[Plugin] follow me rotate
211 Posts 79 Posters 235.2k Views 79 Watching
  • W Offline
    wikii
    @plot-paris said:
    and I have a suggestion for a future update:
    if you have a face with it's midpoint not at the starting point of the curve, the cuve will be moved to this centre point.
    would it be possible to prevent this from happening, so that you can use a shape with an offset, that is twisted arround the path with a certain distance.
    Try to select one curve , one face and one construction point , then , using FAR. The construction point will be treated as the center of the face.
      plot-paris
      weird. it only works for me, if I have a curve as a path. it doesn't work with a straight line like in your example (not even the dialog box for rotation/scale input appears)...
      but arround a curve it looks really cool! 😄
        marcosrodrigues
        Seems very promising, Wikii. Thank you.
        | menos é mais
          Your are not alone 😄
          And yet some erratic Works for 2 straight lines welded, sometimes yes, sometime no
          yesno.skp
            Interesting plugin but this is what I get.
            http://img.photobucket.com/albums/v506/weekender410/669479e4.jpg
            http://img.photobucket.com/albums/v506/weekender410/99a1dcc5.jpg
            http://img.photobucket.com/albums/v506/weekender410/915bea9b.jpg
            http://img.photobucket.com/albums/v506/weekender410/0f17c9f7.jpg
            • W Offline
              wikii
              select a face without it's border
                thank you. that works.
                • W Offline
                  watkins
                  Dear Pilou,
                  Thanks for posting the .zip file.
                  Regards,
                  Bob
                  • F Offline
                    free agent
                    hey wow awsome plugin, thanx for posting, is there any way to reverse the triangulation of the faces, i noticed that once smoothed the and as you rotate the form it gets very jaggy at the edges and you have to go in there with the flip edge tool to smooth it out... any way around this within the coding?
                      juju
                      We have some very gifted people here, only surpassed by their generosity. Thank you (all the ruby programmers, both free and commercial) so much for SU so much than it was.
                        cyan.archnet
                        simply "AMAZING", will give it a try, THANKS A LOT !!
                          dirkkkk
                          When I am using the plug in I get a bug splat... don`t know why 😞
                          Could It be because I am using a 64 bit system,
                          Thanks,
                            or it conflicts with another plugin.
                            You can test this by removing your plugins one by one and constntly restarting SU after each. A little tedious if you have a lot.
                            • N Offline
                              notareal
                              Nice work!
                              Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                              • H Offline
                                herodes
                                I am having difficulties running this script. Inside the latest Far.rar I find:
                                inputbox.rb -- for the interface
                                FollowAndRotate_en.rbs -- the English version of the script
                                FollowAndRotate_cn.rbs -- the Chinese version of the script
                                far.skp -- example output
                                I extract inputbox.rb and FollowAndRorate_en.rbs in the Sketchup Plugins folder and execute sketchup.exe. Going to the Plugins menu there is nothing to be found...
                                In the Ruby console, I type "load 'FollowAndRotate_en.rbs'" and get this:
                                load "FollowAndRotate_en.rbs"
                                Error; #<SyntaxError; (eval);87;in `load'; C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; no .<digit> floating literal anymore; put 0 before dot
                                RBS1.0
                                C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; syntax error
                                RBS1.0
                                C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; Invalid char `\020' in expression>
                                (eval);87
                                can you help me,...?
                                %(#BFBFBF)[http://arhitektonas.blogspot.com
                                I know me,... I am that guy...
                                • W Offline
                                  wikii
                                  To load a rbs file,you can try to use Sketchup.load
                                    And for the little problem of orientation?
                                    • H Offline
                                      herodes
                                      Thanks for answering.
                                      I tried the suggesting and now I get :
                                      Sketchup.load "FollowAndRotate.rbs"
                                      false
                                      ... and there is still nothing in the "Plugins" menu.
                                      How did all the others get it working ?
                                      • H Offline
                                        herodes
                                        Sorry for bumping this thread.
                                        Please help.
                                          Daniel S
                                          Herodes:
                                          I think that you don´t install it well
                                          Put the three files in your plugin folder
                                          inputbox.rb
                                          Perhaps this fix your problem.
                                          Daniel S
                                          • 11
                                          • 2 / 11
                                          2 / 11
