    Vray reflection mapping
    renderpluginsextensions
    55 Posts 8 Posters 27.8k Views 8 Watching
    • soloS
      Reflection slot, you can add in filter slot? 😳
        In regards to the original poster.
          Just to point out. There's a difference between the Reflection slot in the Maps section and the one in the Reflection layer.
          The Maps reflection is to override what the Reflection layer should reflect. The Reflection layer controls how the reflection should behave.
          • K
            kwistenbiebel
            Ibon andSolo,
            Try to increase the multiplier of the reflection slot to 30000 or higher.
            You should be seeing some results..
            I don't think however VfSU can produce an image as the example here. Therefore we would need a Sun object in a HDR combo , a thing that is virtually impossible in the sketchup version.
            A lot of people asked to have a 'posable' sun object, but somehow Asgvis considers it not possible to implement.
            It would be the solution for a lot of sun/sky light trouble though.
              @kwistenbiebel said:
              Ibon andSolo,
              Don't think it'll help ibon. They don't have the same issue.
              • K
                kwistenbiebel
                You're right Thomas.
                I was a bit too hasty in my response. I described the way to handle reflections in a global way...
                Never tried the 'per texture' method so I follow this thread with great intrest.
                  Did a quick little test.
                  I think bumpmap and filter maps would work. The V-Ray manual says that the filter slot is to apply colour to the refletion, but if you use grayscale images it will control the 'opacity' of the reflection as well. It's easier to use the filter slot when you have fresnel reflection map.
                  • StinkieS
                    Stinkie
                    I'm guessing Ibon wants to know how to use specular maps in VfSU. Which is something I'd like to know as well.
                    Where's FreeAgent when you need him? 😄
                    • K
                      kwistenbiebel
                      That would indeed be helpful.
                      Not once, I succeeded in getting specular maps in properly using VfSU. I tried numerous times setting up a decent arroway material (they come with spec map) but never with the desired result.
                      • ibonI
                        ibon
                        Sorry for my late answer. Thanks all for your interest and help. I have never used the "reflection per texture method", so i'm learning a lot in this thread. And yes, stinkie, that's exactly what i'm looking for, i didn't know it's name (specular maps). I have some arroway materials too kwistenbiebel, and they are the reason of my search. They came with diff, bump/disp and other one (now i know it's specular), and i wanted to know if it's possible to use in VfSU. Sorry again not for being clear when speaking english
                        • stefanqS
                          stefanq
                          Ibon, I have an old post on asgvis, about specular maps, but for some reason, I can't access the site. But,I can tell you where I put specular maps, and it's fine. First , make a reflection layer for your material, then, go to reflection/M/(here you have fresnel)/put your map in the "fresnel color"
                          I recommend you to use just reflections and specular without bump, to see if it's working. If it's OK, then you can use bump too!
                          Good Luck!
                            Yea, the forum just went down. At least from the default URL. You can access it from this alternative URL which works: http://asgvis.com/smf/index.php
                            I tried searching for the thread you mentioned. But I couldn't find it. Found a different thread though related to specular reflections.
                            http://asgvis.com/smf/index.php?topic=2248.msg11150
                            • StinkieS
                              Stinkie
                              Odd. Stefan's solution differs from JoeB's.
                              Edit: I can see you, FA! Give up yer secrets! 😉
                                Seems there's many ways to apply specular maps.
                                I figured it'd be of interest to see the reply of one of the ASGVis employees.
                                • stefanqS
                                  stefanq
                                  Thanks for the link Thomas, here the link for my post....sorry for schrolling...it's on page 2..
                                  http://asgvis.com/smf/index.php?topic=4089.15
                                  Stinkie, yes, it's odd, but it's working.Check the link above.
                                  EDIT: the post it's about HDRI, but on page 2, almost at the bottom, I have some images about specular maps.
                                  • stefanqS
                                    stefanq
                                    OK, I did another test...just to be sure it's still working 😆
                                    I have a diffuse layer with the color, and another one ( ghost layer) witch it's transparent, for helping vray to set the correct UV for the specular map.
                                    http://img211.imageshack.us/img211/9537/specular.th.jpg
                                    • StinkieS
                                      Stinkie
                                      Yeah, that'd be nice.
                                        JoeB was that reply. 😉
                                        • StinkieS
                                          Stinkie
                                          lol. Nevertheless I'd like to see, say, Damien Alomar elaborate on this issue. He usually does a good job explaining things.
                                            Yup. His replies are valuable gems. I've been meaning to collect some of them into a tips/tricks post.
                                            • 1 / 3
