    Oalexis' WIPs
    34 Posts 6 Posters 9.7k Views 6 Watching
    • O
      oalexis
      It's from the half life 2 game. It's possible to get all the textures out of the game as well as all the other source games. It only requires two programs to do so. GCFScape, and VTFEdit ๐Ÿ˜„
      • X
        xrok1
        i can't get over how well it bumps. i opened it in PS cause i thought for sure it was coming from the alpha channel but NOOO.
        BTW, i love the trick with the semi transparent lens over the robot dogs eyes, it makes the red eyes appear as though they are glowing inside SU without even being rendered. [hats off]
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
        • O
          oalexis
          Thanks xrok1 ๐Ÿ˜„ Heres a building from today.
          http://i41.photobucket.com/albums/e258/oalexis/row_house.gif
          • O
            oalexis
            some other stuff i'm playing around with. I'm learning kerky now as well, seems to be a great program! ๐Ÿ˜„ I like the volumetric lighting feature
            • honoluludesktopH
              honoluludesktop
              Thanks for positing your model, and renders. Did a quick one because I always like to see what my standard setup can do in comparison to others. Your render is more dramatic. Be nice if the materials were distressed.
              • O
                oalexis
                some assests i made for use in a crysis map ๐Ÿ˜„ pics taken in the cryengine 2
                • X
                  xrok1
                  i've been playing with the crysis engine its awsome but i can't figure out how to get my SU stuff in there any tips or better yet a walk through of your process?? ๐Ÿ˜„
                  • O
                    oalexis
                    It indeed is awesome! You can use this technique here to get your stuff into the sandbox2 editor. http://www.crymod.com/thread.php?threadid=19058
                    • X
                      xrok1
                      ๐Ÿ˜ข i'll have to dig my copy of softimage out of the closet ๐Ÿคฃ
                      i was hoping you were using playup http://playuptools.blogspot.com/ that's what i was trying to work with but????
                      • O
                        oalexis
                        Actually you won't need softimage xrok1, if you read further through the thread there is a way to go directly from SU to sandbox 2. It requires you download a program called colladaCGF. Read a bit further down the thread, and you'll see it ๐Ÿ˜„ ๐Ÿ˜„ Also you could check in this thread http://www.sketchucation.com/forums/scf/viewtopic.php?f=80&t=11606&st=0&sk=t&sd=a&hilit=playup&start=30 or PM zapwizard, he can explain it more clearly, since I think he pioneered the technique.
                        • O
                          oalexis
                          Heres the growing number of stuff that i've put into the crysis editor, all built with sketchup, and textured in sketchup. normalmaps and spec maps and diffuse maps used in game.
                          • B
                            BTM
                            How did you get the god's fingers in the first KT render ๐Ÿ˜ฎ post processing?
                            • O
                              oalexis
                              Scene Settings > Global Settings > Volumetric lighting, then You can play around with the global fog settings at the bottom til you get the results you want. Be warned, it significantly increases your rendertime :S To get the god rays you use a very low amount of scatter I think, like 0.2, and keep the rest as they are. I could be wrong however, since that render was a few weeks ago
                              Oh heres some other stuff I forgot to post as well. Rendered in Kerky. The third and fourth are a spaceship i'm working on inspired by Homeworld 2 concept art
                              • O
                                oalexis
                                heres something recent i'm working on for a contest over at game-artist forums http://www.game-artist.net/forums/game-artist-mini-competition/11265-gamc-3-uav.html
                                The modelling is almost finished I just need to cut down the tri count because the you can only have 2000 tris for the competition and i'm at about 2100 right now
                                http://i41.photobucket.com/albums/e258/oalexis/UAV1.png
                                http://i41.photobucket.com/albums/e258/oalexis/UAV2.png
                                • X
                                  xrok1
                                  niiice! if the wing bottoms aren't totally flat you could try that to reduce tri's.
                                  • O
                                    oalexis
                                    ya I did that among a few other things and the tri count is now at 1979. Heres some shots of the UAV in the Crysis Engine. No texture maps yet
                                    http://i41.photobucket.com/albums/e258/oalexis/ScreenShot0003.jpg
                                    http://i41.photobucket.com/albums/e258/oalexis/ScreenShot0002.jpg
                                    http://i41.photobucket.com/albums/e258/oalexis/ScreenShot0001.jpg
                                    • X
                                      xrok1
                                      i love those little under elevators. inspired by a shark?
                                      https://www.epa.qld.gov.au/images/nature_conservation/grey_nurse_shark.jpg
                                      • O
                                        oalexis
                                        Its been a while. Working on a little Tron: Legacy inspired city scene. Also can a mod move this thread to the WIPs section? I don't think it was there when I originally started this thread.
                                        • O
                                          oalexis
                                          Added another building.
                                          • O
                                            oalexis
                                            An update... I currently only have a netbook to do this little project on, and it takes forever to do the renders! This one ran for just under 24 hours.
                                            • 2 / 2
