    Oalexis' WIPs
    34 Posts 6 Posters 9.0k Views 6 Watching
    • O Offline
      oalexis
      some other stuff i'm playing around with. I'm learning kerky now as well, seems to be a great program! ๐Ÿ˜„ I like the volumetric lighting feature
      • honoluludesktopH Offline
        honoluludesktop
        Thanks for positing your model, and renders. Did a quick one because I always like to see what my standard setup can do in comparison to others. Your render is more dramatic. Be nice if the materials were distressed.
        • O Offline
          oalexis
          some assests i made for use in a crysis map ๐Ÿ˜„ pics taken in the cryengine 2
          • X Offline
            xrok1
            i've been playing with the crysis engine its awsome but i can't figure out how to get my SU stuff in there any tips or better yet a walk through of your process?? ๐Ÿ˜„
            โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
            • O Offline
              oalexis
              It indeed is awesome! You can use this technique here to get your stuff into the sandbox2 editor. http://www.crymod.com/thread.php?threadid=19058
              • X Offline
                xrok1
                ๐Ÿ˜ข i'll have to dig my copy of softimage out of the closet ๐Ÿคฃ
                i was hoping you were using playup http://playuptools.blogspot.com/ that's what i was trying to work with but????
                • O Offline
                  oalexis
                  Actually you won't need softimage xrok1, if you read further through the thread there is a way to go directly from SU to sandbox 2. It requires you download a program called colladaCGF. Read a bit further down the thread, and you'll see it ๐Ÿ˜„ ๐Ÿ˜„ Also you could check in this thread http://www.sketchucation.com/forums/scf/viewtopic.php?f=80&t=11606&st=0&sk=t&sd=a&hilit=playup&start=30 or PM zapwizard, he can explain it more clearly, since I think he pioneered the technique.
                  • O Offline
                    oalexis
                    Heres the growing number of stuff that i've put into the crysis editor, all built with sketchup, and textured in sketchup. normalmaps and spec maps and diffuse maps used in game.
                      BTM
                      How did you get the god's fingers in the first KT render ๐Ÿ˜ฎ post processing?
                      • O Offline
                        oalexis
                        Scene Settings > Global Settings > Volumetric lighting, then You can play around with the global fog settings at the bottom til you get the results you want. Be warned, it significantly increases your rendertime :S To get the god rays you use a very low amount of scatter I think, like 0.2, and keep the rest as they are. I could be wrong however, since that render was a few weeks ago
                        Oh heres some other stuff I forgot to post as well. Rendered in Kerky. The third and fourth are a spaceship i'm working on inspired by Homeworld 2 concept art
                        • O Offline
                          oalexis
                          heres something recent i'm working on for a contest over at game-artist forums http://www.game-artist.net/forums/game-artist-mini-competition/11265-gamc-3-uav.html
                          The modelling is almost finished I just need to cut down the tri count because the you can only have 2000 tris for the competition and i'm at about 2100 right now
                          http://i41.photobucket.com/albums/e258/oalexis/UAV1.png
                          http://i41.photobucket.com/albums/e258/oalexis/UAV2.png
                          • X Offline
                            xrok1
                            niiice! if the wing bottoms aren't totally flat you could try that to reduce tri's.
                            • O Offline
                              oalexis
                              ya I did that among a few other things and the tri count is now at 1979. Heres some shots of the UAV in the Crysis Engine. No texture maps yet
                              http://i41.photobucket.com/albums/e258/oalexis/ScreenShot0003.jpg
                              http://i41.photobucket.com/albums/e258/oalexis/ScreenShot0002.jpg
                              http://i41.photobucket.com/albums/e258/oalexis/ScreenShot0001.jpg
                              • X Offline
                                xrok1
                                i love those little under elevators. inspired by a shark?
                                https://www.epa.qld.gov.au/images/nature_conservation/grey_nurse_shark.jpg
                                • O Offline
                                  oalexis
                                  Its been a while. Working on a little Tron: Legacy inspired city scene. Also can a mod move this thread to the WIPs section? I don't think it was there when I originally started this thread.
                                  • O Offline
                                    oalexis
                                    Added another building.
                                    • O Offline
                                      oalexis
                                      An update... I currently only have a netbook to do this little project on, and it takes forever to do the renders! This one ran for just under 24 hours.
                                      • 2 / 2
