    Vray reflection mapping
    renderpluginsextensions
    55 Posts 8 Posters 27.1k Views 8 Watching
      Yea, the forum just went down. At least from the default URL. You can access it from this alternative URL which works: http://asgvis.com/smf/index.php
      I tried searching for the thread you mentioned. But I couldn't find it. Found a different thread though related to specular reflections.
      http://asgvis.com/smf/index.php?topic=2248.msg11150
      • StinkieS Offline
        Stinkie
        Odd. Stefan's solution differs from JoeB's.
        Edit: I can see you, FA! Give up yer secrets! 😉
          Seems there's many ways to apply specular maps.
          I figured it'd be of interest to see the reply of one of the ASGVis employees.
          • stefanqS Offline
            stefanq
            Thanks for the link Thomas, here the link for my post....sorry for schrolling...it's on page 2..
            http://asgvis.com/smf/index.php?topic=4089.15
            Stinkie, yes, it's odd, but it's working.Check the link above.
            EDIT: the post it's about HDRI, but on page 2, almost at the bottom, I have some images about specular maps.
            • stefanqS Offline
              stefanq
              OK, I did another test...just to be sure it's still working 😆
              I have a diffuse layer with the color, and another one ( ghost layer) witch it's transparent, for helping vray to set the correct UV for the specular map.
              http://img211.imageshack.us/img211/9537/specular.th.jpg
              • StinkieS Offline
                Stinkie
                Yeah, that'd be nice.
                  JoeB was that reply. 😉
                  • StinkieS Offline
                    Stinkie
                    lol. Nevertheless I'd like to see, say, Damien Alomar elaborate on this issue. He usually does a good job explaining things.
                      Yup. His replies are valuable gems. I've been meaning to collect some of them into a tips/tricks post.
                      • StinkieS Offline
                        Stinkie
                        Whoa! Err ... dankie? Dankiewel? Whatever - thanks!
                        • free agentF Offline
                          free agent
                          hey i did a quick test after thomthom PM'd me on the matter, the thing about spec maps is u only notice them in shaded area where the light would hit them where they not in shadow.
                          raw render:
                          http://i167.photobucket.com/albums/u143/FreeAgent84/test01.jpg
                          notice how the walls facing the camera get less reflection than the ones perpendicular to those, this is the fresnel effect, so a couple of things need to come togther in order to achieve this effect.
                          the refelction channel:
                          http://i167.photobucket.com/albums/u143/FreeAgent84/test01reflection.jpg
                          tip: in photoshop overlay the reflection channel over the render and make the layer mode: SCREEN, this will increase the reflection of the raw render.
                          i attached the plaster vismat i made from a cgtextures image... and the model, so u can go through the material to see how its made. the spec map is placed under the fresnel image slot.
                          Plaster rough_1.zip
                          SPECMOD.rar
                          http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                            free agent
                            haha dis 'n plesier.
                            • ibonI Offline
                              ibon
                              Guys, really, really Thanks
                              Freeagent, now with the scene on my hands everything's clear. Thanks everyone for taking so much time with this. I wish some day i will help you as you have helped me
                                Did a little test scene. Used an HDRI as I wanted to get a colour tint to the lighting. Too bad the Sun shadows are gone. (If I remember correctly, I can get them if I turn on default light and decrease the GI light while also adjusting the camera exposure.)
                                • ibonI Offline
                                  ibon
                                  Very beautiful scene thomthom. I have tried to make my own with an HDRI map but after more than 10 trial errors can't get the desired position for my sun. Is any easyer method to quickly position your hdri?
                                    Hide all geometry, or do material override so it renders quickly and then do a few trial and errors of the HDRI horizontal position. Or you could do what Richard do; quite nice setup: http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=18001&p=145253
                                    Note that you won't have much luck if you try to adjust the vertical position of the SUN source from and HDRI. That will just mess things up.
                                    • N Offline
                                      nomeradona
                                      yeap, whenever damien reply assurely my eyes are there...
                                      • N Offline
                                        nomeradona
                                        Oh thank God FA is here to give some explanation about this.
                                        hey stinkie are you saying FA is a donkey? lol.
                                        • N Offline
                                          nomeradona
                                          thats a cool linking render Thom
                                            What I'd like to know is how to create a render with a tinted sun but with sun shadows as in the picture posted by the original poster. Anyone got some tips?
                                            • 2 / 3
