1. Please overwrite the 1001bitmenu.rbs file (must be version 1.1.5)
                2. remove the 1001bit_tools.rbs file , and use the 1001bit_tools.rb in your Plugins folder instead.
                3. remove any file that indicates the path, like 1001bit_path_.....rb
                In this case, the 1001bit folder must be in your Plugins folder.
                Thanks and appreciate all feedbacks
                patch for testing 1001bit default path
                  I advanced the French version! β˜€
                  Tell you when it's finished πŸ˜‰
                    gohch
                    Great Pilou,
                    really looking forward to see 1001bit in more different languages! πŸŽ‰
                      @GOHCH
                      French translation done β˜€
                      See your PM system at PushPullbar πŸ˜‰
                      See your forum for images & questions πŸ˜„
                        gohch
                        hi Pilou,
                        Thanks so much for your efforts!
                        1. Tooltip text: Seems like there is a maximum of 79 characters in the tooltip. I couldn't get it to do more, and couldn't get it to do multi lines of text.
                          Has anyone come across a tooltip with multi lines of text?
                        2. The Escalator title: tracked down the problem. It's that little Apostrophe (')
                          title>>Create Escalator>>CrΓ©ation d'Escalator
                          when Javascript sees a apostrophe('), it interprets as the beginning of another string and caused an error.
                          The translator defaults back to English when there's an error getting the translation.
                          Adding a back slash in front of it will get it to be interpreted correctly.
                        escalator title translated correctly with
                        cheers!
                        Goh
                          OK! So some modify to make πŸ˜„
                            @GOHCH
                            See your forum for little problems πŸ˜‰
                            • Z Offline
                              zfconnor
                              Thank you for your effort.
                                publied
                                very nice library! great job.
                                hire me@ http://www.publied.it !
                                  gohch
                                  😍 Thanks to Frenchy Pilou's hardwork, 😍
                                  the French language pack for 1001bit tools is now ready for download!
                                  http://www.1001bit.com/language_pack/v1.1/fr/1001bit_v1.1_language_fr_pilou.zip
                                  Some of the dialog boxes may be insufficiently sized to accomodate all the French languages. Please bear with this for another 2-3 weeks. I'll issue a version 1.1.6 update soon that addresses resizing of dialog boxes as well as installation path automatic settings.
                                  Again, Thanks Frenchy Pilou
                                    πŸ˜„ πŸ˜‰ β˜€ 😎
                                      putnik
                                      GOHCH, 1001bit_patch(3-May-09).zip works fine for me. WinXP SP3. Russian language translation is a work in progress at the moment at stroyka.cc
                                      http://keshas.info
                                        gohch
                                        Thanks Putnik, for testing out the patch. πŸ˜„
                                        I'm really excited πŸŽ‰ to see someone doing a Russian language pack.
                                        I've placed a link on 1001bit.com pointing to Stroyka forum for anyone who is interested in the Russian language pack.
                                        http://www.1001bit.com/discussions/viewtopic.php?f=17&t=52
                                          gohch
                                          hi guys!
                                          Thanks to Oxer, there is now a Spanish language pack!!!
                                          http://www.1001bit.com/discussions/viewtopic.php?f=17&t=54
                                          Thank you Oxer for sharing your hardwork! πŸ‘
                                          • F Offline
                                            fozmicro
                                            Hello!!!!
                                            I think interesting a portuguese (br) translation pack
                                            • 12
                                            • 13
                                            • 6 / 13
