    Vray reflection mapping
    renderpluginsextensions
    55 Posts 8 Posters 28.7k Views 8 Watching
      Did a quick little test.
      I think bumpmap and filter maps would work. The V-Ray manual says that the filter slot is to apply colour to the refletion, but if you use grayscale images it will control the 'opacity' of the reflection as well. It's easier to use the filter slot when you have fresnel reflection map.
      • StinkieS
        Stinkie
        I'm guessing Ibon wants to know how to use specular maps in VfSU. Which is something I'd like to know as well.
        Where's FreeAgent when you need him? 😄
        • K
          kwistenbiebel
          That would indeed be helpful.
          Not once, I succeeded in getting specular maps in properly using VfSU. I tried numerous times setting up a decent arroway material (they come with spec map) but never with the desired result.
          • ibonI
            ibon
            Sorry for my late answer. Thanks all for your interest and help. I have never used the "reflection per texture method", so i'm learning a lot in this thread. And yes, stinkie, that's exactly what i'm looking for, i didn't know it's name (specular maps). I have some arroway materials too kwistenbiebel, and they are the reason of my search. They came with diff, bump/disp and other one (now i know it's specular), and i wanted to know if it's possible to use in VfSU. Sorry again not for being clear when speaking english
            • stefanqS
              stefanq
              Ibon, I have an old post on asgvis, about specular maps, but for some reason, I can't access the site. But,I can tell you where I put specular maps, and it's fine. First , make a reflection layer for your material, then, go to reflection/M/(here you have fresnel)/put your map in the "fresnel color"
              I recommend you to use just reflections and specular without bump, to see if it's working. If it's OK, then you can use bump too!
              Good Luck!
                Yea, the forum just went down. At least from the default URL. You can access it from this alternative URL which works: http://asgvis.com/smf/index.php
                I tried searching for the thread you mentioned. But I couldn't find it. Found a different thread though related to specular reflections.
                http://asgvis.com/smf/index.php?topic=2248.msg11150
                • StinkieS
                  Stinkie
                  Odd. Stefan's solution differs from JoeB's.
                  Edit: I can see you, FA! Give up yer secrets! 😉
                    Seems there's many ways to apply specular maps.
                    I figured it'd be of interest to see the reply of one of the ASGVis employees.
                    • stefanqS
                      stefanq
                      Thanks for the link Thomas, here the link for my post....sorry for schrolling...it's on page 2..
                      http://asgvis.com/smf/index.php?topic=4089.15
                      Stinkie, yes, it's odd, but it's working.Check the link above.
                      EDIT: the post it's about HDRI, but on page 2, almost at the bottom, I have some images about specular maps.
                      • stefanqS
                        stefanq
                        OK, I did another test...just to be sure it's still working 😆
                        I have a diffuse layer with the color, and another one ( ghost layer) witch it's transparent, for helping vray to set the correct UV for the specular map.
                        http://img211.imageshack.us/img211/9537/specular.th.jpg
                        • StinkieS
                          Stinkie
                          Yeah, that'd be nice.
                            JoeB was that reply. 😉
                            • StinkieS
                              Stinkie
                              lol. Nevertheless I'd like to see, say, Damien Alomar elaborate on this issue. He usually does a good job explaining things.
                                Yup. His replies are valuable gems. I've been meaning to collect some of them into a tips/tricks post.
                                • StinkieS
                                  Stinkie
                                  Whoa! Err ... dankie? Dankiewel? Whatever - thanks!
                                  • free agentF
                                    free agent
                                    hey i did a quick test after thomthom PM'd me on the matter, the thing about spec maps is u only notice them in shaded area where the light would hit them where they not in shadow.
                                    raw render:
                                    http://i167.photobucket.com/albums/u143/FreeAgent84/test01.jpg
                                    notice how the walls facing the camera get less reflection than the ones perpendicular to those, this is the fresnel effect, so a couple of things need to come togther in order to achieve this effect.
                                    the refelction channel:
                                    http://i167.photobucket.com/albums/u143/FreeAgent84/test01reflection.jpg
                                    tip: in photoshop overlay the reflection channel over the render and make the layer mode: SCREEN, this will increase the reflection of the raw render.
                                    i attached the plaster vismat i made from a cgtextures image... and the model, so u can go through the material to see how its made. the spec map is placed under the fresnel image slot.
                                    Plaster rough_1.zip
                                    SPECMOD.rar
                                    http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                                    • free agentF
                                      free agent
                                      haha dis 'n plesier.
                                      • ibonI
                                        ibon
                                        Guys, really, really Thanks
                                        Freeagent, now with the scene on my hands everything's clear. Thanks everyone for taking so much time with this. I wish some day i will help you as you have helped me
                                          Did a little test scene. Used an HDRI as I wanted to get a colour tint to the lighting. Too bad the Sun shadows are gone. (If I remember correctly, I can get them if I turn on default light and decrease the GI light while also adjusting the camera exposure.)
                                          • ibonI
                                            ibon
                                            Very beautiful scene thomthom. I have tried to make my own with an HDRI map but after more than 10 trial errors can't get the desired position for my sun. Is any easyer method to quickly position your hdri?
                                            • 2 / 3
