    POST YOUR RENDERS NR.2: WAREHOUSE
    130 Posts 45 Posters 39.2k Views 45 Watching
    • soloS Offline
      We should have this kind of "challenge" at least once at week. What do you guys think?
      Sounds like a great i dea Competition will push my skill even further
      Guys I have to disagree there, as making it competitive or a challenge will take the free flow fun out of it and force us to judge instead of enjoy.
      Secondly I am opposed to judging render apps against each other as that is what it will end up as being.
      Lets keep it fun.
      • FrederikF Offline
        Frederik
        Lets keep it fun.
        Fully agree with Pete on this one...!! πŸ‘
        Let's keep it fun..!! πŸ˜„
        Cheers
        Kim Frederik
        • stefanqS Offline
          stefanq
          I guess you're right, Pete.
            richcat
            Please - let's keep it fun, informative and learn from each other.
            • N Offline
              nomeradona
              Lets keep it fun.
              well said solo/
                sepo
                Keep it fun please...
                • AnssiA Offline
                  Anssi
                  I fired up Artlantis R version 1 after about a year of no renders. This is what I got with no tweaking of materials at all. I will have to brush up my skills, but the model is so well textured that I am actually quite pleased already. Render time 48 seconds. Setup time 2-3 minutes.
                  Anssi
                    RustyShack
                    Another Artlantis render (v2). 3 mins
                    • marked001M Offline
                      marked001
                      @earthmover said:
                      After Post Process in Photoshop CS3
                      http://img80.imageshack.us/img80/4076/warehousevrayforsketchuge5.jpg
                      i think this is my fave so far.. def the most realistic. you should explain what all you did in pshop πŸ˜„
                      i'm working on a maxwell one right now.
                      http://www.revision21vis.com
                      instagram: revi21on
                      • E Offline
                        ENG. YASEEN
                        By Vray
                        By Vray
                        My Website:
                        http://xyz4studio.blogspot.com/
                          richcat
                          @kevsterman said:
                          I've downloaded the .skp but I seem to have a dark grey stripe top and bottom and I can't get rid of it πŸ˜•
                          Does anyone know whats causing it?
                          Kev if you have not fixed it already it can be corrected with a Rick Wilson ruby from smustard FixAspectRatio
                          • DanielD Offline
                            Daniel
                            Three Vue 7 renderings.
                            My avatar is an anachronism.
                              l.frisken
                              Indigo Render 5 hours 1333 samples per pixel on my 1.7 GHz that i think i accidently downclocked to around 0.7!
                                kevsterman
                                I solved the problem by pasting the warehouse into a new model. Thanks for your advice though πŸ‘
                                "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
                                • N Offline
                                  nomeradona
                                  here is my another try. this time with additional model from the warehouse
                                  Adding some more Warehouse stuff
                                  http://i334.photobucket.com/albums/m421/nomeradona_1234/withabubots.jpg
                                  Then warehouse models were refined to show details. created some bump textures and added them to the diffuse map. So here is the my render image (no post process). more than 12 minutes with my quad core.
                                  http://i334.photobucket.com/albums/m421/nomeradona_1234/warehouse_render_nopostcopy.jpg
                                  Post process image to add grunges.
                                  my steps using photoshop: 1. created a copy of the image and add filter high pass.. play on the opacity
                                  2. add a new layer, then use gradient tool of two colors (one light brown and one dark brown) blending mode is overlay
                                  3. add noise to this gradient map
                                  4. add mask and use textured map (35%) to removed slightly some grunge effect
                                  http://i334.photobucket.com/albums/m421/nomeradona_1234/renderwarehouse_Final.jpg
                                    marked001
                                    great job with the bump maps nomeradomna..that container looks great.
                                    here's my quick 15 minute maxwell setup..think it rendered for like 8 hours or so... didnt really adjust any of the materials, aside from the emitters..
                                    http://img4.imageshack.us/img4/6987/warehousetest3ox9.jpg
                                    and via multilight, here is a a daytime version
                                    http://img165.imageshack.us/img165/9003/frame1uc0.png
                                    instagram: revi21on
                                    • N Offline
                                      nomeradona
                                      mark, thnaks for that. i noticed you said your render is about 8 hours, thats really long. Mine was just 12 minutes. Is it becasue of the emitters?..How about the daytime version?
                                        marked001
                                        maxwell is slow slow slow... it probably could've been shorter though, but i went out and left it running. the night and day images are created from the same render.. maxwell has a feature where you can adjust the output of each individual emitter, as well as the environment..
                                        instagram: revi21on
                                          dtrarch
                                          How about the fastest render comparison ?
                                          Killer quick @ 20 secs
                                          KT Photonmap quick
                                          edit light/dark in KT
                                          Global hdr
                                            dtrarch
                                            KT again
                                            Photonmap fine + AA
                                            3 min
                                            • 5 / 7
