    POST YOUR RENDERS NR.2: WAREHOUSE
    130 Posts 45 Posters 35.1k Views 45 Watching
    • stefanqS Offline
      stefanq
      I guess you're right, Pete.
        richcat
        Please - let's keep it fun, informative and learn from each other.
        • N Offline
          nomeradona
          @solo said:
          We should have this kind of "challenge" at least once at week. What do you guys think?
          Sounds like a great i dea Competition will push my skill even further
          Guys I have to disagree there, as making it competitive or a challenge will take the free flow fun out of it and force us to judge instead of enjoy.
          Secondly I am opposed to judging render apps against each other as that is what it will end up as being.
          Lets keep it fun.
          well said solo/
            sepo
            Keep it fun please...
            • AnssiA Offline
              Anssi
              I fired up Artlantis R version 1 after about a year of no renders. This is what I got with no tweaking of materials at all. I will have to brush up my skills, but the model is so well textured that I am actually quite pleased already. Render time 48 seconds. Setup time 2-3 minutes.
              Anssi
                RustyShack
                Another Artlantis render (v2). 3 mins
                • marked001M Offline
                  marked001
                  @earthmover said:
                  After Post Process in Photoshop CS3
                  http://img80.imageshack.us/img80/4076/warehousevrayforsketchuge5.jpg
                  i think this is my fave so far.. def the most realistic. you should explain what all you did in pshop πŸ˜„
                  i'm working on a maxwell one right now.
                  http://www.revision21vis.com
                  instagram: revi21on
                  • E Offline
                    ENG. YASEEN
                    By Vray
                    By Vray
                    My Website:
                    http://xyz4studio.blogspot.com/
                      richcat
                      @kevsterman said:
                      I've downloaded the .skp but I seem to have a dark grey stripe top and bottom and I can't get rid of it πŸ˜•
                      Does anyone know whats causing it?
                      Kev if you have not fixed it already it can be corrected with a Rick Wilson ruby from smustard FixAspectRatio
                      • DanielD Offline
                        Daniel
                        Three Vue 7 renderings.
                        My avatar is an anachronism.
                          l.frisken
                          Indigo Render 5 hours 1333 samples per pixel on my 1.7 GHz that i think i accidently downclocked to around 0.7!
                            kevsterman
                            I solved the problem by pasting the warehouse into a new model. Thanks for your advice though πŸ‘
                            "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
                            • N Offline
                              nomeradona
                              here is my another try. this time with additional model from the warehouse
                              Adding some more Warehouse stuff
                              http://i334.photobucket.com/albums/m421/nomeradona_1234/withabubots.jpg
                              Then warehouse models were refined to show details. created some bump textures and added them to the diffuse map. So here is the my render image (no post process). more than 12 minutes with my quad core.
                              http://i334.photobucket.com/albums/m421/nomeradona_1234/warehouse_render_nopostcopy.jpg
                              Post process image to add grunges.
                              my steps using photoshop: 1. created a copy of the image and add filter high pass.. play on the opacity
                              2. add a new layer, then use gradient tool of two colors (one light brown and one dark brown) blending mode is overlay
                              3. add noise to this gradient map
                              4. add mask and use textured map (35%) to removed slightly some grunge effect
                              http://i334.photobucket.com/albums/m421/nomeradona_1234/renderwarehouse_Final.jpg
                                marked001
                                great job with the bump maps nomeradomna..that container looks great.
                                here's my quick 15 minute maxwell setup..think it rendered for like 8 hours or so... didnt really adjust any of the materials, aside from the emitters..
                                http://img4.imageshack.us/img4/6987/warehousetest3ox9.jpg
                                and via multilight, here is a a daytime version
                                http://img165.imageshack.us/img165/9003/frame1uc0.png
                                instagram: revi21on
                                • N Offline
                                  nomeradona
                                  mark, thnaks for that. i noticed you said your render is about 8 hours, thats really long. Mine was just 12 minutes. Is it becasue of the emitters?..How about the daytime version?
                                    marked001
                                    maxwell is slow slow slow... it probably could've been shorter though, but i went out and left it running. the night and day images are created from the same render.. maxwell has a feature where you can adjust the output of each individual emitter, as well as the environment..
                                    instagram: revi21on
                                      dtrarch
                                      How about the fastest render comparison ?
                                      Killer quick @ 20 secs
                                      KT Photonmap quick
                                      edit light/dark in KT
                                      Global hdr
                                        dtrarch
                                        KT again
                                        Photonmap fine + AA
                                        3 min
                                        • F Offline
                                          Fletch
                                          great Dtrarch!
                                          here's a thought...
                                          when posting render times, number of threads used is important... I have a quad at work, a single at home... not the same game at all...
                                          Fletch
                                          Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                                            dtrarch
                                            Fletch
                                            good idea
                                            Cor2 Duo 8400
                                            dtr
                                            • 5 / 7
