    Oalexis' WIPs
    34 Posts 6 Posters 9.7k Views 6 Watching
    • O
      oalexis
      update on the room
      • O
        oalexis
        Heres the final on the room done with hypershot. Sadly i can't add an interior light because i can't create a .hdr file without photoshop and i only have elements.
        • O
          oalexis
          working on a model of a canyon, going to try and make it realistic. Just roughing in the basic shapes so far
          • O
            oalexis
            well i did a "simple" model of a light from the game half life 2... applying the texture in SU took forever due to the complex nature of the object. I know its not much but I thought I'd post it up since it took so long. Rendered it in podium
            • O
              oalexis
              heres a little test animation of the scene i'm setting up. First time i've done something like this. It was rendered in podium; still getting used to the program
              http://i41.photobucket.com/albums/e258/oalexis/testscene.gif
              • X
                xrok1
                how did you get the ground to look like that with podium ๐Ÿ˜ฎ thats awsome! could you post the settings or the file?
                โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                • O
                  oalexis
                  heres a little file i made to recreate the same look of the picture posted. Rendered on default in podium 1.6 with the quality and smooth sliders set to halfway.
                  Also heres a close up render of the forcefield fences in the animation
                  podium_settings_demo.skp
                  • X
                    xrok1
                    thats excellent, thankyou very much.
                    thats about the best ground texture i've ever seen. where's it from?
                    • O
                      oalexis
                      It's from the half life 2 game. It's possible to get all the textures out of the game as well as all the other source games. It only requires two programs to do so. GCFScape, and VTFEdit ๐Ÿ˜„
                      • X
                        xrok1
                        i can't get over how well it bumps. i opened it in PS cause i thought for sure it was coming from the alpha channel but NOOO.
                        BTW, i love the trick with the semi transparent lens over the robot dogs eyes, it makes the red eyes appear as though they are glowing inside SU without even being rendered. [hats off]
                        • O
                          oalexis
                          Thanks xrok1 ๐Ÿ˜„ Heres a building from today.
                          http://i41.photobucket.com/albums/e258/oalexis/row_house.gif
                          • O
                            oalexis
                            some other stuff i'm playing around with. I'm learning kerky now as well, seems to be a great program! ๐Ÿ˜„ I like the volumetric lighting feature
                            • honoluludesktopH
                              honoluludesktop
                              Thanks for positing your model, and renders. Did a quick one because I always like to see what my standard setup can do in comparison to others. Your render is more dramatic. Be nice if the materials were distressed.
                              • O
                                oalexis
                                some assests i made for use in a crysis map ๐Ÿ˜„ pics taken in the cryengine 2
                                • X
                                  xrok1
                                  i've been playing with the crysis engine its awsome but i can't figure out how to get my SU stuff in there any tips or better yet a walk through of your process?? ๐Ÿ˜„
                                  • O
                                    oalexis
                                    It indeed is awesome! You can use this technique here to get your stuff into the sandbox2 editor. http://www.crymod.com/thread.php?threadid=19058
                                    • X
                                      xrok1
                                      ๐Ÿ˜ข i'll have to dig my copy of softimage out of the closet ๐Ÿคฃ
                                      i was hoping you were using playup http://playuptools.blogspot.com/ that's what i was trying to work with but????
                                      • O
                                        oalexis
                                        Actually you won't need softimage xrok1, if you read further through the thread there is a way to go directly from SU to sandbox 2. It requires you download a program called colladaCGF. Read a bit further down the thread, and you'll see it ๐Ÿ˜„ ๐Ÿ˜„ Also you could check in this thread http://www.sketchucation.com/forums/scf/viewtopic.php?f=80&t=11606&st=0&sk=t&sd=a&hilit=playup&start=30 or PM zapwizard, he can explain it more clearly, since I think he pioneered the technique.
                                        • O
                                          oalexis
                                          Heres the growing number of stuff that i've put into the crysis editor, all built with sketchup, and textured in sketchup. normalmaps and spec maps and diffuse maps used in game.
                                          • B
                                            BTM
                                            How did you get the god's fingers in the first KT render ๐Ÿ˜ฎ post processing?
