    [Plugin] follow me rotate
    211 Posts 79 Posters 274.1k Views 79 Watching
    • jujuJ Offline
      juju
      We have some very gifted people here, only surpassed by their generosity. Thank you (all the ruby programmers, both free and commercial) so much for SU so much than it was.
        cyan.archnet
        simply "AMAZING", will give it a try, THANKS A LOT !!
          dirkkkk
          When I am using the plug in I get a bug splat... don`t know why 😞
          Could It be because I am using a 64 bit system,
          Thanks,
            or it conflicts with another plugin.
            You can test this by removing your plugins one by one and constntly restarting SU after each. A little tedious if you have a lot.
            • N Offline
              notareal
              Nice work!
              • H Offline
                herodes
                I am having difficulties running this script. Inside the latest Far.rar I find:
                inputbox.rb -- for the interface
                FollowAndRotate_en.rbs -- the English version of the script
                FollowAndRotate_cn.rbs -- the Chinese version of the script
                far.skp -- example output
                I extract inputbox.rb and FollowAndRorate_en.rbs in the Sketchup Plugins folder and execute sketchup.exe. Going to the Plugins menu there is nothing to be found...
                In the Ruby console, I type "load 'FollowAndRotate_en.rbs'" and get this:
                load "FollowAndRotate_en.rbs"
                Error; #<SyntaxError; (eval);87;in `load'; C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; no .<digit> floating literal anymore; put 0 before dot
                RBS1.0
                C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; syntax error
                RBS1.0
                C;/Program Files/Google/Google SketchUp 6/Plugins/FollowAndRotate_en.rbs;1; Invalid char `\020' in expression>
                (eval);87
                can you help me,...?
                %(#BFBFBF)[http://arhitektonas.blogspot.com
                I know me,... I am that guy...
                • W Offline
                  wikii
                  To load a rbs file,you can try to use Sketchup.load
                    And for the little problem of orientation?
                    • H Offline
                      herodes
                      Thanks for answering.
                      I tried the suggesting and now I get :
                      Sketchup.load "FollowAndRotate.rbs"
                      false
                      ... and there is still nothing in the "Plugins" menu.
                      How did all the others get it working ?
                      • H Offline
                        herodes
                        Sorry for bumping this thread.
                        Please help.
                          Daniel S
                          Herodes:
                          I think that you don´t install it well
                          Put the three files in your plugin folder
                          inputbox.rb
                          Perhaps this fix your problem.
                          Daniel S
                          • H Offline
                            herodes
                            @Daniel S: Thanks it did require that the FollowAndRotate_cn.rbs is in the same folder. That solved it thanks a lot.
                            It is rather weird that that both scripts are required.
                              rjb
                              hi!
                              this is an awesome plugin.. was able to do lots of things with it..
                              but m unable to make a fluted tapering column yet..
                              please guide me if anyone knows the trick....
                              • MALAISEM Offline
                                MALAISE
                                So useful, really impressive 👍 👍
                                It could be also a good idea to display a kind of counter
                                in order to avoid any operation during the calculation
                                ( let's see some Didier 's Plugins like terrain reshaper )
                                ----------------80% achieved..
                                MALAISE 😄
                                  bianhai
                                  follow me rotate tutorials
                                  http://www.sketchupbbs.com/thread-13577-1-1.html
                                  http://www.sketchupbbs.com/attachments/month_0809/20080927_f20be19093c967fcf1a22HBisFh3rjMv.gif
                                  SUTOOL2009 tutorials
                                  see here blog:
                                  http://www.sketchupbbs.com/Blog/?54739/
                                    silver_shadow
                                    hi bianhai
                                    what is that side panel thing you are using in your video?
                                      bianhai
                                      side panel is SUTOOL2009
                                        Really cool plugin. Though, there's some odd triangulation some times. Looks like half of it ends up smooth, but the other half of the geometry ends up with sharp jagged triangulation.
                                          silver_shadow
                                          is it a free plugin 😄?
                                            rufy
                                            nice plugin 👍
                                            by the way,what is SUTOOL 2009? it is new plugin ?, i saw the toolbar at the video by bianhai, i search in google, i found it , i know that site but i can understand chinese languange, 🎉
                                            • 11
                                            • 2 / 11
