    POST YOUR RENDERS NR.2: WAREHOUSE
    130 Posts 45 Posters 37.2k Views 45 Watching
    • EarthMoverE Offline
      EarthMover
      Jan, it's Vray for SU7 1.5 found here - http://asgvis.com/index.php?option=com_remository&Itemid=0&func=select&id=30
      I guess there is a 1.5 also for SU6, so they call this one 1.60.16 in the render details. I guess officially it is VrfSU7 1.5.
      Content Creator at Skapeup
        kwistenbiebel
        The one with the loooooooong parsing time. A workflow killer .
          EarthMover
          Actually this warehouse is the fist thing I've rendered since I updated, and I've experienced zero parsing times. Could be that there are only 5 or so materials in the whole model. The 1.5 I was using before this was really bad. It's good to do quick test renders while texturing to find out what is slowing down parsing. It's usually due to materials placed on or in nested components.
            tmposey
            Kerkythea render preset 19 MLT/50 passes
            t.
            • soloS Offline
              We should have this kind of "challenge" at least once at week. What do you guys think?
              Sounds like a great i dea Competition will push my skill even further
              Guys I have to disagree there, as making it competitive or a challenge will take the free flow fun out of it and force us to judge instead of enjoy.
              Secondly I am opposed to judging render apps against each other as that is what it will end up as being.
              Lets keep it fun.
              • FrederikF Offline
                Frederik
                Lets keep it fun.
                Fully agree with Pete on this one...!! ๐Ÿ‘
                Let's keep it fun..!! ๐Ÿ˜„
                Cheers
                Kim Frederik
                • stefanqS Offline
                  stefanq
                  I guess you're right, Pete.
                    richcat
                    Please - let's keep it fun, informative and learn from each other.
                    • N Offline
                      nomeradona
                      Lets keep it fun.
                      well said solo/
                        sepo
                        Keep it fun please...
                        • AnssiA Offline
                          Anssi
                          I fired up Artlantis R version 1 after about a year of no renders. This is what I got with no tweaking of materials at all. I will have to brush up my skills, but the model is so well textured that I am actually quite pleased already. Render time 48 seconds. Setup time 2-3 minutes.
                          Anssi
                            RustyShack
                            Another Artlantis render (v2). 3 mins
                            • marked001M Offline
                              marked001
                              @earthmover said:
                              After Post Process in Photoshop CS3
                              http://img80.imageshack.us/img80/4076/warehousevrayforsketchuge5.jpg
                              i think this is my fave so far.. def the most realistic. you should explain what all you did in pshop ๐Ÿ˜„
                              i'm working on a maxwell one right now.
                              http://www.revision21vis.com
                              instagram: revi21on
                              • E Offline
                                ENG. YASEEN
                                By Vray
                                By Vray
                                My Website:
                                http://xyz4studio.blogspot.com/
                                  richcat
                                  @kevsterman said:
                                  I've downloaded the .skp but I seem to have a dark grey stripe top and bottom and I can't get rid of it ๐Ÿ˜•
                                  Does anyone know whats causing it?
                                  Kev if you have not fixed it already it can be corrected with a Rick Wilson ruby from smustard FixAspectRatio
                                  • DanielD Offline
                                    Daniel
                                    Three Vue 7 renderings.
                                    My avatar is an anachronism.
                                      l.frisken
                                      Indigo Render 5 hours 1333 samples per pixel on my 1.7 GHz that i think i accidently downclocked to around 0.7!
                                        kevsterman
                                        I solved the problem by pasting the warehouse into a new model. Thanks for your advice though ๐Ÿ‘
                                        "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
                                        • N Offline
                                          nomeradona
                                          here is my another try. this time with additional model from the warehouse
                                          Adding some more Warehouse stuff
                                          http://i334.photobucket.com/albums/m421/nomeradona_1234/withabubots.jpg
                                          Then warehouse models were refined to show details. created some bump textures and added them to the diffuse map. So here is the my render image (no post process). more than 12 minutes with my quad core.
                                          http://i334.photobucket.com/albums/m421/nomeradona_1234/warehouse_render_nopostcopy.jpg
                                          Post process image to add grunges.
                                          my steps using photoshop: 1. created a copy of the image and add filter high pass.. play on the opacity
                                          2. add a new layer, then use gradient tool of two colors (one light brown and one dark brown) blending mode is overlay
                                          3. add noise to this gradient map
                                          4. add mask and use textured map (35%) to removed slightly some grunge effect
                                          http://i334.photobucket.com/albums/m421/nomeradona_1234/renderwarehouse_Final.jpg
                                            marked001
                                            great job with the bump maps nomeradomna..that container looks great.
                                            here's my quick 15 minute maxwell setup..think it rendered for like 8 hours or so... didnt really adjust any of the materials, aside from the emitters..
                                            http://img4.imageshack.us/img4/6987/warehousetest3ox9.jpg
                                            and via multilight, here is a a daytime version
                                            http://img165.imageshack.us/img165/9003/frame1uc0.png
                                            instagram: revi21on
                                            • 5 / 7
