    [Plugin] follow me rotate
    211 Posts 79 Posters 280.0k Views 79 Watching
    • soloS
      hey, It works!
      http://img407.imageshack.us/img407/2218/imageoftwist1qo2.jpg
      Thanks mate.
      • EarthMoverE
        EarthMover
        It's working for me also. Thanks sooo much wikii!!
        Content Creator at Skapeup
          silver_shadow
          %(#FFBF00)[Wheeee, thanx a million !!! β˜€]
          • bigstickB
            bigstick
            This is fantastic! Thanks a lot wikii!
            • plot-parisP
              plot-paris
              phantastic plugin Wikii! thanks for sharing 😍
              however, when I use a welded curve, I get very unexpected results. something doesn't seem to be working with welded paths. everything works fine if I use a bezier curve (no matter how complicated)
              http://img205.imageshack.us/img205/3448/far01kh7.jpg
              and I have a suggestion for a future update:
              if you have a face with it's midpoint not at the starting point of the curve, the cuve will be moved to this centre point.
              would it be possible to prevent this from happening, so that you can use a shape with an offset, that is twisted arround the path with a certain distance.
              or even better, could you change the script to allow the use of several seperate faces?
              http://img87.imageshack.us/img87/8549/far02vh5.jpg
              • W
                watkins
                Any chance of making this available as a .zip file? I have problems with files with .rar extensions.
                  Funny πŸ‘ β˜€ 😎
                  Done πŸ˜‰
                  Far.zip
                  • W
                    wikii
                    Try to select one curve , one face and one construction point , then , using FAR. The construction point will be treated as the center of the face.
                    • plot-parisP
                      plot-paris
                      weird. it only works for me, if I have a curve as a path. it doesn't work with a straight line like in your example (not even the dialog box for rotation/scale input appears)...
                      but arround a curve it looks really cool! πŸ˜„
                        marcosrodrigues
                        Seems very promising, Wikii. Thank you.
                        | menos Γ© mais
                          Your are not alone πŸ˜„
                          And yet some erratic Works for 2 straight lines welded, sometimes yes, sometime no
                          yesno.skp
                            Interesting plugin but this is what I get.
                            http://img.photobucket.com/albums/v506/weekender410/669479e4.jpg
                            http://img.photobucket.com/albums/v506/weekender410/99a1dcc5.jpg
                            http://img.photobucket.com/albums/v506/weekender410/915bea9b.jpg
                            http://img.photobucket.com/albums/v506/weekender410/0f17c9f7.jpg
                            • W
                              wikii
                              select a face without it's border
                                thank you. that works.
                                • W
                                  watkins
                                  Dear Pilou,
                                  Thanks for posting the .zip file.
                                  Regards,
                                  Bob
                                  • free agentF
                                    free agent
                                    hey wow awsome plugin, thanx for posting, is there any way to reverse the triangulation of the faces, i noticed that once smoothed the and as you rotate the form it gets very jaggy at the edges and you have to go in there with the flip edge tool to smooth it out... any way around this within the coding?
                                    http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                                    • jujuJ
                                      juju
                                      We have some very gifted people here, only surpassed by their generosity. Thank you (all the ruby programmers, both free and commercial) so much for SU so much than it was.
                                      • C
                                        cyan.archnet
                                        simply "AMAZING", will give it a try, THANKS A LOT !!
                                          dirkkkk
                                          When I am using the plug in I get a bug splat... don`t know why 😞
                                          Could It be because I am using a 64 bit system,
                                          Thanks,
                                          • GaieusG
                                            or it conflicts with another plugin.
                                            You can test this by removing your plugins one by one and constntly restarting SU after each. A little tedious if you have a lot.
                                            • 11
                                            • 2 / 11
